Engine Bay Restoration | FerrariChat
Discussion in '308/328' started by Car-nutt, Feb 17, 2025.
  1. Car-nutt
    Car-nutt Rookie
    Sep 13, 2024
    18
    Toronto
    Larry Conte
    Hello everyone, I am planning to paint and detail the engine compartment in my 1978 308. Can I take off both valve covers without pulling out the motor?
  2. mixedgas
    mixedgas Formula Junior Silver Subscribed
    Apr 23, 2019
    265
    Ramona, CA
    Indeed, no need to remove the engine to remove cam covers (valve covers) but removing the rear hood makes life much easier. Also if you're going to thoroughly clean up / re-seal the engine and clean / paint the engine bay, it's probably easier in the long run to pull the engine.
    ChevyDave likes this.
  3. bitsobrits
    bitsobrits Formula Junior Rossa Subscribed Silver Subscribed
    Nov 12, 2011
    740
    Omaha, NE area, US
    Steve
    I started down the path of cleaning and resealing the engine without removing it. After a couple of weekends of efforts, I decided to pull the engine which made everything sooo much easier, and helped me find some time bombs (like fuel tanks corroding from the inside out) that saved me later grief.
  4. miked
    miked Formula Junior
    Feb 7, 2001
    897
    Cincinnati, Ohio
    I agree 100%, spending a day pulling the engine is well worth the effort whether your project is the engine compartment or the engine itself. Beware, you will find lots of things that need fixing or replacing that you would never had noticed without pulling the engine.
