Engine experts...Whats the consensus on worn cylinder liners? | FerrariChat
Discussion in '348/355' started by James-NZ, Feb 23, 2010.
  1. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    Hamilton, NewZealand
    James
    Worn cylinder liners are a result of;
    Leaking exhaust headers causing bore wash?
    Injector fouling?
    A combo of above?
    Incorrect oil weight?
    No definitive answer, case by case basis?
    I think it is leaking headers that are the primary cause. My basis for this is with a leaking header the o2 sensor will receive an incorrect lean reading for that bank, (as exhaust gas pass the leak it draws air in). Engine management will then increase mixture (rich) till the injectors reach max duty cycle and this will result in bore wash due to the excess fuel washing away the lubricant.
    Am I close or am I miles away?
  2. Rifledriver
    37,288
    #2 Rifledriver, Feb 23, 2010
    O2 sensor operation and fuel trim does not change with a bad header. It is not detectable by any electronic engine parameters.
    We have repaired many 355's with bad injectors. At this point in their lives it is quite common. None have resulted in cylinder wear issues.
  3. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Too much choke ...
    Pete
  4. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    James
    Thanks Brian, I was hoping you would comment.
    In your opnion what is the cause of cylinder liner issues?
    The car in question had been driven for a long time with leaking headers, years and maybe 10,000 miles. Injectors had been cleaned quite some time before the liner issue and injectors have been checked again and needed minimal to no cleaning. Issue came on strong after the headers were fixed. Could be coincidence that the headers were fixed and this problem happened or could they be connected?
    I know it might be hard to diagnose a problem with the patchy information I am able to provide and I appreciate time is valuable so thanks to those who can shed some light on this.
    It is not my car and I now simply have an interest as to what causes this.
  5. Rifledriver
    37,288
    With a bad header the cylinder is ingesting a lot of debris. The flow in the pipe is not one way.
  6. Monteman
    Monteman Formula 3
    2,348
    Santa Barbara, CA
    Monte
    I'm still not 100% clear on this one. Is it the header or is there another common cause for the cylinder liners wearing? I'd love to know if there is something we should/shouldn't be doing to help preserve them?
  7. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,815
    Lake Villa IL
    That's interesting. Most cars I have worked on with a pre o2 exhaust leak will send that bank to max positive fuel trim.
    Is it because the 355 heat shielding seals up well enough so it doesn't pull in much ambient air?
  8. FerrariDeeJay
    FerrariDeeJay Formula Junior
    Jun 2, 2009
    418
    Chino, CA
    Michael
    When my header cracked, the slow down 1-4 light came on and shut down that side of the engine. After the header was repaired, no slow down light, everything functional.
  9. Rifledriver
    37,288
    Don't know, don't care.
    The dealers and the factory tried every possible way to determine electronically if a running problem was caused by a header. We studied parameters on normal cars and sent reams of printouts of those parameters to the factory. In the end no method was found.
  10. Rifledriver
    37,288
    I have replaced or overlooked replacement of hundreds of headers and have never seen that.
  11. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    James
    The top of the piston in the cylinder that failed was clean, like it had been washed with petrol, that would point to bore wash, but from what you are saying Brian, bore wash is unlikely?
    There was no sign of large debris being ingested.
    The cylinders in that bank all show minor wear when compared to the other bank, one cylinder is toast and the rest are within tolerance. Is that common when you see this type of repair?
  12. Monteman
    Monteman Formula 3
    2,348
    Santa Barbara, CA
    Monte
    I was up at Competizione today and brought this subject up. Richard is very cautious with his words and I trust him completely but I left with the impression there may be several factors involved but the primary focus being on the headers. It seems people that get the headers fixed early may not see the problem versus someone that drives their car a long time with a bad header which can greatly accelerate the wear.
    This alone may not help you since the 355 engine is a very complex thing and there are several contributing factors but it was pointed out that cars that had their headers replaced early on after finding a problem with them don't seem to see the problem as quickly or as often as cars that may have header issues over a longer period of time.
    Net, if you know you have a header issue I would recommend parking it until you get it fixed.
  13. Rifledriver
    37,288
    Clean pistons are not caused by fuel washing. Excess fuel causes excess carbon and makes them dirtier. Bad ring sealing allows oil around the circumference and cleans the piston. It is very common in many Italian motors. We used to see it all the time in Alfa 1750 and 2.0 motors.
