Engine crank during compression test? | FerrariChat
Discussion in 'Boxers/TR/M' started by Otus, Sep 15, 2014.
  1. Otus
    Otus Rookie
    Jul 23, 2013
    25
    Finland
    Ville
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,547
    romano schwabel
    best would be to have 2 more hands
    so ask a friend if he/she can help
    and disconnect the ignition ECU for safety
  3. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,047
    Make sure the throttle is wide open during the test.
  4. Steve Magnusson
    26,840
    You would connect the remote starter switch between the "+12V" battery cable on the large post at the back of the solenoid and terminal 50 on the starter solenoid (terminal 50 is the terminal with the white wire) -- but it needs to be a high-current capable switch as the solenoid current is something like ~10A.
    Also remove the two fuel pump relays (in addition to unplugging the MicroPlex ignition ECU over the LH rear wheel as romano suggested).
  5. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    This is common on a carb'd car - but is it applicable to a FI engine?
    Rgds,
    Vincenzo
  6. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,071
    Troy, Michigan
    James
    I just did this yesteray. I didn't open the throttle though. Basically it builds pressure more slowly. I'm sure my reading were off a bit because of it. I also did it on a warm engine. My readings weren't as "tight" as those in the link, but they seem fine.
  7. Rifledriver
    37,116
    It makes a big difference on some motors and none on others. It is a good rule of thumb unless it is known for sure what the effect is.
  8. Premoto1
    Premoto1 Formula Junior
    Jun 6, 2013
    263
    Cincinnati, Ohio
    Tyler Winslow
    Are you selling the car? Does it run poorly? If the answer is 'no' to both of those questions, you may get an answer you don't want to a question that shouldn't have been asked. I've let curiosity get the better of me on more than one occasion.
  9. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,047
    Vicenzo: Any engine that ingests air must have the throttles open (no restriction) to get an accurate compression test. Closed throttles will give you inaccurate readings from cylinder to cylinder.
  10. turbo-joe
    Apr 6, 2008
    9,547
    romano schwabel
    + 1
  11. Otus
    Otus Rookie
    Jul 23, 2013
    25
    Finland
    Ville
    This was right solution, thanks.
    Yes, I disconnect both ECU and turn throttle full open, also turn metering devices open.
    But I was not able to do test yet, because my compression meter doesn't reach to plug hole close enough. I must make a pipe extension with spark plug thread or something like that...
