Engine ignition question | FerrariChat
Discussion in 'Technical Q&A' started by vinuneuro, Aug 6, 2012.
  1. vinuneuro
    vinuneuro F1 Rookie
    May 6, 2007
    2,574
    Chicago
    Vig
    This is not a Ferrari. About 5k miles ago I forgot to ground my plugs/wires while doing a compression test and killed the ignition coil. I guess charge built up in the coil and had no where to go? Friend had an extra used coil which I used since. Recently the coil failed again in the same way as the first one. Resistance in the highlighted circuit is supposed to be 13-20k ohm. First one was 8-9k after failing, this last one was 10k. I've replaced the coil and the car's running again.
    The circuit that failed is the one from the coil to the cap. The other side from the coil goes to the ignition control module (circled red), and resistance on that side was in spec. Since the ICM is grounded can I assume it wouldn't have been damaged? There's no real way to test it with a multi-meter, only continuity checks to determine failure.
    Other question is, if the rest of the ignition system is in good shape can I just chalk this up to a coincidental result of putting in used coil after the first one failed, or should I be suspicious of anything?
    Thanks in advance.
  2. 2NA
    2NA F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Coils fail from a variety of reasons (heat, vibration, age). It is possible that they were coincidences.
  3. smg2
    smg2 F1 World Champ Sponsor
    Apr 1, 2004
    16,440
    Dumpster Fire #31
    SMG
    you really should disconnect the coil when doing a compression test. a coil can fail for a number of reasons, commonly it's heat induced damage that causes the dielectric to breakdown and the secondary windings short internally. the real old ones filled with transformer oil tended to explode.
    without knowing what car and coil type it's hard to state what may be happening on the ECM side. but with most all ECM's the signal is from an op-amp and simply triggers the coil to ground thru a transistor circuit. more than likely there is a diode to protect the ECM. if that went the car wouldn't run.
    I'm not following how the coil failed, was both instances due to running the coil without leads?
  4. vinuneuro
    vinuneuro F1 Rookie
    May 6, 2007
    2,574
    Chicago
    Vig
    The car is 01 Honda Prelude. First coil failed because of my carelessness, second went on it's own.
    Rather than the ECM I'm wondering if the ICM might have also taken any damage?
    I have no idea what type of coil this is.
    Thanks.
