Engine out for 360 belt service? | FerrariChat
Discussion in '360/430' started by jtucker, Jun 29, 2011.
  1. jtucker
    jtucker Rookie
    May 16, 2011
    28
    I am looking at a 2004 360 coupe with 8,400 miles that is due for a belt service, which the seller will pay for. Is there any reason at all to take the engine out for a 360 belt service, or does removing the access panel from the cockpit provide all the access necessary to do the job properly?
  2. big_luke
    big_luke Karting
    Aug 28, 2010
    151
    the 360 belt's can be done with the engine in the vehicle. No need to pull to replace the belts. Some dealerships will pull the engine to do the job I've heard.
  3. HH11
    HH11 F1 Rookie
    3,341
    The access panel on the 360 is the reason it's much easier to do the belt change. No engine out.
    Do a 360 timing belt search. You will find more than you could imagine, good and bad.
  4. Rock-46
    Rock-46 Karting
    Jun 3, 2010
    77
    Slovenia-Europa
    Rok Pogačnik
    Yes, engine is inside :) Just remove seats, nad panel behind the seats, and you can work like king :) it's more then enough space to do it :)
    Rock
  5. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
  6. Testacojones
    Testacojones F1 Veteran
    Nov 3, 2003
    5,198
    Florida
    Luix Lecusay
    Yes, there is a reason to remove the engine to change the timing belts and the reason is for ripping you off, lol.
    The reason why there's a removable panel behind the seat is exactly to perform belt changes.
  7. Rock-46
    Rock-46 Karting
    Jun 3, 2010
    77
    Slovenia-Europa
    Rok Pogačnik
    Sorry for my stupid english :)
    I mean, that there is a lot of space to do job, when you remove the panel behind the seats.
    Rock
  8. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    You have to remove the seats, too. Then plenty of room to do the belt change, or so I'm told.
  9. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    8400 miles seems low for a 2006. My 2002 just cracked 18k.
    You do not have to take the engine out.
  10. HH11
    HH11 F1 Rookie
    3,341
    It's an 04 if that makes it better.
  11. jtucker
    jtucker Rookie
    May 16, 2011
    28
    9,000 miles and counting now! Yes, it's a 2004 and I purchased it last week with 8,400 miles. The last belt service was in 2007, so it's time. Dropped it off at Boardwalk Ferrari in Dallas this morning. Thanks for all the help. My first Ferrari!
