Engine Compartment Cleanliness?? | FerrariChat
Discussion in '308/328' started by Easyrider7467, Jan 16, 2006.
  1. Easyrider7467
    Easyrider7467 Formula Junior
    Nov 3, 2005
    980
    Northen N.J.
    There is a 328 that I'm looking at. Here is the engine compartment. Is there anything to be said about an engine that looks like this? Maybe needs alittle steam or something??
    Also, note the airbox not having "Ferrari" embossed on it? Not unusual? Thanks.
  2. Kingpin328
    Kingpin328 Formula Junior
    Nov 7, 2003
    433
    Can't comment on the engine, looks pretty normal to me.
    For cleanliness' sake though: on the right, there seems te be rust on the metal frame containing the mesh (quite normal, paint peeling of). My mechanic advised me not to get the frame of the hood-frame (riveted), said I'd never get it back on straight. So I just grinded the rust away and aplied zinq-spray + black semi gloss coating. Works for now.
    Good luck on your car-hunt!
  3. steve f
    steve f F1 World Champ
    Mar 15, 2004
    12,119
    12cylinder town
    steve
  4. Bullfighter
    Bullfighter Two Time F1 World Champ Lifetime Rossa Owner
    Jan 26, 2005
    22,601
    Gates Mills, Ohio
    Jon
    It's not uncommon for the Ferrari white lettering to be gone from the airbox... probably was cleaned with something other than water. However, the nicer 328's tend to have it intact.
    Steaming is supposedly not the best thing for gaskets and electrical bits -- I would get it properly detailed as part of a major service at some point.
  5. doug328
    doug328 Formula 3
    Mar 11, 2004
    1,599
    The Space Coast, FL
    Doug B
    Not a whole lot of time or TLC spent on the engine & compartment. Is that an indication of the attention given to the rest of the car?? More important when were the last services done? Given the dirt & grease on the spark plug wires comming out of the rubber cover on the distributer, I would say it's been at least 3 -4 years since any serious work was done on the engine. In it self not a bad thing but expect to do a major service on it soon. More important check the brake fluid, if it's clean then it has been changed within the last 1-2 years so mabe the other fluids were changed as well. If it's dirty then chances are little or no maintenance has been done on the car. Like most everyone else says get a PPI and go from there.
  6. 285ferrari
    285ferrari Two Time F1 World Champ Sponsor
    Sep 11, 2004
    20,962
    MD and NE
    Robbie
    WOW---Steve is that the same motor???
  7. LSU348
    LSU348 Formula 3
    Dec 19, 2003
    1,047
    Sugar Land
    It means nothing. My 308 looked about like that and just made a flawless drive from Houston to Atlanta at the hands of the new owner. If that car has been driven a lot it is likely a superb running machine. Spraying cleaners and steam on it may ruin that.
    I do agree that a good cleaning when it has its next major would be money well spent.
  8. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    try to find some of the engine cleaning how-to threads by DJ (Spasso) - he drives his all the time and you can eat off the engine it's so clean.
  9. steve f
    Mar 15, 2004
    12,119
    12cylinder town
    steve
  10. Easyrider7467
    Nov 3, 2005
    980
    Northen N.J.
    Ok, so it isnt that much of a concern. To my next thread..........
