Engine dies | FerrariChat
Engine dies
Discussion in '348/355' started by fxdwgs, May 23, 2007.
  1. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    So here we are again.
    Was out today.....7000 rpm just beauriful.
    Suddenly......like a resistance ......the engine still running clean but without power.
    Next stop the engine just died.....impossible to start again. Only misfires.
    Towed it home and tried to start in third gear clutch up and she starts again and runs clean as long as there are revs enough.
    Still that resistance though
    Now she is home in the garage and refuses to start again.
    Fuel pumps, fuel filter, ignition what can it be?
    //B//
  2. speedy_sam
    speedy_sam F1 Veteran
    Jul 13, 2004
    5,559
    TX
    Sameer
    Did any of the warning lights come?
  3. marco348
    marco348 Karting
    Apr 24, 2006
    53
    Ontario,Canada
    Marco M
    Doesn't sound to good i had a smiler problem with mine. The first thing remove spark plugs and inspect, Then a leak down and compression test well help. I found 2 burnt exhaust valves. Good Luck
  4. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Hard to say from your description but I'd be thinking along the lines of "plugged cats" based on what little info you've given.
  5. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    How do you check the flow through the cats?
    Start taking them off and then try to start obviously but if they are clogged what to do then?
    New ones?
    //B//
  6. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    No lights what so ever.
    //B//
  7. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    Even if a valve or two are burned it should start with the starter, dont you think?
    It runs clean but struggles.
    What about crankshaft ventilation?
    //B//
  8. kingsdare
    kingsdare Karting
    Oct 24, 2006
    132
    California
    David King
    DON'T START THE ENGINE AGAIN!!!
    This could be a sign that your timing belt jumped a couple of notches. Which means you probably didn't do any damage, but will if you keep trying to start it and it jumps a couple more notches.
    This is just a possibility, but don't take any chances until you eliminate this possibility.
  9. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    got to try that one
    engine out or just gastank out?
    //B//
