Engine Job | FerrariChat
Engine Job
Discussion in '348/355' started by hameednoor, Aug 6, 2015.
  1. hameednoor
    hameednoor Rookie
    Jun 4, 2010
    21
    I have decided to do a valve job on my 1997 355. Change of valves and guides and whatever needs to be changed once opened up. Where to buy parts. Very big difference in price between superperformance and ricambi. Any advice on this would be appreciated.
    Hameed
  2. Shootfighter65
    Shootfighter65 Formula 3
    May 13, 2014
    1,372
    Charleston SC
    Randy..alluneedtokno
    Which is cheaper and is there a quality difference? Going to be an interesting thread
  3. tres55
    tres55 F1 Rookie
    3,572
    Canada
    Piston - TODA RACING
    While you're in there... ;)
    The Japanese YEN to USD conversion is quite favorable right now.
  4. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    #4 2NA, Aug 6, 2015
    You're starting a big and expensive project regardless where you buy the parts. What influenced your decision to open things up?
  5. Qavion
    Qavion F1 World Champ
    14,290
    Ian Riddell
    I'd say it would depend on your country of origin, Hameed. Prices vary according to local taxes, import duties and postage/handling costs. My initial impression of Ricambi (US) is that their basic prices are cheaper, but their postage and handling costs to my country sometimes double the final cost (of smaller parts)
    Regards
    Ian
  6. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,728
    There is a good chance (unlike an american V8) that most of the stuff inside is still perfectly serviceable (excepting the valve guides.)
    When I did mine a couple three years ago, we salvaged the valves, pistons, valve springs but had to replace all of the cylinders, guides, chains, tensioners, bearings,...
    So, wait until its opened up before deciding what to buy.
  7. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    He said he decided to do a valve job, so I assume he did a leak down test and the results were ****. :p
  8. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    Maybe or he could have just been reading up on F chat and realized he HAD to. NOW! :)
  9. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Was only a matter of time. :p
  10. jochem00
    jochem00 Formula Junior
    Jun 19, 2014
    344
    Netherlands
    check the oil pump chain and tensioner!
  11. hameednoor
    hameednoor Rookie
    Jun 4, 2010
    21
    Car would freeze at 2500 rpm. Couldn't accelerate. Don't remember the readings but a couple of cylinders were very low in a pressure test. Plus too much smoke coming out. Plus a rattling noise. Thought I would bite the bullet and open up. Waited for about 6 months to get the $$$ in order before my mechanic opened up. First results out today. Burnt valves. One cylinder was not working at all. That was on one side. Will wait for more results tomorrow.
    Thanks for the tips and the PMs.
  12. hameednoor
    hameednoor Rookie
    Jun 4, 2010
    21
    #12 hameednoor, Oct 17, 2015
  13. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    definitely in need of TLC.
  14. hameednoor
    hameednoor Rookie
    Jun 4, 2010
    21
    Need some expert advice:
    Exhaust Valves :
    Ricambi $338 EACH
    SuperperformanceUK GBP 29 EACH
    Such a big difference. Obviously at 16 nos. the difference in price in significant. Similar differences in intake valves as well as guides.
    Regards
    Hameed
  15. phrogs
    phrogs F1 Veteran
    7,346
    Kzoo Michigan
    I have to say superperformace is not selling the steel guides. Hes selling a Modern acceptable guide to replace the poorly made ones. This is where I found it hard to source off of the steel valve guides No one was carrying all of them when I was shopping.
    they were around $35 each back then. I assume the 338 each from Ricambi is because his stock is low or he is out? you would have to ask him but the price has gone up in the last couple years. No way Id pay that much for each guide.
    13K go on ebay and buy a used motor for less than half that. Might get lucky and the heads are good on it!
  16. hameednoor
    hameednoor Rookie
    Jun 4, 2010
    21
    The price I have mentioned is for the valves not the guides. The guides are 15GBP. The price difference on the valves is simply too high.
  17. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,567
    San Carlos, CA
    Mitchell Le
    I am not paying $338 per valve times 40 valves. No effing way, no how, no where. $13.5K for vaves? Nuts
  18. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    What????
  19. zc911
    zc911 Formula Junior
    Mar 4, 2014
    707
    Brampton, Ontario
    Rob
    Damn right that's just robbery!
    Also check SuperTech valves.
  20. hameednoor
    hameednoor Rookie
    Jun 4, 2010
    21
    Any one use eurospares
  21. phrogs
    phrogs F1 Veteran
    7,346
    Kzoo Michigan
    Yep but ask them.what they are selling don't just go by the part number and think its a ferrari part.
