engine diagnosis | FerrariChat
engine diagnosis
Discussion in '348/355' started by xtcgt, Nov 20, 2009.
  1. xtcgt
    xtcgt Karting
    Nov 20, 2009
    156
    Toms River NJ
    Robert Boynton
    Hi, I just bought a 348 with a loud knocking noise in the motor on monday. After taking the motor out and taking the intake-valve covers off i first found the exhaust cam on the drivers side of the motor is worn- very tight. after taking that off i a lookin at the head and trying to figure out how to take the 15mm head bolts off?
    I bought the car as a new ferrari owner. I have worked on several porsches in the past and ready and willing to tackle anything that has moving parts.
    I bought the car knowing and hearing the knocking-tapping noise. It had water in the oil. the drivers side compression was 0, the passenger side was about 100. both sides low.
    I initially thought the belt was going to be loose, however its tight.
    My question is, how do you get the head off? i see the bolts, but there under the top of the head.
    secondly, what do you was the problem initially. Blown head gasket.
    I pressurized the cooling system and it was holding for about an hour. I understand heat will affect the head gasket, but would think i should see some loss.
    thankyou for you time.
    Robert
  2. hotrod406
    hotrod406 Formula Junior
    Sep 18, 2007
    540
    Grand rapids area,MI
    Tim
    There's a special tool to get the heads off. I'm sure someone will pop in with a link or you can check out Ricambi.com for it.
    Post up some pictures of the cam if you can. We'd all like to see it and it's good for the archives.
  3. rbellezza
    rbellezza F1 Rookie
    Jun 18, 2008
    2,793
    Henderson, NV
    Roberto Bellezza
    I hope you didn't pay your car too much, scary thoughts working on it knowing that there is coolant in the engine oil ( means past overheating issues ), 0 readings in one head and 100 in another ( valves hopefully and not pistons/rings/cylinders ) Motor parts are very expensive even if you do the job for your self. I hope the problem stays with the heads. I really wish you the best of luck man ...
  4. plugzit
    plugzit F1 Veteran
    7,789
    Redondo Beach, CA
    Bruce Bogart
    Ebay has the headbolt tool for about $40. I highly recommend you subscribe so you can post and see pics, and we'll know who and where you are. There'll be a brotherhood member near you. Good luck and enjoy your car! Wish I'd seen it first!
  5. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Welcome to Ferrari Chat! Hopefully you will be able to drive and enjoy your 348 before too long, but you've got some work to do!
    There's no way to tell at this point what happened first, but you probably have a series of bent exhaust valves on the drivers side, accounting for the 0 compression and possibly accounting for the difficulty in turning the exhaust cam. Even if the timing belt is tight, it has probably jumped several teeth, or stripped several teeth off the belt. If you have an even compression reading of 100 psi on the four cylinders in the passengers bank, it MIGHT just have the cams out of time, but I wouldn't be too confident about it. Cranking the engine over with these symptoms probably wasn't a good idea.
    Of course water in the oil isn't a good sign, pretty likely to be a head gasket issue, but could also be a warped or cracked cylinder head or block. If you're really lucky, it was just condensation, and not a sign of overheating. It's possible. My own 348 had a lot of sludge in the oil tank when I bought it, but after I cleaned it up and changed the oil, it hasn't come back in nearly 10 years.
    What can you tell us about the history on your car?
  6. Ricambi America
    Sponsor Owner
  7. xtcgt
    xtcgt Karting
    Nov 20, 2009
    156
    Toms River NJ
    Robert Boynton
    thanks guys, i am not going to be around today, but i will post pics soon. however i was hoping there was just sludge too. the guy said it sat for a while. also said he put in a clutch spark plug wires and fuel filters--which are the wrong ones they don't tighten around the clamps. actually on the pass side the supply going into the filter was kinked. however that was the side with the 100 psi average reading...so not too concerned. looking in the pass side head the intake valves look ok.
    I found the car on craigslist...advertised with motor problems. spent 20 on the car. i think it was a good deal. everything else works as promissed so far except the windows don't go up and down. lol
    again i will post pics soon.
  8. whyte
    whyte Formula Junior
    Apr 25, 2006
    409
    Merritt Island, FL
    John C
    Welcome to the club!
