engine nuts and bolts - correct plating? | FerrariChat
Discussion in '206/246' started by daviekj, Feb 16, 2009.
  1. daviekj
    daviekj Formula Junior
    486
    While my engine is out and partially stripped I am cleaning up including replacing/replating some of the nuts and bolts. Should the nuts and bolts be zinc and yellow passivated or just sinc? Looking carfully at some of the protected parts of the nuts and studs that i have removed, they look yellow passivated, but not all.
    eg.
    The large bell housing nuts
    the differential casing
    the numerous studs and nuts.
    Kevin
  2. champtc
    champtc Formula Junior
    Apr 18, 2004
    732
    Dave- did you ever hear back on this? I am in the middle of doing the same thing to my engine and am most curious. I have a long list of questions for OMG that I will post in a few days re his restoration. He will know that is for sure. Thanks
  3. daviekj
    486
    Champtc,
    I did not receive a reply. However, after carefully looking at the inside of the orginal nuts and bolts with an eye glass, it was clear that they were zinc plated and yellow passivated. I have had all the studs, wahers and nuts replated in the same way. They look great.
    Kevin
