Engine Lite on PLease Help | FerrariChat
Discussion in '360/430' started by CNS, Sep 6, 2008.
  1. CNS
    CNS Rookie
    Apr 28, 2008
    23
    the engine lite in my 360 spider came on for no reason. The car seems to run fine and I checked the gas cap which was on securly. Any sugesstions
    thank you
    chris
  2. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie
    4,684
    LA & OKC
    Kevin
    go to your local autostore and buy an obdii scanner for $60. Plug it into the port and get the code.
    It could be something minor or major, it's better to not take a risk and your scanner can be used on any 96+ car. The best investment you can make!
    Once you get the code, post it here and someone can advise you as to what to do from there but we can't diagnose your car over the internet.
  3. bryanc4
    bryanc4 Formula Junior
    May 22, 2008
    594
    Delray/Boca, FL
    Bryan
    hey bro could you guide the good bro through the process of hoooking up the scanner and what precautions/steps need to be taken for a safe and accurate scanning?
    thanks.
  4. duskybird
    duskybird F1 World Champ
    12,618
    29 Electoral Votes
    Bill B.
    First off it is on for a reason. Like Rosacorsa said buy (my suggestion) borrow or go to Pep boys, Autozone etc and have them scan it. It is extremely easy to do plug it into the OBD II (located under the steering wheel on all OBD II cars delivered in the US) port and follow the on screen instructions.
  5. RossoCorsaItaly
    4,684
    LA & OKC
    Kevin
    There is a port under the steering wheel where you can plug in the OBDII scanner. After that turn your key to the on position and click "read" on the scanner tool, it will come up with code(s). Usually the codes are numbers like P1482 for example. Then you post the code on here or you can look it up and find out what is wrong with your car. 90% of the time, check engine lights are not serious and are from gas caps or just other tedious systems of the car, but it can be serious and you don't want to take a risk.
    You can also as suggested drive the car to a local autostore and have them look up the code for you. But like I said buying the tool is a better idea because it works on any 96+ car and you WILL need it again.
  6. APA#1
    APA#1 Formula 3
    Nov 5, 2003
    1,311
    Central Florida
    Mine was on. Checked it, turned out to be the gas cap. All good, for a while.
    Came back on prior to me selling it. Shelton checked it and smoked the evap system. Turned out to be the rollover valves on the tanks. 2800 later, all fixed. Had to remove the top assembly, rear lid etc.
  7. duskybird
    12,618
    29 Electoral Votes
    Bill B.
    It looks like a "fun" job on a spider!
