engine oil pressure gauge (sender trouble?) | FerrariChat
Discussion in '348/355' started by bikz, Jul 7, 2012.
  1. bikz
    bikz Formula 3
    Mar 2, 2012
    1,043
    Malaysia
    #1 bikz, Jul 7, 2012
    guys,
    do the pix below seem to indicate some wiring fault from the sender?
    the gauge was perfectly fine till last night....after a very spirited run..(well if hitting 160-165mph is not, then i'm prob wrong!) the oil pressure gauge this morning went a bit berserk...
    so in www.my348.com , it says that to get access to the sender, get the oil filter out....then what? is it just there behind the filter?
    ps: had a friend who with his dad had a 355spider, currently has a 360spider and a 550......never had been in a 348 and he kept saying 'f*ck the world', "f*ck me" and a few other profanities here and there a bit too many times while in the passenger seat.....got down and said..... "a Ferrari is a f**king Ferrari".....so the story is, he was told to stay clear away from the 348 when he was in for his first F-car many years back and guess what.....well i think his profanities speak pretty much for itself (unless he was cursing the way i drove...ahaha)
    anyway, the pix below....first at about idle and the other at about 2000rpm..cheers.
  2. Shaide
    Shaide Formula Junior
    613
    Las Colinas, DFW TX
    Jason
    #2 Shaide, Jul 8, 2012
    It's right above the oil filter. Look for this thing...
    I know that it's a bit out of context when removed from the car, but maybe this helps:
  3. Shaide
    613
    Las Colinas, DFW TX
    Jason
    #3 Shaide, Jul 8, 2012
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,744
    Could be the sender, or it could be a ground strap to the engine.
    Bertil likes this.
  5. bikz
    bikz Formula 3
    Mar 2, 2012
    1,043
    Malaysia
    ok ill first get the wiring checked and next see if grounding could be the problem......thanks for pointing out where the sender's exactly located.....cheers
  6. Jasonberkeley
    Jasonberkeley Formula 3
    1,348
    NW Corner, CT
    Anybody ever find a solution to this problem? It has started on my car as well. The TSB referencing the ground strap to the oil tank seems to be specific to the oil temp gauge and not oil pressure.
    Any suggestions?
  7. Qavion
    Qavion F1 World Champ
    14,538
    Ian Riddell
    High pressure usually means low resistance. Is your oil pressure wiring shorting out to something?
    Are the other instruments behaving normally?
  8. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    From my experience, sending unit. Gage would work ok sometimes then show max oil pressure. Replaced sender and all was fine.
    Jasonberkeley likes this.
  9. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    While your in there the 2 blue temp sensors are on the manifold are easy to replace too.
  10. m.stojanovic
    m.stojanovic F1 Rookie
    3,300
    Serbia - Niš
    Miroljub Stojanovic
    VDO oil pressure senders have high resistance at high pressure. If the sender is disconnected (resistance = ∞), the gauge will peg to the right. The too high reading on the gauge could mean the gauge going bad, bad sensor or the wire connection to it, or sensor's path to the ground, has developed some resistance.
    Jasonberkeley and Qavion like this.
  11. bayferrari
    bayferrari Karting
    95
    Bay Area
    William
    I had one of the 2 wires to the sensor become disconnected. Oil pressure gauge was off the chart. Crimped on a new connector and ever since then it is fine. Also have a ground wire running from the bottom of the remote oil filler tank to ground. I guess some one before me had a problem with the sender ground..
  12. Qavion
    14,538
    Ian Riddell
    Thanks for the correction, Miro. :oops:
    Not sure where I got my information from.
  13. Qavion
    14,538
    Ian Riddell
    ... and I confirmed this on my own car a few moments ago. I think someone on the 360 forum said the opposite, but the setup on the 360 is the same as the 348 and 355.
    Fuel and temperature are opposite.
  14. Qavion
    14,538
    Ian Riddell
    The oil pressure sender uses the engine block as a path to earth. There is a ground strap from engine block to the chassis. Since a lot of the engine electronics uses the same earth path, it's less likely to be an earth strap problem (unless you are experiencing other problems).
  15. Jasonberkeley
    1,348
    NW Corner, CT
    Hi- yes, everything else is working normally!
    Qavion likes this.
  16. Qavion
    14,538
    Ian Riddell
    So basically make sure the sender connections are not dirty or hanging on by a single strand of wire. Assuming that's ok, it's up to you if you want to go straight into part replacement or pulling the car to pieces for further wiring checks.
    Are we talking about a 355 or 348? If a 348, there's that notorious connector foward of the LH rear strut.
  17. Jasonberkeley
    1,348
    NW Corner, CT
    348.
  18. m.stojanovic
    3,300
    Serbia - Niš
    Miroljub Stojanovic
    Good idea to check there, Pin 3 for the oil pressure sender.
  19. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,808
    Seattle, WA
    Brian White
    If it ends up being the gauge, I have a replacement for sale in the classifieds.
  20. Jasonberkeley
    1,348
    NW Corner, CT
    Thanks guys! Will check further this weekend.
  21. Jasonberkeley
    1,348
    NW Corner, CT
    Sender replaced and has solved the problem. Thanks for all of the feedback and assistance!
  22. johnk...
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    Of course it was the sender. Occam's Razor.
  23. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
