engine fans? | FerrariChat
engine fans?
Discussion in '365 GT4 2+2/400/412' started by koisokok, Apr 29, 2007.
  1. koisokok
    koisokok F1 World Champ
    12,182
    nine 0 two one 0
    hi ,on the 400s do both fans come on or only one? its seems that only my right passenger side one turns on while the car is hot but the center one doesnt..is it normal?? or can i make both of them turn on?? any help would be great@@ thxs again, kerim
  2. rickard
    rickard Rookie
    Apr 13, 2007
    38
    toronto canada
    rick impera
    I think both fans should be on . Check your fuses to see if they are blown and then check the connection by giving it a little twist.
  3. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Turn the A/C to "on". Then both should run.
  4. dstacy
    dstacy F1 World Champ
    11,997
    GMT -5 & GMT +1
    Dave
    There are 3 radiator fans. 2 in front of the radiator and one behind it.
    2 should be running when the engine begins to get hot the 3rd runs when the a/c is on.
    When the engine gets very warm all 3 will run.
    If one of your front fans quit (which they are famous for doing) it is a Lucas part from an early XKE and will runn over $200.
