Engine number identification? | FerrariChat
Discussion in 'Technical Q&A' started by MSPV12, Dec 3, 2009.
  1. MSPV12
    MSPV12 Karting
    Jun 18, 2008
    62
    Wisconsin
    Mark
    Hi Folks,
    I am about to purchase a used 456 engine from a reputable UK source. My question for you more knowledgable folk, is can I identify a year of manufacture from the engine number or any casting numbers on the engine. There are several motors available for me to choose from (all stored on pallets) and I would like to confirm the age and buy the youngest engine of the bunch if possible.
    Any advice would be greatly appreciated.
    TIA
  2. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    I image that highest number = youngest motor (but not necessarily lowest mileage of course!)
    That said, I imagine that your Ferrari Network would most likely be able to date any engine by number if you ask.
    The one thing you can be sure of is that any doner engines almost certainly came from a badly crashed vehicle and so you can be pretty confident that they were working perfectly up to that point!
    Good luck with your purchase, hope it works out for you.
  3. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    TIA, personally, I'd look for the engine that looks the cleanest. You want to make sure you're getting an engine from a crashed car, not one that has been in a flood or fire or other non-crash terminal event for the car it was sitting in. An engine that has been exposed to floor or fire is not one that you want. Recyclers will sell major drivetrain components (such as engine/gbox) from flood and fire cars after very cursory inspections, just hoping that the sold parts don't implode right away.
    And generally, the cleaner engines are lower mileage (less miles and time to spring oil leaks and such).
  4. tazandjan
    39,315
    Mark- Cliff is correct. What you want is the lowest mileage 456 engine in the best shape, not the latest engine. The latest engine, by the way, will have the highest engine number, as Cliff stated.
    Be careful not to get a 456M engine if you have a 456. Firing order was different, 1-12-5-8-3-10-6-7-2-11-4-9 for the 456 and 1-7-5-11-3-9-6-12-2-8-4-10 for the 456M. Different ECUs. There were also two different versions of the 456 engine with Motronic 2.7 (94-96) and Motronic 5.2 (96-99) Ignition-Injection ECUs, so you need to ensure your harnesses and ECUs are compatible with whichever engine you choose.
    Get a pro to help you that knows what you can mix and match. Most of us laymen are just blowing in the wind.
    Taz
    Terry Phillips
  5. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,741
    If you have any access to these engines, buy the one with the best leakdown numbers; and ignore the casting/date/mileage....
  6. MSPV12
    MSPV12 Karting
    Jun 18, 2008
    62
    Wisconsin
    Mark
    Thanks for the input guys.
    The one I am most likely to buy is from a '97 car, which suffered very light damage to NSF corner (low down) and along the NS Sill and Door. The engine is very clean and has covered 40,000 miles.
    I will not be using the Ferrari ECU or intake etc, as I am planning on fitting Throttle Bodies and an after-market ECU and loom.
    I will take your advice Mitch and ultimately go with the engine that has the best leak-down numbers.
