Engine detailing | FerrariChat
Engine detailing
Discussion in '360/430' started by Labman, Jan 9, 2015.
  1. Labman
    Labman F1 Rookie
    3,801
    Long Island, NY
    Steve
    Anyone here ever clean their engine? I really talking about the hard to reach valve covers. Mine has a slight layer of dust on it which dulls the red a bit. I try to reach in there with a rag but it's hard to remove due to limited access. Is there any detailing spray available or something?
  2. bball16
    bball16 F1 Rookie
    4,129
    NY LI FtL
    Hey Steve, I've been using Griots engine cleaner. Has worked great with some elbow grease.
  3. sunir
    sunir Formula Junior
    Oct 30, 2014
    758
    MD
    Sunir
    Is there a way to spray some cleaning agent like simplegreen or somethig in there and hose it all down with hot water?
  4. Labman
    Labman F1 Rookie
    3,801
    Long Island, NY
    Steve
    Mike...is it just spray on and wipe off? I'd hate to spray with a hose in there!
  5. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
    On my 360 I've used Dawn dish washing liquid applied and agitated with a 2" paint brush and could reach most areas. I then rinsed it with a hose using low pressure. No issues. The engine compartment does get wet anyway. I would just avoid using a high pressure nozzle so water does not get forced into an area where it should not go.
    Of course.......do all this at your own risk!
  6. Byebye911
    Byebye911 Karting
    May 8, 2014
    70
    Norway
    J.G
    #6 Byebye911, Jan 9, 2015
  7. GaryR
    GaryR Formula 3
    Dec 11, 2006
    1,006
    Valencia, Spain
    Gary R.
    Doesn't water just flow in there through the vents along the window when you wash the car? Is this another "melts when wet area"?
    :D
    Seriously, light flow of water or spray won't hurt, just blow it out with your leafblower to dry it.. then polish stuff.
  8. Byebye911
    Byebye911 Karting
    May 8, 2014
    70
    Norway
    J.G
    Light flow of water from a garden hose is no problem, but i dont like high pressured water all over the engine bay.
  9. Bigilo
    Bigilo Formula Junior
    Sep 28, 2013
    260
    San Antonio, Texas
    #9 Bigilo, Jan 9, 2015
    I wash the entire car with this bucket sprayer and power brush. I wet out the entire car with distilled water followed with the power brush. The brush has a container for soap, I use a few drops of dawn, it is enough for the entire car. I then wash the entire exterior down with more distilled water, usually the entire wash is done with 3 gallons of water total, including extra attention to the wheels and brake dust. The water in Central Texas is very hard and leaves water stains that are very difficult to remove. I will wet out a blue shop rag with distilled water and knock out the engine compartment with a wipe down, it is never too dirty to begin with. I finish up with another shop rag coated with a small amount of Boeing-Shield, it is electrically neutral and was designed for aluminum so I think it is pretty safe to use. I don't dare tell anyone outside of the car culture my extreme ways for fear of being involuntarily committed for "Ferrari Insanity".
  10. bball16
    bball16 F1 Rookie
    4,129
    NY LI FtL
    Spray and wipe off. I'm not hosing down my engine no matter what anyone says.
  11. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    Dawn has detergent and shouldn't be used on your paint. It will strip away the protective waxes and polishes that are on your paint to protect it. Detergent soaps will also leave a residue when dried. If you check the ingredients of specific car wash soaps you will find there are no detergents in it for this reason.
  12. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
    Yep....not using it on the paint.
  13. jzcar
    jzcar Karting
    Mar 23, 2012
    157
    N Florida
    As has been said by a few, be careful how much water you use and how you use it in your engine bay. I had my engine detailed professionally. Apparently, too much water was used, messing up my F1. It immediately began to shift in and out of gear at any speed. It took 3 weeks for a complete dry out and normal shift patterns to return, although the problem began to improve somewhat in about a week.
  14. rmarchjr
    rmarchjr Formula Junior
    May 21, 2012
    586
    North east, USA
    The electrical connectors are not sealed/mil spec and will allow water in, any water will degrade the connector over time. I would not use running water.
    Spray on wipe off, less water better. Ask a challenge car owner how his electrical connectors are doing. CH cars a more susceptible to connector failure as theirs are more exposed then street cars.
