Engine control system failure light | FerrariChat
Discussion in '612/599' started by RegW, Apr 12, 2019.
  1. RegW
    RegW Karting
    Aug 8, 2017
    62
    London
    On the highway cruising through Belgium for Easter holidays, suddenly the warning sign went on the dash - all is ruining fine - my guess a sensor that has failed / how urgent is it to go to a dealer to investigate in your view? Many thx!
    Sent from my Moto G (5) Plus using FerrariChat.com mobile app
  2. F612
    F612 Formula Junior
    Feb 5, 2018
    644
    Leeds,AL
    David D. Hood
    My US car did the same thing. Turned out to be oxygen sensors.
    Probably needs repair but on your schedule. I waited almost a year and 3K miles.
    Ferrari of Atlanta charged me $1001 US to replace them.
  3. brogenville
    brogenville Formula 3
    2,312
    Robin
    The warning light is normally indicating that a sensor on the engine has returned an impossible value, indicating that it’s faulty. The ecu will substitute the impossible value for a “safe” one, thus protecting the engine, but likely sacrificing performance. Quite how much performance can vary anywhere from virtually none, to a shed load.
    I think you want to know what’s up. Get yourself a cheap 10 euro code reader. It will at least tell you what the fault is. Could be any one (or more) of hundreds, so it’s fairly pointless trying to speculate on the cause.
  4. icelander47
    icelander47 Karting
    Sep 12, 2012
    142
    Mine just came on tonight in my 612. When I checked the gas cap was basically off. How do I get the light to go away?
  5. 360Marnix
    360Marnix Formula Junior
    Jan 4, 2017
    491
    Holland
    By (let) resetting it. If the gas cap is off you get a check engine light. So put it back and reset the light
    Verstuurd vanaf mijn G3121 met Tapatalk
  6. RegW
    RegW Karting
    Aug 8, 2017
    62
    London
    Thanks to all for your insights! I welcome a suggestion for the fault readers, avoiding pointless visits to the garages.
  7. icelander47
    icelander47 Karting
    Sep 12, 2012
    142
    How do you do that?
    G. Pepper likes this.
  8. George Vosburgh
    George Vosburgh F1 Rookie
    Buy an OBD and then you will know what is happening.
  9. RegW
    RegW Karting
    Aug 8, 2017
    62
    London
    My gas cap doesn't operate with the button inside anymore - so that must be the cause per the previous posts. Let's see if somehow the system will be able to reset that over time - otherwise I know someone who will be pleased to see me again!
  10. 360Marnix
    Jan 4, 2017
    491
    Holland
    Is the fuel door not operating or the gas cap? The fuel door will not cause a check engine light. The gas cap will.
  11. G. Pepper
    G. Pepper Three Time F1 World Champ
    38,749
    Texas/Colorado
    George Pepper
    Disconnect the battery to reset. Some cars like my 360 have a rotary switch for that, so check your manual.
  12. George Vosburgh
    The button inside just opens the gas door, if you have the cap on correctly the message will just go away.
  13. brogenville
    2,312
    Robin
    I’d much rather find out what the code is/was before resetting it. May well be nothing, but why wouldn’t you want to know?
    The engine fault light wasn’t just installed as a decoration.
    Rifledriver and Skidkid like this.
  14. F612
    F612 Formula Junior
    Feb 5, 2018
    644
    Leeds,AL
    David D. Hood
    My OBD never coded but Ferrari of ATL found the O2 sensors were bad.
  15. brogenville
    2,312
    Robin
    Yeah but in this case there is a warning light, so there must be a trouble code stored. Any cheap obd reader will perform the basic function of telling you what the high level trouble code numbers are. If you’re not planning on doing anything complex, just buy a cheap code reader. For the $10 it’ll set you back, it’s a handy thing to have even if it is ultimately limited in functionality.
  16. 599_GTO
    599_GTO Karting
    Mar 7, 2018
    237
    J.S.
    Hi Robin, what budget OBD reader would you recommend? Any specific UK websites? Thanks! Sounds like a must have
  17. George Vosburgh
    Mine is a Foxwell set up for a 599 plug. Seems to work, the directions are more complicated than the unit.
  18. 599_GTO
    599_GTO Karting
    Mar 7, 2018
    237
    J.S.
    Thanks a lot George... will see if I can locate one (and avoid the instructions)!!!
  19. brogenville
    2,312
    Robin
    Thanks to Uncle Sam, you can buy literally any OBD2 scanner, and it will plug into your car over a standard socket, and will pull up any one of the “generic” trouble codes. Doesn’t mater if it’s a 2 quid Chinese cheapo, or a massively expensive Ferrari SD3.
    Reading generic codes is the very bottom of the rung in terms of what functionality you might want. The more you pay, the more functionality you will get- anything from talking to airbag modules, coding in new hardware, setting up clutch engagement points, the list is vast. Unless you’re doing it for a living though, most people won’t use more than the basic reading and resetting of generic fault codes. I’d say it’s an invaluable tool to have at home. I actually keep one of the little Elm327 WiFi dongles you get now that allow you to talk to an app on your phone in each of my cars. They’re under a fiver and work a treat for reading faults and viewing live sensor data.
    FastMev and 599_GTO like this.
  20. 599_GTO
    599_GTO Karting
    Mar 7, 2018
    237
    J.S.
    Love it, thank you Robin... this is extremely helpful and educational! Happy Easter
  21. Rex71
    Rex71 Formula Junior
    Mar 24, 2007
    361
    Jeddah,Saudi Arabia
    Majd B.
    Can some one post a pic of one of those cheap scanners while it is plugged in to the 599 OBD II connector.
    I already have the Bluedriver and the ELM327, but I couldn't connect it yet because the place is very tight and i don't want to make any mistakes.
    Thanks.
  22. RegW
    RegW Karting
    Aug 8, 2017
    62
    London
    I bought an OBD2 scanner - the best rated according to Amazon for the budget- trouble is that I haven't found the plug in my 612 - is it under the dash or in the trunk?
  23. F3RN4ND0
    F3RN4ND0 Karting
    Nov 16, 2015
    214
    Madrid, Spain
    F3RN
    Me too.
    I have Bluedriver but been unable to connect.
  24. RegW
    RegW Karting
    Aug 8, 2017
    62
    London
  25. Rex71
    Mar 24, 2007
    361
    Jeddah,Saudi Arabia
    Majd B.
    Correct, but the Gray plastic bracket surrounding the OBD connector is preventing the scanner from being plugged.
    It seems that an extender is needed , did any one find a solution?
