Engine compartment insulation | FerrariChat
Discussion in 'Technical Q&A' started by Luigient, Jan 29, 2010.
  1. Luigient
    Luigient Rookie
    Oct 7, 2008
    37
    New Zealand
    Lloyd
    On a 1988 328 GTS – the insulation, a foam type, lining in the engine compartment is coming apart. Any recommendations for its replacement, what have others used?
  2. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    You may want to contact Daniel at Ricambi... he may know the answer to your question.
    Send a PM to Jack Russell Racing
  3. mseals
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    oh, you may also want to post in the 308/328 section. Lots of smart guys there.
  4. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #4 eulk328, Jan 29, 2010
    I also have an '88 328GTS and mine was "going bad." I removed all of it. It didn't looked great, seemed to "store" some oil vapor and probably was more fuel for a potential fire than useful for sound deadening.
    I did do a test burn on some of it and it would light on fire albeit not easily.
    Also, I found that after removing it, from the fire wall for example, the underlying red paint reflects more light than than the foam. Makes it a little easier to see and work on things in the engine compartment.
    I can't comment on any increase in cabin noise. It was a long time between removing the foam and driving the car again. I'm sure there is some increase but I usually drive with the top off and have a Tubi so.....
    photo showing firewall sans ugly, dark foam. still needs a nice cleaning one day when the engine is out.
  5. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,361
    Southern New Jersey Shore
    Phil
    I always thought about using Dynamat when the day comes that I need to replace this foam....but I haven't yet. Wondering if anyone else has used this.
    Here's an example: http://www.eastwood.com/dynamat-extreme-bulk-pack.html
    Phil
  6. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Dynamat might be a good product but they have a few too many logos for my taste.
    There are some similar products that are plain and would better suit a non-poser car.
  7. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    The replacement stuff is called Kwool.
  8. bill brooks
    bill brooks F1 Veteran
    6,088
    waynesburg,pa
    bill brooks
    #8 bill brooks, Jan 29, 2010
    kaowool.
    10-4. it's a ceramic, non-asbestos blanket.
    you may be able to score from mcmaster-carr or e-bay.
  9. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    I think we're mixing sound insulating material (foam in the 308/328) with heat insulating material (Kaowool). Different stuff, different purposes.
  10. Luigient
    Luigient Rookie
    Oct 7, 2008
    37
    New Zealand
    Lloyd
    I had looked at the Dynamat stuff and thought it would be good however was put off by all the logos/branding
  11. 412fan
    412fan Karting
    Aug 1, 2005
    150
    Northern Plains
    Apparently Aerogel has become rather more reasonably priced, to where it's beginning to be used in construction too. Might be worth looking into.
    Disclaimer: I have no financial stake in Aerogel or any of the companies linked to below:
    Here are a couple of links:
    http://www.aerogel.com/
    http://www.thermablok.com/index.html
  12. moysiuan
    moysiuan F1 Rookie
    4,253
    Canada
    Pelican Products has the hood insulation foam for the porsche 944. These foam pads are similar to the Ferrari insulation, and I believe they are a foam that is designed to melt and help smother a fire. Not too pricey, the amount needed for the F car isn't that great. Two types, one with a waffle type weave, the other plain like oem.
  13. davem
    davem F1 World Champ
    11,000
    Stepford, Connecticut
    dave m
    My local F dealer had it pretty cheap. No screwing around.
