Engine Cover Broken Stay Hinge Ass'y | FerrariChat
Discussion in '308/328' started by swanstr, Sep 3, 2017.
  1. swanstr
    swanstr Rookie
    Mar 1, 2014
    15
    Hi,
    The stay hinge ass'y on my '77 308 GTB broke. The stay moves right when the engine cover is opened, and left when closing.
    The hinge ass'y is the hard plastic piece attached to the under side of the engine cover (bonnet).
    To remove it, I removed the 2 10mm screws, but the plastic part did not come off.
    Is there a trick, or it just needs some force? (which I hesitate to use to avoid damage).
    Any advice is welcomed. Thank you,
    *Check the condition of your engine stay ass'y. If it fails, the engine cover is quite heavy and may cause damage to you or your Ferrari...
  2. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    628
    Massachusetts
    Joe
    The part attached to the rear cover should come off. It is only held on by the two screws. Try gently tapping it side to side and front to back. Tap it on the large rectangular base, not the round part extending down.
    There are three parts to the hinge. What part is broken? Pictures?
  3. Motob
    Motob Formula 3
    Nov 11, 2003
    2,370
    Frederick, Maryland
    Brian Brown
  4. swanstr
    swanstr Rookie
    Mar 1, 2014
    15
    #4 swanstr, Sep 4, 2017
    The part came off easily after a couple of light taps.
    I've inquired to GT Car Parts if the have the part that broke. Their stay-fork would attach to the part that broke (photo attached). Thanks for the tips.
    (1977 308 GTB, 22115)
  5. dflett
    dflett Formula 3
    1,632
    NY
    David
    Hill Engineering make a complete replacement:
    http://www.hillengineering.co.uk/catalog/hood-strut-hinge-assy-p-451.html
    Regards
    David
  6. swanstr
    swanstr Rookie
    Mar 1, 2014
    15
    Ordered, received, installed.
    If only all issues could be addressed so easily...
