engine mount to frame template needed | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by rusty69911, Nov 27, 2016.
  1. rusty69911
    rusty69911 Karting
    Nov 11, 2016
    82
    Albany Australia
    Russ Freer
    Hi all,
    just wondering if anybody here has access to a 400 with the engine out or a bare chassis?
    I would be prepared to paypal beer money for the effort,
    as my car has had the engine mounts cut down to allow the chev to mount I need a template of the original mount side plates so I can fabricate before the v12 gets slotted back in and then weld in the correct location,
    cheers Russ...
  2. rovexienus
    rovexienus Formula Junior
    588
    Sainte Colombe, France (near Lyon)
    Jean-Michel Savary
    I currently have access to two 400i's with engine out, one manual gearbox, one auto gearbox. These two are in France.
  3. rusty69911
    rusty69911 Karting
    Nov 11, 2016
    82
    Albany Australia
    Russ Freer
    any chance you could get a side on picture of it and some dimensions please?
    a cardboard template would be the best but pics with dimensions is obviously the easiest,
    Cheers Russ...
  4. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
    Have you phoned Al? I think one of his has the engine out.
  5. Al Campbell
    Al Campbell Formula Junior
    Nov 22, 2013
    581
    Australia
    All mine still have the engines in but I will see if I can get some decent pictures this afternoon.
  6. rusty69911
    rusty69911 Karting
    Nov 11, 2016
    82
    Albany Australia
    Russ Freer
    cheers guys
  7. rovexienus
    588
    Jean-Michel Savary
    PM sent with request for additional details.
  8. Tojo
    Tojo Formula Junior
    Apr 12, 2002
    499
    Tim
    My engine is out, but I don't expect to be anywhere near the car for a week or so. PM me if you need, and aren't in a rush.
  9. rusty69911
    rusty69911 Karting
    Nov 11, 2016
    82
    Albany Australia
    Russ Freer
    #9 rusty69911, Nov 28, 2016
    ok Gents,
    just to expand a bit I need a good side on pic of this part, this pis is good but I would prefer a more accurate face on not at an angle, which may be hard to do,
    I also need size in mm of all the red lines please,
    cheers Russ,,,
  10. Al Campbell
    Nov 22, 2013
    581
    Australia
    #10 Al Campbell, Nov 29, 2016
    Hi,
    I have added a few measurements to your picture but am missing the inside one. I will raise the hoist up & get this measurement tomorrow - also try & get a cardboard template. The template would make things a lot easier because the oval chassis & angled mount will make the mount hard to replicate otherwise. My mounts look a bit different on the outer edge to the one you have pictured as you can see in my pictures.
    Cheers,
    Al
  11. rusty69911
    rusty69911 Karting
    Nov 11, 2016
    82
    Albany Australia
    Russ Freer
    sweet your a leg end Al, a template would be much better if its not too much trouble,
    the pic is actually a 365 but looked similar and all I could find on the net,
    I will either make a jig the same as the motor to set it up true or sit the motor in but the later is the least preferable as I will need to motor in and motor out to weld correctly them motor back in again
  12. Ferraridoc
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
    How long did you search for that washer before giving up? :)
  13. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,459
    Canada
    Newman
    Ferrparts and Eurospares has parted out enough 400's im sure they would have some brackets you could have cut off a frame
  14. rusty69911
    rusty69911 Karting
    Nov 11, 2016
    82
    Albany Australia
    Russ Freer
    true but looking at their prices they prob want as much for them as I paid for the whole car haha
  15. Newman
    Dec 26, 2001
    14,459
    Canada
    Newman
    Worth a call, beats cobbling something together if it can be had quickly and easily.
  16. rusty69911
    rusty69911 Karting
    Nov 11, 2016
    82
    Albany Australia
    Russ Freer
    I wouldn't consider my fab skills to be cobbling,
    mind you the factory mounts in Als pic look like they were done by my 8yo son haha so pretty sure I can make better looking ones than that,
    you never know the original mounts may be sitting in the bottom of the pile of parts, but I didn't see them when I picked them up the other day,
    I'm about 1500kms from them at the moment so just trying to get info while I'm away at work
  17. Newman
    Dec 26, 2001
    14,459
    Canada
    Newman
    So did the car come with the original engine long since knackered with the chev engine under the hood?
  18. rusty69911
    rusty69911 Karting
    Nov 11, 2016
    82
    Albany Australia
    Russ Freer
    it came with the original engine on a pallet (chev removed)and any other part taken off to allow the chev install,
    the original motor turns over and no oily exhaust ports so I plan on doing a leakdown and compression check, there no hole in the side of the block so hoping it wont take too much to fix, even if its heads they shouldn't be too bigger concern as long as they are not knackered completely,
    I have a machinist mate who can make a lamington out of a **** sandwich so I'm confident we can sort it
  19. rusty69911
    rusty69911 Karting
    Nov 11, 2016
    82
    Albany Australia
    Russ Freer
    #19 rusty69911, Nov 29, 2016
    heres some pics, you can see the mounts are moved back and are lower and flatter than the stock ones, also the front x member has been notched but has been boxed back in and is nicely done, all mods have been done to a high standard, the firewall has had an alloy panel made to allow clearance for the chev headers but this can stay as it looks almost factory to the untrained eye, same goes for the notching of the front x member,
    cheers Russ...
  20. Newman
    Dec 26, 2001
    14,459
    Canada
    Newman
    That's great it wasn't all long gone. Very lucky.
  21. Al Campbell
    Nov 22, 2013
    581
    Australia
    #21 Al Campbell, Nov 29, 2016
  22. rusty69911
    rusty69911 Karting
    Nov 11, 2016
    82
    Albany Australia
    Russ Freer
    cheers Al, much appreciated, that will make it super easy,
    the wonders of the interweb...
