Engine deck lid skin removal
Discussion in '360/430' started by Aintqik, Aug 12, 2017.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. Aintqik
    Aintqik Karting
    147
    South Jersey
    RJ Cilurso
    This may sound like an odd question, but has anyone removed the aluminum skin from the rear decklid? It is riveted and bent around the structure, and I'm trying to find some good pics or someone who may have done this. Cheers!
  2. Kevin Rev'n
    Kevin Rev'n F1 Veteran
    Rossa Subscribed Owner
    Nov 29, 2009
    9,628
    Honolulu
    Kevin
  3. vrsurgeon
    vrsurgeon F1 World Champ
    10,604
    Charleston, SC
    Curt
    Why oh why... they intended you to remove the deckled and throw another new part on when the old is bent in an accident. Never going to line up right again. Unless you're adding a wing or body panel...
  4. rizzo308
    rizzo308 Formula 3
    1,822
    perth, australia
    riggio
    #4 rizzo308, Aug 12, 2017
    It's bent round the underside structure u would have to grind the edge of the top skin down 1-2 mm with caution and it may be glue to bott structure also. Is ur top skin toasted. If ur in need of a full lenth fiberglass repo CS deklid I can help u out
    Cheers
  5. Aintqik
    Aintqik Karting
    147
    South Jersey
    RJ Cilurso
    #5 Aintqik, Aug 12, 2017
    Why oh why indeed lol. I do a lot of custom fabrication and I happened upon a CS lid. Not the whole assembly, just the deck.
    I realize this is blasphemy, I've already hand made the nose from a factory Modena bumper (notice the side gills).
    Oh, it all lines up pretty good too believe it or not! It's just sitting there in the pic.
  6. Aintqik
    Aintqik Karting
    147
    South Jersey
    RJ Cilurso
    Besides being bent around it's glued to an inner brace that is riveted to the structure. That can be reshaped and used.
    Really concerned if its panel bonded along the crimps and under the glass. Maybe I can find a used assy like your eBay post.
  7. Tired of seeing this ad? Upgrade now
