Engine bay freshen-up questions from a new guy | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Doug D, May 15, 2020.
  1. Doug D
    Doug D Rookie
    May 6, 2020
    27
    Douglas Dwyer
    Hi, new guy here. Not new to working on cars but I've just begun dabbling a bit in Ferraris. My background over the decades is mostly Jag/Corvette/muscle car stuff.
    Current project is a 1974 365 GT4 2+2. It's a nice driver-quality car needing some TLC in a few areas. Besides light mechanicals and servicing I am doing an engine bay freshen-up.
    A couple questions in that regard....although as the weeks pass I'm sure I'll have more!
    1) The air intake ducts that are bonded to the inner fenderwells: In looking at pics I see some are black and others are silver. Is there a rhyme or reason to this? Presently the ducts on this particular car are black but it has become clear to me that I'm not the first person to have done some cosmetic rehab work on the engine bay.
    2) Air cleaner housings/boxes: At first glance I thought these had a wrinkle finish like the cam covers. However, while there is some texture to the finish, it really isn't "wrinkle" texture. More like a very fine pebble texture. What the correct finish for these?
    Although a true restoration is beyond the scope of this project I do want to get (at least) the easy stuff right!
    Thanks for any help.
    Doug D.
    Pacific Northwest USA
  2. raemin
    raemin Formula 3
    Jan 16, 2007
    1,865
    Lyon (FR)
    R. Emin
    I've usually seen the 365 with black intakes, while the 400 are aluminium. Note that the firewall is painted the same colour as the intake. Note also that the 412 has no wrinkle paint on the cam covers.
    Indeed the wrinkle paint is far less thick on the air-filter-boxes, but so is the material underneath. I presume it would be hard to apply a 2mm coat of paint over a half millimetre sheet of metal. The coat of paint would probably crack easily.
    The proper way to apply this paint is normally one coat of fast drying/curing paint (acrylic?) and one coat of slow cure paint (petroleum based). As one paint cures faster than the other you get the wrinkles. If the base-coat is not too much damaged you can overspray it with epoxy.
    Doug D likes this.
  3. simon klein
    simon klein Two Time F1 World Champ
    Feb 25, 2009
    28,802
    North Qld
    simon klein
    G'day Doug!
    The air thingy's,for mine,should be silver in the 365's,there has been discussion on here re that and I think most reckon the same.
    The air boxes should be similarish to the cam covers,someone else will tell you I'm sure.
    Some pics will aid the answers to your questions.....and pics of the rest of the thing as well!
    Doug D likes this.
  4. Doug D
    Doug D Rookie
    May 6, 2020
    27
    Douglas Dwyer
    Gentlemen, thanks for the input and taking the time to reply
    Cheers
    DD
  5. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,685
    Seattle, WA
    Brian White
    Post some engine bay pics Doug.... :)
  6. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    Doug D likes this.
  7. Doug D
    Doug D Rookie
    May 6, 2020
    27
    Douglas Dwyer
    WDA, thanks for the pics. The ducts on my car certainly have some sort of gloppy stuff applied. Who applied it, I don't know. I like the look you achieved.
    Cheers
    DD
  8. Doug D
    Doug D Rookie
    May 6, 2020
    27
    Douglas Dwyer
    Here's a pic I grabbed on the run, I'll add more later
    Though not shown in the photo it appears that the firewall may have originally been entirely silver, including the ducting under the cowl. Does that sound right?
    I'm seeing many traces of red paint in the engine bay under layers of black. I've also seen traces of red in tiny nooks and crannies in the body work. This brings me to believe the car was originally red. Did Ferrari paint the entire car body color and then blackout the engine bay areas?
    As I may have mentioned, "a person or persons, not me", had been in the engine bay before with some spray bombs. I have black and silver in odd places. That's all be corrected. The pedal box has been painted entirely silver; doesn't seem right to me.
    Job is progressing slowly but steadily. I dedicate 2-3 hours/day to it. Not much left to strip out of the engine bay. Starter is heading off for a freshen up on general principles with the alternator to follow. After prepping a nicely painting the engine bay and detailing the engine itself....to the extent possible in situ....I'll work on refurbishing everything I've removed. Then reassembly begins.
    Fun project!
    Thanks for all the input so far
    Cheers
    DD
    Il Tifoso likes this.
  9. raemin
    raemin Formula 3
    Jan 16, 2007
    1,865
    Lyon (FR)
    R. Emin
    Pedal box is also silver on mine, and so was the entire firewall. This paint seemed original to me. I've recently painted the firewall black but kept the pedal box silver.
    Under the airbox paint, the coarse coating is the same one as what is used on the tanks and the inner door panels. I would keep some sort of insulator here, as the engine bay can be hot as hell and insulating this metallic part would avoid to feed the cockpit with insanely hot air.
    Doug D likes this.
  10. samsaprunoff
    samsaprunoff F1 Rookie
    4,179
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Doug
    On my car (365 as well) the fender mounted air ducts are coated as Raemin described. I agree that these ducts should be Silver in color, as this will help to reflect engine bay heat. Painting them black will certainly accelerate heating of the cavity resulting in larger air temps flowing into the car's cabin.
    Cheers,
    Sam
  11. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,551
    SF Bay Area, CA
    Ruben
    That makes sense Sam, but for what it’s worth, Ferrari seems to have gone back to black crackle texture on the 412.
