Engine Failure on take off. | FerrariChat
Discussion in 'Aviation Chat' started by FERRARI-TECH, May 20, 2013.
  1. FERRARI-TECH
    FERRARI-TECH Formula 3
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
    I think this guy did all he could and handled it pretty well....I think I would still be washing the stains out.
    From Youtube: "Three high definition cameras were mounted to my Beechcraft Bonanza when the engine quit on takeoff from Fairbanks Alaska on July 26th 2012, One was pointed forward, one to the right side, and one to the rear. All three cameras caught the crash as it happened in HD. Both people on board survived with only minor injuries, but the airplane didn't."
    https://www.youtube.com/watch?v=234_naonoH8
  2. Tcar
    Tcar F1 Rookie
    The other plane looked fairly close... In the pattern?
  3. kylec
    kylec F1 Rookie
    3,670
    Orlando
    So, the NTSB was able to run the engine, no problem with the fuel or fuel pump. Did he say he tried to restart the engine?
  4. jcurry
    24,082
    In the past
    Jim
    Not enough time at that altitude. I think he was concentrating on finding a suitable place to land and save his life (and that of his passenger).
  5. rdefabri
    rdefabri Three Time F1 World Champ
    Jun 4, 2008
    33,571
    NJ
    Rich
    That's a masterful piece of piloting there - he didn't extend landing gear as it would be in semi-retracted / extended state...read his notes about why he turned...he was really thinking in a panic situation, well done!
  6. jcurry
    24,082
    In the past
    Jim
    Gear down would have been monumentally worse. Possible flip or rip open the wings and spew gas everywhere.
    1st thing to remember in this situation is save your bacon, the plane is now owned by the insurance company.
  7. Tcar
    Tcar F1 Rookie
    I noticed he said that he left the door shut for structural integrity. Got me thinking about my friend.
    He had that happen w/ his Bonanza; it flipped over when it hit and he wished he'd cracked the door before it hit. He said that's usually recommended. He was alone. The door jammed shut.
    He wasn't nearly that high, though, probably 50 feet or so.
    He ended up having to crawl back and exit through the baggage door. He got a cut on his ear when it hit and he was bleeding like a stuck pig. Ear was the only injury.
  8. Schimpf
    Schimpf Karting
    Jul 20, 2005
    137
    CO
    Schimpf
    That landing sure looked like he slapped the ground a bit hard, assume bc he slowed it to stall speed.
    I was trained to always pop the door open by an ex bush pilot of 7yrs in Honduras.
    Trust his advice from the stories he told
  9. MarkPDX
    MarkPDX F1 World Champ
    Apr 21, 2003
    15,111
    Gulf Coast
    Really depends on the type of aircraft and it usually says somewhere in the flight manual. Some you do want to fix the door open, others not so much. The CT-43 (military 737) said that you should always leave the doors closed in a ditching situation. If it was enough to jam the doors it would rupture the fuselage.
  10. open roads
    open roads F1 Rookie
    Jan 28, 2007
    3,799
    Sarasota, Fl.
    Stan
    A solid landing. A-
  11. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    I think that he did a darn good job of picking something nearly straight ahead and flew the airplane all the way to the landing. It appears that the touch down was on an up-slope and thus made his arrival a bit hard but over all, he did a good job.
  12. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    the main thing about engine out is the airplane needs to be flown to the flare / touch down, many panic and forget about what makes an airplane fly, it's about maintaining control ALL the way to the unintended point of landing...
  13. keelaboosa
    keelaboosa Formula 3
    1,821
    San Marcos, CA
    Andy
  14. norcal2
    norcal2 F1 Veteran
    Sad..I see in the article there were 5 cameras on this plane crash If they were working i wonder if we will see the footage..
  15. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    They say that a good landing in a bad place is better than a bad landing in a good place...
  16. zygomatic
    zygomatic F1 Veteran
    5,063
    Washington, DC
    Chris
    What's the old Bob Hoover aphorism:
    "If you're faced with a forced landing, fly the thing as far into the crash as possible."
    This pilot did a very, very good job
  17. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    My instructor offered the same advice only in a different way, "FLY the airplane! Don't turn yourself into becoming a passenger."
  18. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    ...except for the final instant when the plane ( or car ) will go bump... let go of the wheel and cover up... it will keep from breaking the arms...
  19. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    A friend of mine, when trying to recover from an engine failure on take off in a Champ, lost his little finger that was severed because it was draped over the window sill while his hand was on the throttle. The sliding window slammed shut at impact. His left ankle and leg were shattered because of his pushing on the rudder pedal to stop the spin. He survived with many other injuries but his passenger did not because he had not fastened his seat belt. Another incident caused by trying to turn back to the strip after engine failure with no airspeed and no sense. He had a cleared corn field dead ahead of him when he lost power. I was always admonished by another old pilot friend not to use that "DEAD ahead thing" in his airplane. "Say, right up there, okay?" But it was appropriate in this case.
  20. zygomatic
    5,063
    Washington, DC
    Chris
    Great advice, that.
    My other favorite Hoover-ism runs along those lines: no matter what, keep flying the airplane.
    The story I've been told was that Bob Hoover was asked [possibly by the FAA] about an incident in which he hit a power line and lost 2' off one wing of his P-51. When asked how the plane kept flying / how he got the plane back home, Hoover replied:
    "Nothing said I had to crash."
