Engine break-in oil questions | FerrariChat
Discussion in '206/246' started by utah4re, Sep 8, 2008.
  1. utah4re
    utah4re Karting
    Nov 1, 2005
    52
    I have always used 30wt break-in oil. After checking oil posts here and other sources, I have read about the change to oil and warnings to owners with engines with flat tappet cams. I looked at Royal Purple break-in oil and discovered it is only in a 10w30 weight. Would this be a problem. How many miles are recommended before changing the break-in oil. Thank you in advance for any good input.
  2. frankwissman
    frankwissman Karting
    May 6, 2006
    63
    Charleston, SC
    Frank Wissman
    Now that Kendall had it’s Zinc removed to preserve catalytic converters, Brad Penn oil http://www.bradpennracing.com/ has become very popular with it’s high ZDDP content. I know a few vintage cars that made the switch to Brad Penn. Also, I’ve heard of Joe Gibbs break-in oil http://www.joegibbsracingoil.com/ but haven’t talked with anyone who has 1st hand experience with it.
    I favor using a generous amount of Red Line assembly lube, Brad Penn 20W-50 and changing the oil and filter after a few miles up hills in as high a gear as I can pull cleanly.
