Engine cover release broken-512TR | FerrariChat
Discussion in 'Technical Q&A' started by greg512tr, Apr 23, 2004.
  1. greg512tr
    greg512tr Formula Junior
    Feb 19, 2002
    994
    Dallas TX
    Greg B
    My engine cover release lever is inoperable (no cable tension) and I used the emergency release to open it however now it won't latch shut. Has anybody relplaced a broken cable before? Mine might have just come loose. Also, any pointers on how to get the engine cover to latch shut while I am using the emergency cable release?
    l
  2. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,426
    Alabama (was Mich.)
    Jeff
    I'm not sure as I haven't done it myself, but I think the release cable replacement involves some CAREFUL interior dis-assembly. Other than that no big deal. I'm gonna guess that the reason your hood won't latch now is because the emergency cable is binding up a bit due to lack of use....a common thing, and not letting the hood catches return all the way. You may have to physically pull the hood catches back into position by hand, and then shut the hood.
  3. greg512tr
    Feb 19, 2002
    994
    Dallas TX
    Greg B
    You may have to physically pull the hood catches back into position by hand, and then shut the hood.[/QUOTE]
    Thanks. The engine cover hood now shuts. The cable broke right where it connects to the latch and is not visibile. At least I can drive it now but not sure if I want to tackle dissasembling the interior to search for the cable.
  4. Terry
    Terry Formula Junior
    Nov 3, 2003
    250
    Cheshire, UK
    Terry
    I have replaced the emergency cable for the front lid on my Mondial t. It was a simple case of withdrawing the old cable and feeding the new cable through, no trim removal/disassembly was neccessary. I overhauled all the latch mechanisms on my car by removal, cleaning, lubing and reinstalling. I used a bicycle brake cable as the replacement which worked fine.
  5. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,610
    Avvocato
    Mine also broke and I used the emergency one, its a very simple fix and not expensive. Easy to do...follow the cable latch to the interior, took me two hours to fix and the actual new level witch was $72.00CDN (few yrs back).
    Be very carful of the front hood double latch, if that one breaks its a nightmare, and $$$ dont ask how I know.
    Good luck.
