News
Engine insulation
Discussion in 'Mondial' started by stevenwk, Jul 18, 2011.
  1. stevenwk
    stevenwk F1 Veteran
    Apr 12, 2007
    5,222
    Metro Detroit
    Steve
    Need the center square foam insulation pad for my 83 Quattro; not the 2 outer triangular pieces.
    Anybody have a source?
    My current piece just doesn't want to hold on any longer.
    Thanks.
  3. 350HPMondial
    350HPMondial F1 Rookie
    Feb 1, 2002
    4,824
    Edwardo
    #2 350HPMondial, Jul 18, 2011
    Steve,
    It is just black polyurethane foam. I have a whole bunch,,,, cheep, how much do you want.?
    but, fact is, these cars run cooler,,, without the foam.
    This winter, pull your radiator and have it serviced.
    Remove all foam,, prime and paint frame.
    Then, get one of my radiator silicon hose kits, 2 hoses, red or blue.
    PM me.
    Edwardo
  4. stevenwk
    stevenwk F1 Veteran
    Apr 12, 2007
    5,222
    Metro Detroit
    Steve
    #3 stevenwk, Jul 18, 2011
    Thanks Edwardo.
    I just need the center piece. I am just paranoid of the heat killing the paint on the engine bonnet.
    My car runs pretty cool as it is, so not a big deal. Also, what type of adhesive do you use to affix?
    Thanks.
    Will pm you....
  5. jgoodman
    jgoodman F1 Rookie
    2,998
    Central PA
    Jay Goodman
    PM sent
  6. stevenwk
    stevenwk F1 Veteran
    Apr 12, 2007
    5,222
    Metro Detroit
    Steve
    Funny.
    If I wasn't so tired from studying for the California Bar next week I would have laughed too.
    Took a study break last night and saw foam not hanging on too well.
    You would fall over if you knew what a factory piece of foam cost..........
  8. 350HPMondial
    Feb 1, 2002
    4,824
    Edwardo
    #6 350HPMondial, Jul 19, 2011
    Steve and Jay,
    Steve, I believe you want part # 22 in diagram.
    And,
    Jay, I believe you want part # 34.
    Edwardo
    Foam everywhere.
  9. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    There are threads here for the finding. I followed one and got some window a/c foam from Home Depot, cut to size and used upholstery adhesive to stick it into place. The piece between the radiator top and bonnet.
  10. jgoodman
    jgoodman F1 Rookie
    2,998
    Central PA
    Jay Goodman
    34 is the one for me. Thank you.
  11. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,403
    Philly suburbs
    Joe
    I could use one too :)
  13. 350HPMondial
    Feb 1, 2002
    4,824
    Edwardo
    #10 350HPMondial, Jul 19, 2011
  14. maestro8
    maestro8 Formula 3
    2,054
    Nor Cal
    Jason
    I did the exact same thing.
    One year later, looks as good as the day I installed it!
  15. 350HPMondial
    Feb 1, 2002
    4,824
    Edwardo
  16. maestro8
    maestro8 Formula 3
    2,054
    Nor Cal
    Jason
    Are you kidding me?
    $47 for a piece of foam?
    Does it cure cancer or something?
  17. JoeZaff
    JoeZaff F1 Veteran
    Aug 5, 2007
    5,403
    Philly suburbs
    Joe
  18. stevenwk
    stevenwk F1 Veteran
    Apr 12, 2007
    5,222
    Metro Detroit
    Steve
    #15 stevenwk, Aug 1, 2011
    Ok, back from California.....
    I am looking for the insulation center piece that covers the engine; not the radiator insulation covering the radiator.
    Sorry for the confusion.
    There is the center piece which covers the engine, and two outer (triangular shaped) pieces on the engine lid.
    The second photo is the shiny plastic piece (square) that came off the foam piece from the center square. Factory original price is waaaaaay high.
    Here's what I'm talking about............
    Anyone have a ballpark figure on non factory original insulationi?
  19. moysiuan
    moysiuan Formula 3
    2,214
    Canada
    Look on Pelican Parts and order a pad for the 944 hood. A nice waffle pattern, brownish colour like Ferrari OEM, and has fire retardent properties (melts to help extinguish flames).
  20. cockrill
    cockrill Formula 3
    1,077
    Frisco, TX
    Jeremy Cockrill
    I used Dynamat. It's shiny, however, and not the OEM looking gray foam. At the time I didn't really care. Now, however, it's kind of bugging me. (At least I didn't go with the day-glo yellow spark plug wires...)
  21. ukshooter
    ukshooter Rookie
    Jul 5, 2011
    47
    Crowthorne, UK
    Ian Morgan
    I was looking at the dynamat Hoodliner (which has the shiny aluminium top coat but they also do one that is just dark grey with slightly lower temp range, I think 200c instead of 225c. I think I will get some of that for mine.
  22. 350HPMondial
    Feb 1, 2002
    4,824
    Edwardo
    #19 350HPMondial, Aug 6, 2011
    Steve,
    here you go,,, a group buy is needed, for a minimum order is Huge,
    http://www.mcmaster.com/#foam/=di1srs
    Edwardo
    Part number, 1580T4
    In stock for $123.71
    Material Type
    Abrasion-Resistant Fabric-Faced Neoprene Foam Rubber
    Shape
    Sheets, Bars, and Strips
    Backing
    Laminate
    Laminate Material
    Nylon
    Thickness
    .26"
    Thickness Tolerance
    ±0.02"
    Rubber Thickness
    .24"
    Length
    83"
    Length Tolerance
    ±4-1/4"
    Width
    51"
    Width Tolerance
    ±2-1/2"
    Temperature Range
    +15° to +150° F
    Density
    11 lbs./cu. ft.
    Foam Structure
    Closed Cell
    Foam Firmness
    Not Rated
    Firmness, psi
    Not Rated
    Compression Recovery
    Good
    Color
    Black
    Finish
    Smooth
    Tolerance
    Standard
    Specifications Met
    Not Rated
    Properties
    Oil Resistant, Abrasion Resistant, Impact Resistant, Weather Resistant
    Notes
    A layer of black nylon fabric covers each side of the foam.
