engine mounting fail | FerrariChat
Discussion in 'Technical Q&A' started by vlamgat, Mar 21, 2005.
  1. vlamgat
    vlamgat Formula Junior
    Jan 9, 2004
    776
    Just discovered two failed engine mountings on my 456. What causes this on the V8? Any BTDT experiences out there? On my Audi race car it happens because the torque specs exceed the design capabilities and we overcame the problem by fitting mountings used with engines of greater capacity and torque with a little reengineering. I am not sure this is even possible on the 456 as I doubt the 550 or 575 mountings would fit...or would they?
  2. Rifledriver
    37,335
    The 456 and 550's have been notorious for bad motor mounts. Good thing you caught it, many found out by the sway bar knocking off the oil pressure sender and having the contents of the oil tank pour out onto the pavement with the occasional loss of a motor. Motor mounts for the 550 and 456 are the same and were redesigned a year and change ago. It is starting to look however like the new mounts are only better and not a real fix.
  3. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Why would a part like this fail? Sounds very shoddy but perhaps it isn't.
    Philip
  4. Rifledriver
    37,335
    330-365 era cars motor mounts lasted 20-30 years. I still see originals working fine.
    308 era cars mounts last 10-15 years
    348-355 era cars mounts last 5-10 years
    456-550-360 era cars mounts last 2-3 years
    Are you starting to see a pattern?
  5. judge4re
    judge4re F1 World Champ
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    Yes, and I am even more comfortable in my decision to buy the 365 almost 8 years ago now. :)
  6. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Brian
    How do you tell when they are starting to go or have gone (and how much "flex" is too much?
    I have replaced most of the rubber on my 77 308 - the instrument bezel rubbers come to mind as some that I haven't changed (and yes, the instruments fog with humidity change as a result). Rad hoses et al were done several years ago. The reaction rod bushings were changed this year (you could see they were cracked). My guess is the mounts are next.
    I have "inspected" the motor mounts by pressing on the female-threaded protrusion and seeing how much it will flex under a two palm press (scientific, huh?). Two are tight. Two have a little flex. If I can move by hand (imagine the "Charles Atlas" two handed compression move) is it replacement time yet?
    BTW, it is used almost exclusively on the track.
    Philip
    P.S., any part that fails with any regularity and a 2 - 3 year time interval is poorly designed, whether or not it has a horse badge or not.
  7. Rifledriver
    37,335
    If you have to shim the mounts up to keep the exhaust pipe (or it's heat shielding) on the right side off the frame tube that is usually a sign you need new mounts.
  8. pistole
    pistole Formula Junior
    Jan 31, 2005
    771
    Malaysia
    now I am really worried ...
  9. Rifledriver
    37,335
    Don't be worried, just do like me when something is wrong. ***** and scream at Ferrari to fix it and don't get bent over without making someone pay for it. Don't think for a minute that Ferrari has gone to hydraulic valves and timing chains because THEY wanted to go to the expense. They do respond but they do it like a cat being called to dinner, they make damn sure they leave the impression it was all their idea.
    This thing edited out that word? What are you supposed to call a female dog?
  10. pistole
    Jan 31, 2005
    771
    Malaysia
    a ferrari.
    lol !
  11. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Brian,
    I have a "clunk" when my 308 goes over sharp bumps. Last year I replaced all the suspension bushings and had the shocks rebuilt to fix it and guess what, it didn't fix it. Do you think this kind of thing can be engine mounts? (This has been suggested by someone else). How hard are they to replace? Does the engine have to come out or can it be done in place one at a time?
    Birdman
  12. Rifledriver
    37,335
    Could be. Motor stays in. It can be dirty but it is an easy job if you can stand up while doing it.
  13. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Cool. I'll try it. (I'm spoiled...I have a lift.)
    Birdman
  14. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    OK, I'm looking at the parts diagram...there's a lot of parts in a mount. Which ones do you replace?
    Birdman
  15. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Nevermind, I figured it out.
    Man, those are expensive! $108 each from Ferrari UK! Anyone have a lead on a domestic source? Dennis McCann has them listed at $125.
    Birdman
  16. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    WHEW! And T. Rutlands will be happy to sell them to you for $193 EACH!
  17. vlamgat
    Jan 9, 2004
    776
    Many thanks to all for your comments and suggestions. I guess it went like this -
    Luigi: What are we going to use for motor-mounts on this 456 model?
    Petro: What fits?
    Luigi: Remember those ones we had built for the 400 that we never used when the model was pulled - how about those?
    Petro: Si - makes sense, they are free, all we have to do is get Georgio to copy them. Ask him tonight when you play boule.
    Luigi: The new motor is better, they may not work?
    Petro: Hey anyone paying for these cars cant really expect the whole thing to work all the time. This way we make life interesting, take money out of their pockets so they cant chase too many women and all in all make the world safer by keeing the cars at the dealership being cared for the way we designed them.
    Luigi: ......
    You get the picture!
  18. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    LOL, so very true. it also falls under one of "The Six Laws of Italian Sports Cars." Specifically, number 4
    4)THE LAW OF PERSONAL ABUSE
    "The more an Italian auto breaks down, the more endearing it becomes to its increasingly irrational owner." For example, you purchase an Italian Sports car, for all the money you ever hoped to earn, and receive a ticket for air pollution on the way home from the dealer due to the vast clouds of smoke that follow you. Several return trips to said dealer, accompanied by your rapidly dwindling cash reserves, cures the smoking. But now, the engine sounds like a food processor full of ball-bearings. After replacing every component in the car, including the radio speakers, the noise vanishes and is replaced by an odor reminiscent of a major fire in a goat-hair mattress factory. You still keep trying, G-d help you.
  19. winston
    winston Karting
    Nov 3, 2003
    139
    foothills
    don
    Oh no, I just replaced the motor mounts and rear shocks less than a year ago on my 456m. Now , Brian, you say every two to three years for motor mounts, ugh. How about designing and building some that will last five years so I can have them done along with my timing belts,ouch.
    Winston
    Junebug
    Nigel
    and Don
