"Engine Check 1-4 cylinders" swicht on above 5.000rpm | FerrariChat
Discussion in '348/355' started by Sergiaib, Oct 15, 2007.
  1. Sergiaib
    Sergiaib Karting
    Sep 12, 2007
    106
    Vallès (BCN)
    Carlos
    Hello,
    I have a little problem in my 348 (1991). When I go above 5.000rpm orange light "Engine Check 1-4 cylinders" swicht on... And down 5.000rpm the light switch off ...(?)
    I look for the warning lights in the 348 manual and it explain that "Engine Check 1-4 cylinders" is NOT USE and appear at right of light battery/alternator. In my car the orange light "Engine Check 1-4 cylinders" is place at left of "Handbrake" light...
    I don't undestand it
    Can you help me ???
    Thank you very much
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    When your motor is off, turn your ignition key to position II (the "run" but not the "start" setting).
    Note which warning lights illuminate for the bulb test. Even better, snap a picture of those lights and post it here.
    The behavior that you describe is consistent with a failing alternator triggering your battery light, but you are reporting a CEL 1-4 light instead, so if the bulbs aren't somehow misaligned I'd suggest pulling your engine error codes with these instructions: http://www.club348.com/technical/Tech/348.html#ECUcodes
    Post those error codes here.
    You can place your seat belt warning light bulbs into your CEL 1-4 and CEL 5-8 warning light sockets to activate a considerable amount of on-board Ferrari diagnostics for your car, by the way.
  3. Sergiaib
    Sergiaib Karting
    Sep 12, 2007
    106
    Vallès (BCN)
    Carlos
    Thank you very much No Doubt, This afternoon take the picture and post it here !!!
    Yesterday with my mechanical (not Ferrari mechanical saw that mi 348 don't have catalysers !!!!) and the error could be for this reason... :-O
  4. Sergiaib
    Sergiaib Karting
    Sep 12, 2007
    106
    Vallès (BCN)
    Carlos
    My car is European and link says
    """How To Check The 348 A/F ECU Diagnostic Codes (non-Euro 348's)"""
  5. Sergiaib
    Sergiaib Karting
    Sep 12, 2007
    106
    Vallès (BCN)
    Carlos
    There is not "Slow down" right and left because they switch off very very quick; they are above oil(left) and ABS(right)
  6. Sergiaib
    Sergiaib Karting
    Sep 12, 2007
    106
    Vallès (BCN)
    Carlos
  7. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Even though you have a Euro 348, your car has been set up with full Ferrari engine diagnostics. Open up the panel that is just to the rear of your seats and you will see your two main engine computers.
    There should be a button attached to each one that will allow you to pull your engine diagnostic codes.
  8. Sergiaib
    Sergiaib Karting
    Sep 12, 2007
    106
    Vallès (BCN)
    Carlos
    Excuse me, No Doubt, tomorrow I will pass ITV (mot) After it I will put to look the instructions...
    Thank you very much
    Carlos
