Engine control system failure | FerrariChat
Discussion in 'California/Portofino/Roma' started by Ars3na1, May 12, 2024.
  1. Ars3na1
    Ars3na1 Rookie
    Mar 20, 2024
    9
    Need advice, my 2010 California has upon starting a low rumbling sound and two failure lights come on- “limited performance of the engine” & engine control system failure”
    Can anyone advice if this is something major and what in anyone’s experience this was and repair costs?? Thank you all
  2. FrancisK
    FrancisK Formula 3
    1,422
    Midwest
    Does it feel bogged down when you give it full throttle?
  3. Sunshine1
    Sunshine1 Two Time F1 World Champ
    25,273
    Miami
    Did you start the car again a few times? Owners have stated that many times the light just goes away after starting cars again (Ferraris are very sensitive, a light does not mean there is something wrong if it goes away after one or several times). Do you have an OBD scanner to have more information and to clear the code (after taking a picture of the dashboard)? If the light/message still comes back and does not go away after all of this, then your Cali would need to be seen by an experienced mechanic.
  4. Ars3na1
    Ars3na1 Rookie
    Mar 20, 2024
    9
    Yes it does just seems like it’s gonna clunk out almost, then after about 5 minutes or so the revs balance out, but the engine light remains, it seems to smooth out after a while of roughness but doesn’t clear
  5. Ars3na1
    Ars3na1 Rookie
    Mar 20, 2024
    9
    Yeh I tried it a few repeated days and it really sounds bad, I will be getting it looked at next week it just has to be transported to my nearest dealer about 3 hours away
  6. Willl
    Willl Karting
    Oct 8, 2022
    145
    Vancouver, WA
    Will
    Please let us know what the dealer has to say.
  7. Ars3na1
    Ars3na1 Rookie
    Mar 20, 2024
    9
    Sure will!!!
    Willl likes this.
  8. teodorjelev
    teodorjelev Rookie
    Aug 25, 2022
    15
    Bulgaria
    Teodor Jelev
    The same goes for Roma, they change the filters and turbines
  9. Ars3na1
    Ars3na1 Rookie
    Mar 20, 2024
    9
    Ok thank you
  10. miamiron
    miamiron Karting
    Sep 3, 2016
    79
    Double check all the piping under the hood are connected and secured
    Had a similiar issue...an intake hose was loose.
  11. Ars3na1
    Ars3na1 Rookie
    Mar 20, 2024
    9
    O
    Ok Thank you!
  12. c928jon
    c928jon Rookie
    May 25, 2010
    42
    Mine was a Maf that failed, intermittent for a while until it failed properly and ran like half the engine had fallen out. I was reading fault codes all the time but nothing maf related until it failed.
