Engine cradle cross member bend or not? | FerrariChat
Discussion in '348/355' started by emailben, Mar 30, 2014.
  1. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    #1 emailben, Mar 30, 2014
    I was reading about where to jack up the car on 348, some thread said the cross member could be bent if jack up from the middle.
    I went to check my car, and it seems it was jacked up from the middle before. I used a 2x4 to see if it was bend. Seems a little bit? What do you think if I should straighten this cross member? or is it just minor and won't hurt the performance or alignment of the car?
  2. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    If its that slight I wouldnt worry about it - just dont make it worse by using it as a jacking point yourself :)
  3. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    Doesn't look bad.
    Kai
  4. MRF40@yahoo.com
    [email protected] Formula Junior
    Jan 1, 2006
    563
    Planet Urf.
    like whut? Ralph??
    ..dont run over somebody who has a 2x4 in their pocket, you should be fine.
  5. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    I guess I am not going to worry about it if it seems minor. Will have alignment check since the car hasn't have alignment done for awhile.
  6. Carbuilder
    Carbuilder Formula Junior
    Aug 18, 2012
    550
    Bolton, ON
    Rick
    I would definitely get it straightened..............the 2x4, not the frame. ;)
  7. S-T48
    S-T48 Formula Junior
    575
    Stevenson Ranch, CA
    All it takes is four bolts and it's out. I would probably straighten it.
  8. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    So, I drove to a local body shop earlier to get some advise, the guy said the car this age probably has some minor flex or bend here and there. As long as the car runs straight, it's not necessary to straighten it.
  9. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,898
    Richmond
    Pete
    If you've ever taken one off of a car, you'd never put a jack on it. They're fairly thin.
  10. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    Ditto. I rarely find a 2x4 without a bit of a bend. But seriously, as others have stated, it doesn't look bad.
  11. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
    I've been jacking mine up for almost 6 years at that spot, still the same as it was the day I got it.
  12. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    #12 emailben, Mar 30, 2014
    Maybe yours has slight bend/flex like mine?
  13. ff355b
    ff355b Karting
    Feb 26, 2010
    218
    Typical 2x4 aren't straight, you should get 72" level and try it again to validate this.
  14. Dino Chang
    Dino Chang Guest
    Dec 29, 2012
    772
    That's true that, there a thin hollow box section. Only held in between the cradle via two bolts at each end. I would never use it as a jacking point.
  15. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,734
    My guess is a motor or transmission mount has expired.
  16. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    I used a leveler and it did show about 3mm bend inward in the middle part of the cross member.
  17. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    I don't think the engine or transmission are mounted on the cross member, so I don't think the mount is broken.
  18. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    937
    Europa
    Bob
    On my 355 it was bent badly where it had been used as a jacking point by someone at some stage.
    I removed the brace but it took some "persuasion" because being bent it went kind of keystone shaped at the flange ends and didn't want to come out easily.
    Anyway, I straightened it out in the vice using a peice of steel tube over the end for leverage. I cleaned it up and sprayed it black and it now looks new.
    It fitted easily and snugly once it was straight.
    I don't think it does much when the car is static, the mounting points didn't move a mm with the car on axle stands.
  19. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    You mean it was easy to install it back?
  20. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    #20 emailben, Apr 1, 2014
  21. dapper
    dapper Formula Junior
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    In my view anyone who uses the mid region of that cross member as a jacking point or axle stand support point evidently has no idea of stress loading/bending moment.
    Occasionally I'm in disbelief at what I see on here. Where will it stop, before we know it there'll be images on here from shortcutters chopping holes in their rear bulkheads to do 'engine in' cambelt changes....ohhh, you say there have been already, there ya go!
  22. ff355b
    ff355b Karting
    Feb 26, 2010
    218
    Interesting, I've never imagined anyone would use the cross member as a jacking point. I was like WTF, how in the hell it got bent? But now I know what could have contributed....
  23. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
    I will take a look in a few days
  24. spaghetti_jet
    Jan 5, 2005
    937
    Europa
    Bob
    Yes, once it was straight it was a snug, but smooth reassembly. No significant force needed to reposition the cross member. Just a rubber mallet to lightly tap into place.
    When I removed it was like a keystone wedged into place.
  25. emailben
    emailben Karting
    Feb 10, 2012
    195
    San Jose, CA
    I sourced a brand new cross member. OEM Ferrari part. It is not completely level and straight. So I think minor bend to the cross member is OK.
