430 - Engine light on | FerrariChat
430 Engine light on
Discussion in '360/430' started by kurtflies12, Jul 26, 2022.
  1. kurtflies12
    kurtflies12 Karting
    Aug 13, 2015
    64
    Tx
    My battery was dead so I charged it up overnight. Started and drove fine. Next day started normally but went into neutral from auto by itself. Went to paddle shifters and slipped back into neutral again. It did this a few times then seemed to be ok in auto but the engine light came on. Got it home and did a restart.
    Engine light still on. I’m due for service but it’s a 2.5 hour drive to Dallas. Anything I can do?
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,927
    Central NJ
    Dominick
    Disconnect battery and leave off for 30 mins and then reconnect .. I assume battery is still good ?
    kurtflies12 likes this.
  3. marc996
    marc996 Karting
    May 12, 2019
    66
    marc bethell
    Just replace the battery, these cars are so sensitive its not worth messing with a suspect battery, given its probably the cheapest part on the car to replace.
    kurtflies12 and LorenzoR like this.
  4. LorenzoR
    LorenzoR F1 Rookie
    Replace battery for starters
  5. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    Order one of these from Amazon, so you’ll always have it. You battery is probably a goner.
    Car battery’s don’t recharge to 100% reliably once they are run down to zero. Sometimes a deep cycle battery will, but rarely.
  6. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    Is that a Stearman next to your car? When I was a kid I mopped floors at a hangar at Santa Paula Airport in CA. One of our customers had a Stearman biplane that was spectacular. He took me for a ride in it that I’ll never forget.
  7. kurtflies12
    kurtflies12 Karting
    Aug 13, 2015
    64
    Tx
    Thank you
  8. Snapshift
    Snapshift Formula Junior
    924
    Centralia IL
    Lyle D. Pahnke
    Nice rare Waco or Howard. Needs to be at Osh! BTW Get a code reader and read the codes from the CEL. Get a tender I have had all three, Battery minder, Ctek, and Granite Battery saver. I find the Granite works the best, keeps it at 13.1V fully charged. Start with a good battery and then go from there. Good luck.
  9. colorfull
    colorfull Formula 3
    2,337
    Franklin Park, New Jersey
    John Napoli
    On another note @kurtflies12 , Your car is stunning! I love the color combination
    Rare and beautiful
    Not to mention your amazing aircraft
  10. 430tdf
    430tdf Formula Junior
    Aug 7, 2008
    281
    Canada
    Brett
    I noticed the color too. Is that Grigio Ingrid over Bordeaux? I would love to see more pictures of it.
  11. kurtflies12
    kurtflies12 Karting
    Aug 13, 2015
    64
    Tx
    I use one but had it disconnected for a month:(
  12. kurtflies12
    kurtflies12 Karting
    Aug 13, 2015
    64
    Tx
    I charge the battery and the engine light went out but it still won’t shift out of Auto. Will shift with the paddles both up and down.
  13. kurtflies12
    kurtflies12 Karting
    Aug 13, 2015
    64
    Tx
    I have a load tester.
  14. Scottslaw
    Scottslaw Formula Junior
    Honestly, just replace the battery. As others have noted it’s not worth the second-guessing and constant worrying. Even if you think it’s fine its probably not. As stated above, even if it starts the car it could be weak and cause a host of little issues. Replace the battery and start your diagnosis off on the right foot by ruling out this common culprit. These cars are incredibly sensitive to voltage issues. Good luck!
  15. craze
    craze Formula 3
    Mar 5, 2021
    1,165
    Melbourne
    Michael
    I had 2 ferrari dealer batteries and all cause issues in winter
    I replaced it to an agm battery and in winter still can cause rough idle issues.
    So now i turn on ig, then off, then back on and then start car and it seems to start better
    mainly a winter issue as voltage is lower
  16. marc996
    marc996 Karting
    May 12, 2019
    66
    marc bethell
    Do you always leave connected to a tender when not in use?
  17. craze
    craze Formula 3
    Mar 5, 2021
    1,165
    Melbourne
    Michael
    Yes ctek mks5
