engine finally ready to go back in! | FerrariChat
Discussion in '206/246' started by philt68, Jan 11, 2013.
  1. philt68
    philt68 Formula Junior
    Aug 26, 2008
    969
    new york city
    #1 philt68, Jan 11, 2013
  2. champtc
    champtc Formula Junior
    Apr 18, 2004
    732
    Phil. A few things u may want to consider while its out;
    1) get acorn nuts with stato seal washers for all of the nuts on the sump. Otherwise it will leak and drive u crazy
    2) consider getting the valve covers powder coated...not entirely original but looks great
    3)put one of the new alternator drip protector that nuvolari is selling- a huge pain to fix the alternator
    4) get the linkage at least cad plated on the carbs....do the same for the chain tensioner caps
    5) make sure that they test it on a test bed and look for leaks..insist on wet and dry compression readings
    6) install new water pump and engine mounts
    I am sure that others here have some insights but it looks great (also get all used parts back...pistons rings valves etc)
  3. champtc
    Apr 18, 2004
    732
    Also get 13mm nuts on the headers...Superformance sells em and easier to take off
  4. racerboy9
    racerboy9 F1 Rookie
    2,652
    Phil, I don't see the updated stop screw in your timing chain tensioner. Keeps your timing chain tensioner from loosening up. Look at the tensioner on your Stratos. It has the stop screw. Very easy and worthwhile modification.
  5. philt68
    Aug 26, 2008
    969
    new york city
    thanks for the info guys...!
    btw, where can i get a stop screw?
  6. champtc
    Apr 18, 2004
    732
    Ron at Superformance made me a set. They are pretty simple to do yourself though. I was thinking of this last night- hopefully your guy made a booklet with a ton of pictures showing you what he did to the engine. Also make sure that the drum of the distributor does not have wear spots from the throw out weights on the spindle. If it does they look like round indented impressions & it will screw up your timing. There are threads about this on Fchat but easy to fix. There are just 1000 little things that you can get done while the engine is out...I didnt look but do you have the gear reduction starter in there? you may have installed one in the past...good luck!
  7. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,203
    Norfolk - UK
    Tony
    and make sure you have the mounting brackets fitted correctly, easy to get around the wrong way and a sod to alter when the engine is in, also dont be tempted to fit to much to the engine as you will struggle to get it in!
    Tony
  8. philt68
    Aug 26, 2008
    969
    new york city
    but i was only going to add little LED lights so the engine compartment would glow when i drive at night...
  9. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,865
    Atlanta
    John!
    Hey looks great! Any neat internals this time? Do tell
  10. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,641
    Toronto / SoCal
    Rob C.
    The engine looks really nice and there has been some excellent advice given. Allow me to add that you want to make sure that all of your exhaust shields are trial fitted and in place. This includes the alternator heat shield and the aluminum cup that covers the engine mount.
    As for exhaust nuts I urge you to stay with the copper ones. The brass ones SP sells do not stay tight as nice as the copper ones and you do NOT want to have to tighten the forward manifold nuts when on the car.
    Lastly do consider a D3S Alternator drip saver. Even with everything brand new the tensioner is a bad design and is prone to leak at any time.
  11. VicJano
    VicJano Karting
    Dec 17, 2011
    233
    Kingston upon Thames
    Chris O'Connor
    Sounds great. Where can I get some. I'm think of putting in a modified and chromed E Type rear suspension and lighting that up too!
  12. simonc
    simonc Formula Junior
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
    I second what Tony L has said. Looking at your picture I think the mountings may be upside down and mounted the wrong side of the brackets. Please remember the diagram in the parts manual is wrong. I may be wrong but it has been discussed here before so it may be worth checking.
    Simon
  13. Nickrry
    Nickrry Karting
    Jan 4, 2009
    156
    I'm sure there are plenty of guys out there with more experience than me but having been at this point on two previous occasions I can seriously recommend running it on a stand for a few hours and then re-torquing those heads back down. Yes its a pain taking the cams back out but I got movement on all of the head nuts.
  14. champtc
    Apr 18, 2004
    732
    i just did it on mine & will absolutely second that. I will post a pic of it on the stand. Its the only way to get all the leaks and re-torque the cams. yes it is a huge pain!
  15. racerboy9
    racerboy9 F1 Rookie
    2,652
    You don't even need a stand. I ran mine on the floor. Used a mechanical oil pressure guage. Ran it for a short time to let it heat soak and over all I think I let her run for 7-8 hours at varying rpm. Pulled the covers and checked/adjusted tappet clearance and re-torqued the heads. Re-checked carb balance as well. Did a compression check of all cylinders for base line and to make sure everything was OK. So much easier to do this outside the car. Someone suggested using an oil pig to ensure oil pressure on start-up and that is a great option if available. On mine, just prior to start-up, I put oil in the oil cooler lines and the pressure sender hole. Cranked it over with plugs out and pressure came right up.
