i am sure that every body knows that pre 2001 360 had a problem with engine mount bracket cracking. there is a small crack in both brackets in my 360 i am sure there was a detailed how to some where . could some one please post link ? search option did not show it. thanks
I just scanned my TSB's on a CD I have and did not see this one. If someone has it maybe they can load a copy on here or point to a link?
Mine is 2000 Vin serial below 12000. Maybe early 2000 had the same problem. Sent from my SM-G928C using Tapatalk
Just get the new style mounts and put them in. Having a car lift helps along with a small jack. I took more time to remove/replace the rear bumper and under tray than to install the mounts. Easy job, do the search as there is a write up on this.
