Engine Coming Out | FerrariChat
Engine Coming Out
Discussion in '206/246' started by naparsei, Jul 6, 2025.
  1. naparsei
    naparsei Formula Junior
    Oct 11, 2005
    299
    Land of Enchantment
    Alex
    of my '72 246GT.
    Is there anything I should add to the maintenance besides adjusting the forward timing chain and valve cover gaskets?
    TIA.
  2. swift53
    swift53 F1 Veteran
    8,269
    E.S.
    Alberto
    Alex, Valve clearances, Crank seals, Check clutch disc, and anything else that's a bear to do w/engine in, but not out.
    Change all fluids, Thermostat, check water pump for play, et al.
    Have fun! So nice to have an engine out and work on it with a comfy chair next to it. :)
    Regards, Alberto
    375+ likes this.
  3. swift53
    swift53 F1 Veteran
    8,269
    E.S.
    Alberto
    PS. Alex, please remember how to adjust the chain tensioners properly, by hand rotation.
  4. naparsei
    Oct 11, 2005
    299
    Land of Enchantment
    Alex
    Is there a way to get a shop manual (either "real" or replica)? Thanks!
  5. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,298
    Sergio Tavares
    Make snaps of the engine type and number
  6. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    Unless it is bone dry replace the gasket that goes between the casting that houses the crankshaft main seal and the block. This gasket cannot be replaced with the engine in and is much easier to do with the engine out.
    375+ likes this.
  7. TTR
    TTR F1 Veteran
    5,880
    Riverside, CA
    Timo
    I imagine for anyone to be able to provide any meaningful advice or suggestions, it would be imperative to know the reason(s) and/or the objective(s) for removal of the engine.
  8. daviekj
    daviekj Formula Junior
    486