    You've certainly got us pulling for you, but make sure you stay realistic about your repairs and assess whether your car is really going to be worth repairing. I hate the thought of losing another 348 to the parts bin, but I also don't want to see a new brother be taken to the cleaners trying to get his car on the road!
    As it has already been said, parts for these engines are very, very, very (did I say very?) costly. In my five years of ownership, I've seen several people pick up project cars. Most of these go into the deal knowing that parts are expensive and intending to provide their own labor, only to find out their repair estimates were several factors less than the real costs. Even doing all your own wrenching, repair costs can be staggering, and may quickly approach or exceed the cost of buying a running car in good shape!
    We don't know much about your motor situation yet, but consider that we've seen quite a few engine rebuilds exceed $20,000, and parts alone for a partial rebuild can *easily* hit the $10,000+ range.
    I say this not to dissuade or discourage you, but to ensure you take a realistic look at your project before you get in too deep financially. Sounds like you are well on your way to assessing the damage, which is smart. There are some brilliant Ferrari mechanics on this forum that I'm sure will give you a realistic assessment of your motor requirements once you get down to the pistons and valves.
    If things look promising, you can count on the Brotherhood to help you along the way. There's not a more helpful group on the site!
    If things look bad, don't despair! You definitely have $20,000 worth of parts in your car, probably more, so I doubt you would have much trouble selling it to the Fchat crew or parting it out if things look bleak.
    If you can pull the motor, use a timing wheel, and adjust valves, then picking up a neglected, running car and performing a major may be a better deal for you in the long run.
    Or better yet, pick up ANOTHER 348 with body damage and a good motor! :)
    In any case, good luck and keep us posted!
  9. xtcgt
    xtcgt Karting
    Nov 20, 2009
    156
    Toms River NJ
    Robert Boynton
    well after calling them for the head bolt tool, they said that item was backordered. sweet. Time to make my own! let you guys know once i get the heads off tonight. Talked to someone who has 2 348 heads on a motor at his shop 1200 for the one. I know i am going to need one as the exhaust cam ground in the head. i can't beleive they don't use bearings! talk to you all later
    Robert
  10. plugzit
    plugzit F1 Veteran
    7,789
    Redondo Beach, CA
    Bruce Bogart
    Once you get it apart and estimate the costs, you may want to just buy another motor. These are usually so dependable, the salvagers can't sell them, so you might be able to find a completer for $7-8k. (As a new close personal friend of yours, I'll be glad to haul away your old broken motor.) :)
  11. xtcgt
    xtcgt Karting
    Nov 20, 2009
    156
    Toms River NJ
    Robert Boynton
    #11 xtcgt, Nov 23, 2009
    ok, heads are off. every exhuast valve was bent on the drivers side. explains no compression. passenger head valves look like they aren't bent, but i do see a little wear on the pistons. with that being said its time to figure out a plan. i need a new head on the drivers side as the exhaust cam wore groves in the head. found one 1200. ok need head gaskets 250. complete 30,000 rebuild kit 1400. water pump??? i heard you can rebuild them but then i was talking to someone today and he said yo hav to buy a new one?
    I need a plan.
    I also am concerned about a piston on the number drivers side. 2 one from the front. something punched a litte hole or grove in the bottom of it. i don't need valve damage on the pistons is any concern.
    What do you guys think? i am attaching a picture.
    thankyou
    Robert
  12. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    #12 No Doubt, Nov 23, 2009
    Do yourself a favor by taking off both cats and looking into them for broken-up mesh/catalyst material. It can be sucked backwards up into the motor, and our 348 cats are old!
    Anyway, don't you think that your picture shows a valve impact?
    Here are the valve marks from a broken Jeep motor:
  13. xtcgt
    xtcgt Karting
    Nov 20, 2009
    156
    Toms River NJ
    Robert Boynton
    i miswrote. i meant i don't THINK valve impact on piston is anything to be concerned about. what does concern is the tiny little hole at the bottom of the piston.
    sorry for the confusion
  14. xtcgt
    xtcgt Karting
    Nov 20, 2009
    156
    Toms River NJ
    Robert Boynton
    Also, that is the plan for tommorrow. (taking off cats)
    thankyou
  15. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Can you show a picture of the damage to the cam journal? Chicken and egg. I wonder if maybe the oil pump chain/tensioner broke, then no oil pressure, then exhaust cam seized, then belt skipped, then valves hit pistons.
