Engine block and radiator coolant drain taps | FerrariChat
Discussion in '206/246' started by daviekj, Apr 12, 2009.
  1. daviekj
    daviekj Formula Junior
    486
    #1 daviekj, Apr 12, 2009
  2. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  3. daviekj
    486
    Scott,
    looks ideal, and about as cheap as it gets for a Dino.
    kevin
  4. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Champ,
    Got your PM. GT Car parts has the radiator tap for $3.93, ask for part number 1701905
    Scott
  5. champtc
    champtc Formula Junior
    Apr 18, 2004
    732
    Thanks Scott- I will check it out- appreciate it!
  6. beanderb4
    beanderb4 Rookie
    May 19, 2011
    2
    Dublin
    Paul
    Hi Synchro,
    Can I just check with you if you bought the 1/4" tap and did this fit the Dino block?
    Many thanks.
  7. champtc
    Apr 18, 2004
    732
    I did buy it and it fit perfectly. I ended up getting it at Napa. I think I bought an extra one and if you cant find one I will be glad to send it to you.
  8. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    These are standard drains for air compressors.
    BTW, one problem is that people tighten these far too tight then later nearly destroy it when they need to open the drain. Be gentle
  9. beanderb4
    beanderb4 Rookie
    May 19, 2011
    2
    Dublin
    Paul
    Thanks for the very kind offer champtc. I have just bought two from jaydog512 on ebay for the grand total of $5.98. :))
    That must be the cheapest part I have ever bought for this engine!!
    I'll let you know how I get on.
    Many thanks.
