Engine Lid latch | FerrariChat
Engine Lid latch
Discussion in 'Technical Q&A' started by Dino6304, Aug 15, 2020.
  1. Dino6304
    Dino6304 Formula Junior
    Jul 27, 2020
    537
    CT
    Laurence
    My “new” 360 has a problem
    The engine lid latch opens just fine
    Just won’t fully latch
    It was fine until today
    When I push the latch down with my fingers it almost holds
    Any ideas
  2. Dino6304
    Jul 27, 2020
    537
    CT
    Laurence
    Did fix it
    Took the cover off the latch mechanism, lubed it generously and it works.
    Only problem is that I dropped my 1/4” socket wrench into the engine compartment. Can’t see it but it is likely on the bottom cover.
    I hope that cover can be removed.
  3. Ray Smith
    Ray Smith Formula Junior
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    Use a long flexible magnetic grabber tool. It's sitting on the diffuser or under tray. I have experience.
    Ray
  4. Dino6304
    Jul 27, 2020
    537
    CT
    Laurence
    Hi Ray
    Where to I purchase that tool
    Can you post a pic of it
  5. Ray Smith
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    #5 Ray Smith, Aug 16, 2020
    I got one at Sears years ago. It has a powerful magnetic on the end of a flexible shaft and it has a built in light. It's perfect for finding dropped bolts, washers (non-copper) and tools. I'll post a photo of it tomorrow. I'm sure you can find something similar on Amazon or Harbor Freight. On the Ferrari with the under-trays and diffuser it saves having to unbolt either or both just to recover a part or tool.
    I'm seriously thinking of buying one of those flexible cameras that archeologists use to look into small spaces. I have an LED lost somewhere under the headlights that I have yet to find.
    I just found one on Amazon for $59.98. It has four LEDs and a magnet on the end.
    Vividia 9mm Portable Digital Flexible Inspection Camera with 2.4" color LCD Monitor.
    https://www amazon com/gp/product/B00AIFSSUG/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
    Insert the "dots" where appropriate.
    Ray
  6. Dino6304
    Jul 27, 2020
    537
    CT
    Laurence
    Thanks Ray,
    I can always remove the tray
    Ordered a flexible magnet on amazon
    24” I think
    What and where is the diffuser
  7. Dino6304
    Jul 27, 2020
    537
    CT
    Laurence
    It fell into the right side near the rear of the engine
  8. Dino6304
    Jul 27, 2020
    537
    CT
    Laurence
    Can I drive it?
  9. Dino6304
    Jul 27, 2020
    537
    CT
    Laurence
    Was sitting on the right air cleaner box
    Went over the front of the box
  10. Dino6304
    Jul 27, 2020
    537
    CT
    Laurence
    Ray,
    Any danger in driving it?
  11. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,668
    Honolulu
    Kevin
    It would be best to find it now while you have a bearing on the location. If you drive it might end up someplace else Over the years I have racked up hours wasted trying to find things that have succumbed to gravity in that engine bay! I know all the hiding places now!
  12. Kevin Rev'n
    Nov 29, 2009
    24,668
    Honolulu
    Kevin
    Ah just read where it went. A strong magnet tool and poke it around and I'm sure you'll get it back, plus not knowing if it is in the shift linkage is worry.
  13. Dino6304
    Jul 27, 2020
    537
    CT
    Laurence
    Good advice
    If I had a lift I could remove the bottom cover. I suspect (and hope) that it would just fall out
  14. Ray Smith
    May 17, 2020
    851
    Costa Mesa, CA
    Raymond Smith
    I doubt it, more danger of the item falling out and getting truly lost. The diffuser is the finned under-tray on the back of a 430.
  15. Dino6304
    Jul 27, 2020
    537
    CT
    Laurence
    Thanks,
    At worst I lose a 1/4” ratchet with a 7mm socket. I did order a magnet on a flexible 25” handle and a led lit mirror on a 34” stalk. I’ll find the damn tool!
