engine coolant flush/clean | FerrariChat
Discussion in '308/328' started by david bentley, Mar 26, 2016.
  1. david bentley
    david bentley Karting
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    Anyone cleaned their cooling system?
    I have read about using citric acid, vinager, hot water heater cleaner...all to remove lime, scale, rust, etc to improve cooling
    No one seems to think Prestone radiator flush does much good!
  2. MNExotics
    MNExotics F1 Rookie
    2,631
    Good Thunder
    Ben Gruenzner
    Can't speak for prestone but make sure you read the label and make sure it is compatible with you cooling system. Also when you refill the system use either RO or distilled water but never tap.
  3. tinterow
    tinterow Formula 3
    Nov 1, 2014
    1,339
    Houston, Tx
    Chaya Tinterow
    I might rethink doing this yourself or better yet...if it ain't broke...don't fix it. I've been working on cars as a hobby for 45 years and if you'll read the threads I have never seen so much hoopla over a simple thing. The bad news is if done incorrectly...worst case scenario...you could burn up your engine. Either have a pro do it or don't do it at all if you're not experienced...opens a whole can of worms that you can read about ad nauseum on thus forum :(
  4. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    bingo
    all manner of debris could be dislodged and damage the impeller in the water pump or foul the thermostat or a hundred other niggling problems
  5. Rifledriver
    37,288
    I agree with the last 2. If it is dirty enough to need it the debris will just clog the passages in the radiator and heater cores.
    Regular changes with the water sources mentioned and Zerex G05 is the best thing you can do.
  6. francisn
    francisn Formula 3
    Apr 18, 2004
    2,017
    Berks, UK
    francis newman
    With a friend I flushed the coolant system on my GT4 back end of last year. We used a commercial radiator cleaning fluid (I could probably find what we used but as in UK might not be same brand for other countries).
    I doubt this had been done on my car for 20 years and the amount of rubbish that came out was incredible. We did two flushes with the fluid then a further flush with pure water (reverse osmosis) before refilling the system with pure water, blue antifreeze and water wetter.
    Have now driven 500 miles since then and all is fine.
  7. francisn
    francisn Formula 3
    Apr 18, 2004
    2,017
    Berks, UK
    francis newman
    Zerex sounds familiar for what I used
