engine ground strap location | FerrariChat
Discussion in '308/328' started by tatcat, Mar 24, 2010.
  1. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    spoke with my electrical guru. he recommended, as did others here, concentrating on the various grounds on the car to solve my starting issue. naturally i did the obvious one first, the battery. now i'm after the engine ground strap. where is it? i'm assuming it's a woven type. i had enough problem finding the starter. i've checked the manuals and the archives. much advice but no directions.
  2. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,395
    Canada
    Newman
    Right rear lower corner of the gearbox to the frame.
  3. 8KRedRacer
    8KRedRacer Karting
    Jun 7, 2007
    196
    Georgetown, KY USA
    Alan Bennett
    Paul is correct on location and it is often covered with engine/transmission fluids (hard to see).
    I remember reading a rice magazine that a high tech set of ground straps (silver connections) throughout the body would provide a three to five HP improvement. Is there any truth to that? The 308 ground straps seem to be pretty good quality.
    Cheers,
    Alan
  4. tatcat
    Sep 3, 2001
    11,013
    rick c
    have you been looking under my car? there was a thread in the archives were the poster said he did get a performance boost on cleaning things up. i'll be happy if the thing just starts.
  5. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Electrically speaking, the engine only needs spark to run. Improving the coils ground would not improve the spark quality, better than 1 ohm ground won't make a measureable difference to the output. So no hp improvement there.
    A magnetti or otherwise control unit doesn't need anything special for a ground. If it runs on a .5 ohm ground, improving to .001 ohms ground is meaningless to the output. It either works well or it doesn't work at all. No in between so no hp improvement there either.
    A super ground questionably helps anything which draws current, starter is #1, and it also helps reduces radio interference. A super ground can help any sensors which don't carry there own ground (poor design). But affect horsepower?, myth busted.
  6. Jdubbya
    Jdubbya The $10 Trillion Man
    42,659
    PNW
    That cable can and does cause starting problems...speaking from experience. I took mine off, cleaned it very well and put it back on. It was in great shape other than it was coated in grease and oil. Solved my problem.
    Till the next one that is! :)
