Engine Control Failure on FF | FerrariChat
Discussion in 'FF/Lusso' started by RickLederman, Feb 2, 2014.
  1. RickLederman
    RickLederman F1 Rookie
    2,837
    Swanton Ohio
    Rick Lederman
    At a little over 31,000 miles I got an engine control failure. The FF continues to run well but will go to the dealer Monday. :( So I put my snow tires on my California today:) since the snow and ice continues here in NW Ohio.
    More news on what is wrong with it when it gets back from MAG.
    Rick
  2. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    alarm stayed on even after a reboot?
    curious to see what it is. they should be able to plug it in and have an idea hopefully pretty quickly.
    hope - and assume - it's something minor. probably only a few FF's worldwide with that mileage so you're a bit of a pioneer in terms of higher-mileage problems.
    We're trying to catch up but you have too much of a lead on us...
  3. Cariad
    Cariad Formula Junior
    Jan 1, 2006
    445
    Any F1 Circuit
    I think you should also have them check the battery. They replaced the original Fiamm brand in mine with a more robust alternative.
  4. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    If the car is running normally and not in limp mode, it is probably a software glitch. These events were SOP on my BMW. And occasionally it would protest if it didn't like the gas but it would go to limp mode to protect the engine.
    Keep us informed.
  5. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    +1. It should take a standard Interstate Eurobattery. I recently replaced the original battery in my wife's F430 as a prophylactic measure.
  6. FFMAC
    FFMAC Formula Junior
    Jul 20, 2012
    397
    Mac
    Good luck Rick, hopefully just an electrical glitch. Happened on mine after a week of ownership! Just needed rebooting.
  7. StickBreitling
    StickBreitling Formula Junior
    Oct 12, 2012
    342
    Had that come up on the day before my car went into annual servicing. Turned out to be a failed air flow solenoid. Was replaced under warranty for free.
    The engine ran fine throughout with no loss in power.
  8. RickLederman
    2,837
    Swanton Ohio
    Rick Lederman
    Thanks all. It went to MAG today. Over the weekend I disconnected the battery to reboot and it still failed after I reprogrammed the date/time. It ran OK, seemed to not be power limited at all although hard to tell on salt covered roads with SottoZero's. Hopefully I will know tomorrow.
    I must say its traction is far better than my California with its SottoZero's although the rears on it are a bit worn :D.
    Rick
  9. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    Limp mode is hard to miss in other cars. You can tell from the throttle response. Let us know what you find out.
  10. RickLederman
    2,837
    Swanton Ohio
    Rick Lederman
    Thermostat failed. There are three in North America so MAG will have one by Wednesday. I'm guessing I will get the FF back by Thursday :). More news at eleven:D. It is interesting because I never saw water or oil temperatures too high nor too low.
    Rick
  11. Lone Wolf
    Lone Wolf Formula 3
    Oct 24, 2006
    1,085
    Highway to Hell
    whats MAG?
    and this all came to light because of the dash warning?
  12. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    Very interesting. The thermostat can fail "open" in which case you will not overheat but could have experienced long warm up times. Or it could fail "closed" which could cause overheating unless you kept air moving through the cooling system at the needed rate. You might ask them if they can tell what position it failed in, for information's sake.
  13. RickLederman
    2,837
    Swanton Ohio
    Rick Lederman
    MAG = Midwestern Auto Group in Dublin Ohio, near Columbus, central Ohio. I am near Toledo, northwest Ohio.
    Yes, after starting the FF it does its engine check thing for 20 or 30 seconds then the Engine Control System Failure appears in large non-flashing letters. After that the engine graphic appears at the bottom of the left display. There were absolutely no other symptoms. Warm up seemed normal, and temps were always in the normal range.
    I'll be getting more details from their Ferrari mechanic. Dan has been great at giving me as much detail as possible because he knows my interest in the engineering behind the scenes.
  14. rmitchell248
    rmitchell248 Formula 3
    May 26, 2013
    1,071
    Nürburg
    Robert
    How's this conning?
    Gesendet von meinem iPhone mit Tapatalk
  15. reflex
    reflex Karting
    Nov 11, 2003
    173
    Brighton U.K
    Hope yore back on the road very soon, they are such an aweseome car!
  16. RickLederman
    2,837
    Swanton Ohio
    Rick Lederman
    #16 RickLederman, Feb 13, 2014
    The thermostat should arrive at the dealer today over a week from Italy! With all of the snow it has been difficult being relegated down to a lowly California :D. The Cali performs well in the snow even though the rear tires are a bit worn but no V12 sound! Hopefully the FF comes home Friday. I will give more details when I hear from the mechanic.
    Looking at Ricambi America http://www.ricambiamerica.com/parts_catalogs.php?M=FE&P=&V=diag&I=114519 the thermostat appears rather complex, priced at $700. And it looks like it allows water to flow throughout the engine bypassing the radiators when it is not up to temperature. Pretty cool compared to any other thermostat I have ever seen that simply blocks all water flow.
    Rick
  17. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    It is even more curious that you didn't notice any issue in temperature behavior. I suppose that it is possible that your ambient temperature and driving speeds were such that the coolant remained at normal temps.
  18. RickLederman
    2,837
    Swanton Ohio
    Rick Lederman
    My FF should be here by noon today. The failure mode actually happened when the engine was cold, in the heated garage cold anyway. So somehow it detected a problem. It seemed to heat up just as quickly as normal, and temps never got higher than normal. Possibly a sensor issue. The good news is in researching it the engineering behind it keeping water flowing even if the engine is still cold is very cool.
    Rick
  19. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    I gather that the dealer is saying that the thermostat did fail... or they will replace the thermostat per Ferrari protocol regardless of whether the fault was real. In any case, the engine was never subjected to thermal stress.
  20. RickLederman
    2,837
    Swanton Ohio
    Rick Lederman
    The thermostat was generating a code for some reason. That code was cleared by the dealer and it immediately failed again. It always failed on startup, not while running down the road. Temperatures (which I always monitor) never strayed away from normal so who knows what failure actually happened within the thermostat but it continued to function normally. They put a new thermostat in it yesterday along with additional coolant and all is well. They also checked the system for air and other things as noted in the repair bill but found nothing and after all of that testing went for the entire thermostat.
    One more time I am VERY happy with the service at Midwestern Auto Group in Dublin Ohio. They not only do the job right but keep me informed on what is going on and details about the job. In a previous life about 50 years ago I did my own engine swaps, transmission swaps and repairs, etc. and remain very interested in the design of the cars that I drive.
    Rick
  21. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    Perfect. In the old days, we would go down the road and overheat when the thermostat stuck closed. So sensors and software are good for something.
    Glad to see that you are on the road again with this remarkable car. :)