  15. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
  16. Labman
    Labman F1 Rookie
    3,801
    Long Island, NY
    Steve
    All very helpful. I'm actually talking specifically about the valve covers that have a layer of dust on them. I would love to spray them with a light stream of water but so afraid of getting any water on the electronics because we all know how finicky there cars can be. I will give the Griot's engine detailer a shot and see if that will work.
  17. dadswrld
    dadswrld Karting
    Jan 4, 2010
    175
    Toronto, Ont
    JR
    You can still spray on your cleaner of choice and use another spray bottle of just water, that way you can control how much gets sprayed in said area, wipe and be done.
    Something like this can be used also, maybe much for some, but very versatile. http://www.detailersdomain.com/Kwazar-Venus-Pro-Compression-Sprayer-1-Liter_p_428.html
    Also keeping a bucket for the purpose of rinsing out your dirty cloth/rag and wiping those areas in the engine will also help.
  18. Cgk360
    Cgk360 Formula Junior
    569
    NJ
    Chris
    Dan, have you used Scrubbing Bubbles on any carbon fiber parts? If so, is it gentle enough to not harm them?
  19. Cgk360
    569
    NJ
    Chris
  20. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    #20 whatheheck, Jan 12, 2015
    Here you go.
    As you all know its not a good idea to get water inside the electrical connectors as it can cause intermittent connection or short circuit so my vote is to cover all electrical connectors with saran wrap prior to washing and detailing the engine bay.
    Carbon Fiber parts are coated with clear coat so its just like a paint job. My experience with scrubbing bubbles is it has no detrimental effect in CF parts.
    I have used Scrubbing Bubbles on my other cars many times and I was always pleased with the results.
    Dont use Gunk engine cleaner as it will stink you car for days.
    Scrubbing bubbles is very good for cleaning grime, grease and very friendly to plastic and painted parts. It makes aluminum very clean and shiny.
    I like to use Lemon scent.
    Kindly share your experience with Scrubbing bubbles should you decide to try my method.
    And yes, its good to use on valve covers, and anything inside the engine bay area. Again, just avoid spraying water directly to any electrical connection.
    Also when rinsing the engine bay after spraying scrubbing bubbles to it use a stream of water, dont use high pressure as we dont want to inject water or moisture to any electrical connections that can get wet.
    Dan
    Hope that helps.
  21. Skidkid
    Skidkid F1 Veteran
    9,538
    Campbell, CA
    John Zornes
    I think that people are a little overly paranoid. Do you people mask off the engine vents when you wash the car?
    I have driven in the rain many times. I have also, on more than one occasion, rinsed the dust and stuff off inside the engine bay using a hose. I didn't spray I just let the water run over things to rinse them off. It isn't all that delicate. Don't use pressure spray but you should be fine.
    Oh yea, I like the scrubbing bubbles idea.
  22. sunir
    Oct 30, 2014
    758
    MD
    Sunir
    Dan I feel like the spirit of the one and only legendary Billy Maze is being channeled through you!! Bam!! Into the matting, into the padding!! You want CLEAN, I got your CLEAN...how about this!!!!??? It's like it was NEVER there! :)
  23. GaryR
    GaryR Formula 3
    Dec 11, 2006
    1,006
    Valencia, Spain
    Gary R.
    Exactly, don't take a pressure washer or a 30 PSI garden hose to it, a light fan spray to rinse it off is no more than will come in the vents parked at a light in the rain..
  24. kommons
    kommons Karting
    Sep 30, 2013
    215
    Silicon Valley, CA
    Chris
    To Dan's point on electrical connections. When you are dealing with inaccessible areas (e.g. engine bay, motorcycle), I always use deionized water. These things are a bit pricey but you don't have to think about masking anything and can comfortably walk away from wet connectors or what not. Using regular tap water once could be enough to leave some residue and bridge an electric connection. The alternator is one of those particularly vulnerable components. You could also use distilled water which is very inexpensive and rinse the engine with that after using your degreaser of choice. Both of these solutions leave no residue whatsoever.
    While rain and other water can get in there, it won't be in the same quantity and location as when you are washing it.
  25. Cgk360
    569
    NJ
    Chris
    Thanks for the help Dan. I'll be in touch after trying it.
    Chris