    Did you find any evidence of holes in the head gasket that may have let coolant into the oil?
  16. xtcgt
    xtcgt Karting
    Nov 20, 2009
    156
    Toms River NJ
    Robert Boynton
    no head gasket failure as far as my eyes can see. my oil pressure guage when i briefly had the motor running was up. but maybe i should check anyway?
    thanks for all the posts.
    Robert
  17. jqpd99
    jqpd99 F1 Rookie
    2,503
    Ottawa
    DFO
  18. foxmul
    foxmul Karting
    Mar 14, 2008
    100
    Millington, NJ
    Joseph Molino
    very nice advice jqpd99!!! I am about to have my timing belts redone in Feb and these are all great things to have done.!!
  19. xtcgt
    xtcgt Karting
    Nov 20, 2009
    156
    Toms River NJ
    Robert Boynton
    #19 xtcgt, Nov 24, 2009
    Ok, got the cats off. drivers side ok- the one with the bent valves. pass side rotted---all kinds of stuff came out of it- remember that was with the psi - 90 to 120. again inspected head gaskets doesn't look like they were leaking. Inspected the that drives the belt and front ring plate is loose. thankyou for sharing your knowledge on that. I wil have to weld the front and back of that gear to assure no further problem.
    Cylinder walls all look ok so i am assuming that there isn't any piston-ring damage( or maybe i am hopefull)
    i am posting pics of the cam wear and the cylinderwear. remember only the exhaust cam on the drivers side wore in the front spot closest to the gear.
    the main belt looks brand new. I didn't get much info from the owner and no receipts but i am thinking that the place installed the new belt wrong. I am hoping that the passenger side low compression is from the belt being off a tooth or 2. hoping. I guess the only way to know is to 1 pull the pistons. or 2 put the heads back on and jump the starter and see what i get. I am opting for number 2 but will a lack of oil in the crank be a problem? hmmm.
    I have not seen any block cracks noticeably. so hopefully condensation. my other consideration is that there was a water leak from the hose going to the water diverter in the heads dripping a little. letting water sit on top of the block, and possibly penatrating through the 3 brass plugs. is that possible? seems like it but i don't want to try to reseal them if you all don't think it is possible.
    thank you for your time in this matter
    Robert!
  20. MaterMech
    MaterMech Formula Junior
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    I think Jeff is on to something here. Better pull the pan and front cover and have a look see at the oil pump chain tensioner. A really good machinist could probably fill weld and bore and then you need the special Ferrari cam ream tool. The cam will clean up with 2000 grit wet sand paper and be none the worse.
  21. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Didn't we have a famous case a while back where someone had installed a camshaft cap backwards (on a 3x8?) and blocked off the oil flow and caused damage like this? Is there any possibility that this could happen on a 348???
  22. xtcgt
    xtcgt Karting
    Nov 20, 2009
    156
    Toms River NJ
    Robert Boynton
    going to pull the front and oil pan tonight. let you know!. Queston of info, if i find a newer motor with 2.7 Motronic and wiring harness minus the computers will it plug and play with my existing computers?
  23. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    If your car is a 1991 model as per your profile, then it has the 2.7 Motronic ECU's. Only the 1989 348's had the 2.5 Motronics.
  24. xtcgt
    xtcgt Karting
    Nov 20, 2009
    156
    Toms River NJ
    Robert Boynton
    my car according to the head is a 1990 also acordding to the sticker on the rear deck lid.
    don't know how to determine is has 2.5 or 2.7 computers? checked the computers no matching numbers.... hmmm
    Everything ok with the oil pump.
    thanks
  25. MaterMech
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    #25 MaterMech, Nov 25, 2009
    Hmmm maybe there is some crunk in the oil galleys that clogged the restrictor pictured at the bottom left. Do the stakes in the aluminum cam plug and the cam line up? What do the other journals look like? Take a picture of your chain tensioner parts. Ferrari went through several revs. but unless it completely grenaded you should still have oil pressure.
