Engine mounts 246 and ignition | FerrariChat
Discussion in 'Technical Q&A' started by yakxx21, Nov 27, 2013.
  1. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    I removed the 246 engine brackets wut got them mixed up...now I read they are position specific ..can somebody put me in the picture and advise how they go back.
    Also I want to change the ignition system....the one touted in the UK seems great but very expensive at $ 1900 with Vat.
    Any good alternative ?
  2. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    You might want to post to the 206/246 forum if you don't hear anything here.
  3. simonc
    simonc Formula Junior
    Nov 1, 2003
    884
    Herfordshire, UK
    Simon Campbell
  4. dino clay
    dino clay Karting
    Oct 31, 2007
    185
    san mateo, cal
    clay cavanaugh
    they only fit one way
    clay
  5. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Here is an overview about available ignition systems for the 246:
    http://www.dinoplex.org/overview_dino_ignitions.pdf
    Let me know if you have any questions about this, happy to help!
    Adrian
  6. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
  7. yakxx21
    yakxx21 Karting
    Jun 29, 2013
    230
    Adrian. In your opinion which is the best system if I still use my points .
  8. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    If you want to keep the points setup and (visual) originality is not a concern, then a MSD Digital 6A or MSD 6AL-2 with an MSD Blaster II coil is the best choice. The MSD 6A ignition also has the same CDI principle as the original Dinoplex.
    The MSD ignition can be wired up similar to the original Dinoplex for offering a Normale (Electronic ignition) and Emergenza (Points and coil only if the MSD should fail) mode.
    For an L and early M series Dino, which came with a Dinoplex D/DA, the MSD Digital 6A fits in the original space of the Dinoplex. For late M and E series, the MSD 6AL-2 will fit into the space of the original Dinoplex AEC103A.
    good luck,
    Adrian
