News
Engine not idling
Discussion in 'Boxers/TR/M' started by Guss23, Mar 19, 2021.
  1. Guss23
    Guss23 Karting
    Jun 11, 2017
    76
    Indianapolis
    Jason Sharkey
    I have my 86TR out tonight. Just got it and it’s been sitting for 3 years. Topped it off with some fresh gas and drove it for about 15 or 16 miles. While driving home as I accelerated through 4500 RPM it started surging and cutting out. I figured it was probably bad gas and tried to push through. When I took my foot off the Excelerator the engine died. Now, if I have my foot lightly on the gas it will stay running but it won’t idle. Seems to run perfectly with a little bit of throttle but not at all without
  3. ChipG
    ChipG Formula 3
    May 26, 2011
    1,268
    Santa Monica, CA
    I had a similar issue back in the day, I did have spark for all 12 cylynders, my prob was from old gas (car had sat for a few years), and the gum / debris in the tank clogged up the injectors, I was able to fix it by adding about 4 cans of injector cleaner to a tank that was less than 1/4 full, it took about 20 miles of hard driving to finally clean them out.
  4. Steve Magnusson
    20,292
    Texas
    Are you saying that it runs smoothly when you apply a little bit of throttle, or rather roughly?
  5. Guss23
    Guss23 Karting
    Jun 11, 2017
    76
    Indianapolis
    Jason Sharkey
    Runs smooth when applying a bit of throttle.
  6. Steve Magnusson
    20,292
    Texas
    #5 Steve Magnusson, Mar 20, 2021
    Then first diagnostic steps IMO are:
    1. Put a timing light, or spark tester, on a spark plug wire of each bank (when you've got the engine running) to confirm/deny if spark is reaching the plugs in each bank.
    2. Inspect the fuel pump connections in the horizontal white connectors of the fuse-relay panel -- see post #6 in this thread for where to look (the connector needs to be unplugged to see the damage, if present):
    https://www.ferrarichat.com/forum/threads/left-bank-not-firing-on-testaroosa.637693
    The functional test for each fuel pump (with everything plugged in), is to remove the fuel pump relays and use a jumper wire to connect the female 30 terminal in the relay socket to the 87 terminal in the relay socket (key "off") -- you should hear the corresponding fuel pump "hum" if it is working:
    Good Hunting!
    turbo-joe likes this.
  8. Guss23
    Guss23 Karting
    Jun 11, 2017
    76
    Indianapolis
    Jason Sharkey
    Looks like it’s the right hand fuel pump! Thanks for the help!! Now, How do I change the fuel pump!?
  9. Guss23
    Guss23 Karting
    Jun 11, 2017
    76
    Indianapolis
    Jason Sharkey
    Is there a difference in the fuel pumps between 86 and 87 TR?
  10. Steve Magnusson
    20,292
    Texas
    No. It's a Bosch 69532. If needed, it can be bought on Amazon for ~$160. (I've noted some F part suppliers are using a smaller, incorrect substitute.)
    How did you determine this conclusion?
    PS Be warned that the relay marked "R.H. fuel pump" operates the fuel pump mounted on the RH side of the chassis, but it serves the LH 7-12 bank. Likewise, the relay marked "L.H. fuel pump" operates the fuel pump mounted on the LH side of the chassis, but it serves the RH 1-6 bank.
  11. Guss23
    Guss23 Karting
    Jun 11, 2017
    76
    Indianapolis
    Jason Sharkey
    When I jumped that relay it did nothing. Thanks
  13. Steve Magnusson
    20,292
    Texas
    If the connection in the y white connector is "burned up", this will prevent the fuel pump from working when using the jumper in the relay socket -- did you inspect those connections, too?
    All you know now is that one of the fuel pumps is not working -- you need to determine WHY that fuel pump is not working BEFORE buying a new fuel pump.
  14. Guss23
    Guss23 Karting
    Jun 11, 2017
    76
    Indianapolis
    Jason Sharkey
    The plugs on the y cable were perfect. I think the pump simply failed
  15. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    6,725
    southwest germany
    romano schwabel
    before you change the pump check directly at the pump with an external batterie if this will run or not. may be you have somewhere bad contact?
    fridolin_pt likes this.
  16. Guss23
    Guss23 Karting
    Jun 11, 2017
    76
    Indianapolis
    Jason Sharkey
    Where else could there be a bad connection?
  17. Guss23
    Guss23 Karting
    Jun 11, 2017
    76
    Indianapolis
    Jason Sharkey
    Hooked up the pump directly to the battery. It ran but sounded terrible, like there was gravel in it. I think that is the problem
  18. Steve Magnusson
    20,292
    Texas
    Now that's a test result that I can agree justifies buying a new fuel pump ;).
  19. Guss23
    Guss23 Karting
    Jun 11, 2017
    76
    Indianapolis
    Jason Sharkey
    Thanks guys! Can’t tell you how much I appreciate it!!