  14. Rifledriver
    37,288
    All true.
  15. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    James
    Thank you Brian, I should have been able to work that out given it is fairly obvious when you look at a spark plug, black carbon soot means its rich, stands to reason the inside of the cylinder would also be black, so a clean piston would not be a symptom of excess fuel mixture.
  16. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,822
    James
    Thanks Monte, like you I would like to know if there is anyway I can prevent this from happening with my car. All the info we can gather on this will help to get a better understanding of the causes and what we can do to prevent it.
  17. jonp
    jonp Karting
    Jun 24, 2006
    86
    Essex, UK
    Jon
    Unfortunately, I'm no expert by any stretch, but my take from reading around and folks like Brian who are very experienced, is that no-one really seems to know what causes these issues, including the factory. There are obviously causes but no concrete link formed, and that's after a considerable number of rebuilds and thousands of header failures and the like.
    I had to have a rebuild on my 355 due to liner wear, one pot in each bank. Both headers had been replaced, and the issues spotted with those fairly quickly and not run on them etc. One thing I noted prior to any issues, was that sometimes on cold starting it would run rough for 20 seconds or so and quite petrolly. Oil cleaning the pistons is spot on in my case as well, the pistons with worn liners had failing oil rings and the car was using a lot more oil than normal. I just wondered if some petrol wash previously at points could possibly damage the liners/rings, and then you get the oil use and shiny piston syndrome??
    On mine everything electrical/injectors etc was found ok, changed none the less as I really didn't want to face that again and although errors etc weren't found, I'm guessing it's virtually impossible to test everything to simulate 5-10k of motoring. Nothing problematic was ever found though that you could say, yep, that little b#gger caused the prob. Not the most confidence inspiring. The onset symptoms I noticed were very quick to arrive, and started with smell of burning oil when backing off acceleration under braking. 150-200 mls later I think, the engine was in pieces.
  18. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    That would do it. Petrol is a fantastic abrassive.
    Has anybody worked out whether there is a correlation between vehicles with little user versus vehicles that are used as a car?
    Short trips with the computer running the engine rich due to it being cold is a bad thing ... heck with my motorcycle (because it has carbs) pretty much as soon as I can I put the choke in. That is usually within 100 metres or so ... sure its not 100% happy but that is better than washing the bores.
    Pete
  19. PaulK
    PaulK F1 Rookie
    4,801
    Michigan
    Paul
    Would anyone mind telling me what constitutes a bad header? The cracking? Or is it something else?
  20. Monteman
    Monteman Formula 3
    2,348
    Santa Barbara, CA
    Monte
    I am operating under the assumption that it is a hole or crack in the header tube.
  21. FerrariDeeJay
    Jun 2, 2009
    418
    Chino, CA
    Michael
    #21 FerrariDeeJay, Mar 1, 2010
    This is what it looks like! These tubes are from my 1995 355.
  22. PaulK
    PaulK F1 Rookie
    4,801
    Michigan
    Paul
    Wow, thats just insane!
    They all cant get THAT bad, can they?
  23. LamboRaj
    LamboRaj Rookie
    Mar 2, 2010
    7
    You should get an engine conpression test done if you are worried about bore wear. This should be done on a cold and hot engine. Also, it is always worth getting a cylinder pressure test via compressed air, this will show of excessive leak back, (excessive crankcase pressure), past the piston rings and also if the valves/seats are sealing correctly.
    Unfortunately, most exotica's dont get used much and because of that injector clogging from varnish and other by products in the fuel does not help. This can deposit around the injector needle and can cause all sorts of fuelling issues. I have seen many injectors on my injector test rig fail the spray pattern and flow rates because of this.
    Also to note, injectors are a serviceable item, repair kits which include filter strainer, seal and spacers etc are available for most fuel injectors.
    Wrong engine oil can also cause excessive bore wear, oil viscosity is very important as this determines how well the oil will flow at various temperatures. i have also seen some engines fail due to 'sticky' piston rings, this is caused by the oil by products/carbon gumming up in the piston ring groves and makes the rings stick to the piston wall, causing low compression and also wear on the liner.
