Engine control system failure 488 | Page 2 | FerrariChat
Discussion in '458 Italia/488/F8' started by Wangotango123, Jan 18, 2021.
  1. reisskhan
    reisskhan Karting
    Aug 11, 2017
    81
    #26 reisskhan, Jan 25, 2021
    Heard good thing about all these type of starters that are out there on the market
    Are they still similar to the conventional jump/booster packs or work differently?
    Also the original supplied Ferrari charger supplied with the vehicle doesn't it charge and keep the battery on trickle/condition if its all the same thing lol?
    If so then surely there's no need for the starter as pictured or you on about once the battery starts going weak?
  2. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,314
    AUSTRALIA
    ANGELO
    There are quite a few of these starters , basically up to you. I just wanted a big one. They would have the same function but mine has a lithium battery hence smaller but you can get even smaller.
    Just have it charged and in the car with you. You will need it one day 99.999999% sure you will.
    The factory unit is a conditioner. Barely enough just to keep the voltage.
    Thing is you really dont know when the battery is going weak.
    Im just giving you a heads up like others before gave to me. FYI i have my car on the conditioner 24/7, nearly drive every week end and ive had to use it 6 times.
  3. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,432
    #28 blkdiablo33, Jan 26, 2021
    In case needs a boost is the battery located same area as earlier versions like 430 passenger area ?
  4. MANDALAY
    May 23, 2013
    14,314
    AUSTRALIA
    ANGELO
    Passenger side on the foot rest . You will see a black plastic round bolt to undo and the panel will drop down.
    Familiarize yourself with it and the +ve and -ve posts.
    I only suggested the one picture because its got balls but it has 2 thinks that are a MUST
    1) REVERSE POLARITY PROTECTION.
    2) NO SPARK WHEN CONNECTED.
    blkdiablo33 likes this.
  5. Atlplastic
    Atlplastic Rookie
    Dec 23, 2020
    27
    Robert A Colgrove Jr
    I had a bunch of error messages on my 488 including E/diff
    Put a new battery in then everything is fine
    blkdiablo33, Cigarzman and MANDALAY like this.
  6. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,049
    DFW, Texas
    Tom C
    Which brand is battery did you use?
    T
  7. blkdiablo33
    Jul 12, 2004
    4,432
    what is the group number for the battery and brand you guys go with when time to change
  8. Wangotango123
    Wangotango123 Karting
    Aug 7, 2020
    60
    Rafael olarte
    Just got word from the collection as most of you said battery is the culprit.
    Cigarzman and tomc like this.
  9. reisskhan
    reisskhan Karting
    Aug 11, 2017
    81
    good news in a way
    you going for an O.E battery or aftermarket?
  10. Wangotango123
    Aug 7, 2020
    60
    Rafael olarte
    Letting dealer handle for $800. Rather be able to keep everything documented. Obscene pricing