    Cheers,
    Ruben
  12. samsaprunoff
    4,179
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Ruben,
    Understood. Personally I think the black wrinkle finish looks much better and matches the engine bay components (valve covers, etc). As to why they changed this...perhaps the heating of the incoming cabin air was not an issue, or the 412 had improved their HVAC system, or Ferrari just went with aesthetics. Sadly, we simply do not know. What I do know is that insulating the fresh air intake will make it easier for the cabin HVAC to do its job. I am unsure how well the 365/400/412's HVAC system is, but given the number of other model era HVAC complaints (308's, Boxers, etc) I would suspect that any help you can provide to Ferrari's HVAC system would indeed be beneficial.
    Cheers,
    Sam
  13. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,551
    SF Bay Area, CA
    Ruben
    Hey Sam, yeah, I agree that the aesthetics is better with the black. On the HVAC performance, my car has the dual AC, which I think all 412s may have (?) - it works fantastically well, even in 95 deg heat. Maybe Ferrari in their infinite wisdom decided that they wanted the engine bay to look its best in black crackle paint, so they decided to just make the dual AC standard! :D
    Cheers,
    Ruben
  14. samsaprunoff
    4,179
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Ruben,
    Obviously Ferrari was listening to its customers and went with the Dual AC on the later model...and I am sure it helped a lot :). ... and I am sure you appreciate this chnage! That being said, one would be surprised at how somewhat minor details/changes can have such an affect on the HVAC of a space. As an example, I am in an old (1954) building and the building's AC was an add on much later... and whoever installed it simply ignored the laws of Thermodynamics. With that said, I have one office which was getting quite warm in the Summer. A full AC retrofit with an air handler would be the best solution, however, until this is done I simply made some air flow adjustments along with installing some blinds and the result was a reduction in space temperature by over 5 degrees... which makes the space comfortable and less taxing on the current AC system... a win-win as it were.
    Cheers,
    Sam
  15. raemin
    raemin Formula 3
    Jan 16, 2007
    1,865
    Lyon (FR)
    R. Emin
    The HVAC of the 412 definitively works much better. I presume the three additional ASTI fans do contribute to the efficiency of the 412 as the rest of the AC is using basically the same hardware. 400i gen1 only has one additional ASTI cooling fan, while the 365 had to make it do without ant additional fans. The 365 is by far the hottest...
    Air-duct paint: I will probably upgrade this somehow as the texture does not stick to the duct. From time to time I just have an annoying bit that comes off.
  16. Doug D
    Doug D Rookie
    May 6, 2020
    27
    Douglas Dwyer
    Gentlemen,
    I haven't been a very good correspondent. Sorry. I am making slow-but-steady progress. I'll post some pics soon
    On this issue of fender ducts I ended up going with black. I sanded and scraped....and could find no evidence that they were ever silver. I may change my mind, though. There is so much black in the engine bay the silver might be a welcome bright spot.
    Anyhow, I have some questions but will start a new thread.
    Doug
  17. Doug D
    Doug D Rookie
    May 6, 2020
    27
    Douglas Dwyer
    Hi everyone. It's been a long time. You've probably forgotten about me but I haven't forgotten about you....although it may seem that way. The project is nearing completion after many adventures, lessons, and being back-burner'd a few times.
    Carbs overhauled, cam cover gaskets replace, starter and alternator overhauled, new plug wires, sending units, new fuel hoses, new heater and hood cables, and....and....and. You all know the drill. I've learned a lot. Also repaired the headlight motors and circuits, power windows, blowers, and a slew of previously-hacked-up wiring. I lost count of how many new hose clamps and shiny new acorn nuts I had to buy!
    Engine started instantly after carb overhauls, new points, etc. I was sure that I'd bollix up the distributor reinstallation and timing but, by golly.....I didn't. That was a huge relief. Sounds great and responded perfectly to carb adjustments. Working on brakes now and hope to actually drive it in a day or two.
    I have some questions on details items that I'll post in a new thread.
    Here's a pic to prove I haven't been sitting on my hands. I think it looks decent for a driver-quality car.
    Cheers
    Doug
  18. simon klein
    Feb 25, 2009
    28,802
    North Qld
    simon klein
    You are sooo gunna love opening all those throats!!! :D
    Doug D likes this.
  19. Doug D
    Doug D Rookie
    May 6, 2020
    27
    Douglas Dwyer
    I was hoping for that enjoyment but it didn't quite pan out :)
    After a quick drive a few weeks ago the brakes began seizing-up, which I sorta expected, to be honest. So, a break from test-driving while a full brake system overhaul took place...which was unremarkable.
    Drove the car some more recently. Starts easily, idles well, good throttle response, shifts well, etc. But.....when I begin pouring on the coals the engine splutters and complains. 'Tis sweet as can be until 3000 rpm or so. Again, I'm not entirely surprised. I have not tweaked the timing or anything. Everything to this point has been to simply get the engine to start, run, and idle. I assumed there would be more work ahead of me.
    I'll be starting a new thread with some questions
    Cheers
    DD
  20. Theruse
    Theruse Karting
    Jan 17, 2014
    119
    Maryland
    Prescott Russo
    Doug D likes this.
