Engine issue with 355 challenge | FerrariChat
Discussion in '348/355' started by thibaut, Aug 24, 2022.
  1. thibaut
    thibaut Formula Junior
    Feb 28, 2004
    530
    London, UK
    Thibaut A.
    I have owned my challenge for 8 years. Mostly use it on the road with the odd track. Hasn’t run much ober the past couple of years due to Covid, last engine out service 2 years ago.
    I took it to my mechanic for an oil change. Car was running great beforehand.
    I had to pick it up and, ehile driving back home, quickly realised something was amiss. Car had no power, in neutral, slight press on throttle resulted in rev dropping. Very difficult to rev up. Sometime engine would come back to life for short periods of time. I have the impression one banck isn’t firing.
    I am now waiting for the car to be collected but this will bave to wait as the workshop is full and car is kept in my second home.
    I wanted to pick the brain of the experts as I have tried troubleshooting the issue. The car starts notmally with both CEL coming off 1-2 seconds after start.
    I don’t think it’s fuel supply related as fuel pump and lines were changed as part of last engine out service.
    I immediately thought it may be the ECU relearn as I drove the car stright away and they may had switched off the battery. Did it properly but no improvement.
    I have checked battery voltage, but it on conditioner overnight, no result.
    I have cleaned up the contacts at the 2 engine ECU in the rear wings. No improvement.
    I am now thinking it may be a sensor that failed. They are probably original and I guess eventually they are bound to let go.
    Any thought ?
  2. day355
    day355 F1 Rookie
    Jun 25, 2006
    2,590
    Could be a problem with the coils or spark plugs ?
    taz355 likes this.
  3. Qavion
    Qavion F1 World Champ
    14,349
    Ian Riddell
    Just engine oil? Does your mechanic know how to change oil on Ferraris?
  4. Kokose7en
    Kokose7en Karting
    Dec 5, 2019
    209
    SF Bay Area
    How old is the fuel? Since you don’t drive much
  5. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Fuel is likely not suspect as he mentions "I took it to my mechanic for an oil change. Car was running great beforehand."
    See quite a few of these threads, basic oil change then the car won't run right after for some reason, Perhaps mechanics trying to drive more work back into the shop post oil change. :eek:
  6. thibaut
    Feb 28, 2004
    530
    London, UK
    Thibaut A.
    Thank you for your thoughts:
    Spark plugs were replaced during enfine out service. Not likely to be the issue. Coils: hard to check, I check the ignition box side of the cables but didn’t go as far as removing the cover on the engine to check the coils.
    Fuel has been in for some time but wouldn’t only affect one side of the engine like it seems to be.
    the workshop I use has plenty of work (they had a couple of classic lambos in restoration and a matra V12 70s formula 1 in the shop together with other exotic machinery), I doubt they are just creating issues to get more work. My car is somewhat of a diversion !
  7. Kokose7en
    Kokose7en Karting
    Dec 5, 2019
    209
    SF Bay Area
    I wouldn’t cross out fuel just yet, as I’m talking about water separation from ethanol fuel. As water accumulation will rest on top of the fuel. It could run fine until the fuel level drops.
    high ethanol fuels, high humidity and long sitting periods. It is quite possible.
    I heard the UK now sells E10 when it used to be just E5?
  8. fboutlaw
    fboutlaw Formula Junior
    Dec 3, 2014
    260
    Woodside, CA
    What year is the car? If it's a 2.7, that sounds a bit like 1 ECU not having power.
    taz355 likes this.
  9. INRange
    INRange F1 World Champ
    12,591
    Virginia/Florida/Caymans
    JD
    Did they wash the car or detail it before you picked it up?
  10. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,243
    CT
    John Kreskovsky
    Water goes to the bottom. Additionally, separation in E10 can only occur if the fuel is saturated to start with and then the temperature drops. Other than that the only way to get water in the tank is from condensation.
    Consider that the 5-8 bank crank sensor is mounted on the bottom and not too far from where they would have been working to remove the drain plug.
    Kokose7en likes this.
  11. thibaut
    Feb 28, 2004
    530
    London, UK
    Thibaut A.
    The car is kept in south of france. Very dry and I only fuel with E5 / 98. So less risks than with E10.
    all challenges are 2.7. If one bank ECU wasn’t getting power, wouldn’t I get a CEL ?
    when looking at the car from rear, is 5-8 on the right hand side or left ?
  12. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,450
    Los Angeles
    Are you sure a bank is dead? Very easy to check with a laser thermometer on the headers. If you're certain it's a bank problem then you've significantly winnowed the list of culprits.
  13. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,594
    San Carlos, CA
    Mitchell Le
    If you have a true Challenge car, then it has some extra stuff and does not have some normal 355 stuff. Take anything I say with a grain of salt. Start with ...
    Run the car at idle, use a laser thermometer (get one if you don't have one) to measure the temperature at the exhaust header for each of the cylinder. See which one is not firing.
    Bank 1 is the right bank, bank 2 is the left bank.
    If one whole bank is not running, all the cylinders on that side will be stone cold.
    If it's the whole bank not running, start looking at fuel pressure for that bank, or ignition for that bank, or TDC sensor for that bank.
    If one or two cylinders are not firing, then you have to focus on those cylinders. Since you took the car to a mechanic for an oil change, my guess is you don't want to get your hand dirty at the dead cylinder level. Take it to a shop.
  14. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Yuuup, Sounds like fuel
    I had a pump drop on the track, hit 7000rpms car went flat. Got worse until I could not go past 4000rpms
    Run my pumps out of tank now for easy servicing.
    BTW had this happen on 2 of my 3 challenges
    Car sitting for a while is a pump killer for sure
  15. thibaut
    Feb 28, 2004
    530
    London, UK
    Thibaut A.
    I had the pump replaced 2 years ago. Could it fail after such a short period ?
    Perhaps. Will report when they get the far back.
  16. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    Yes very easy. When they sit they tend to corrode from the bas gas these days, even with that fuel additive sitting kills it. I been replacing fuel pumps in my cars that sit for years for the last 40 years. Cars sitting is the worst thing for them
    taz355 likes this.
  17. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,777
    Lake Villa IL
    I don't see that you mentioned if it's single or dual fuel pump.
    Not sure but would guess Challenge cars followed street cars when 2.7's went from dual to single fuel pump?
    If so and dual pump, of course one pump failing could kill a bank.
    Would say johnk's crank sensor idea is the most likely/logical.
  18. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    504
    Chicago IL
    A fuel pressure guage is quick and telling
  19. thibaut
    Feb 28, 2004
    530
    London, UK
    Thibaut A.
    My challenge has a single pump. It was renewed recently.
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Follow yelcab above and get back too us. All these checks are relatively easy.
    If 1 bank is not running switch the coils from bank 1 to bank two is about all I can add
