Engine out "manual" | FerrariChat
Engine out "manual"
Discussion in '348/355' started by fxdwgs, Oct 3, 2009.
  1. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    Since I will try this winter to pull the engine, I wonder if there is an engine out "step by step manual" same as Ernie made for the gear box out? ( which by the way worked perfect when I pulled the gear box last winter).
    Would be great to have......less sleepless nights in any case......
    //B//
  2. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Hi Bengt, excuse me if my memory is poor, but you have a 348, right? If you go to www.my348.com, and scroll down a little ways to the table of contents, there's a link to 'Engine Removal' that takes you to a procedure for engine removal. I think there are also some threads on Fchat that have discussed it, so you may try a search. Hope this is what you're after.
  3. PAP 348
    Dec 10, 2005
    100,234
    Mount Isa, Australia
    Pap
    I think Ernie also came up with the "Engine Removal" procedure didnt he? :D:D
  4. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Yes Pap! :) The first (long) procedure on my348.com that I referred to is called "Ernie's famous 2-jack method". Didn't recall that when I mentioned it. Thanks Ernie ... for this and a whole lot of other Brotherhood stuff!!
  5. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    "my348.com" will have a visitor
    //B//
  6. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
  7. PAP 348
    Dec 10, 2005
    100,234
    Pap
    Mine is over 6 yrs now!! :eek::eek:
    Wanna do mine the same time you do yours Ernie?? :eek::eek:
  8. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    #8 ernie, Oct 4, 2009
    Fly me out and feed me, and we'll do it.
    But common Pap, after wrenching on the behemoths you work on the 348 should be a snap.
  9. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
  10. PAP 348
    Dec 10, 2005
    100,234
    Pap
    Yeah, will be a breeze! :D:D
    Will do it later this year or next year sometime. Pappy got too much going on all the time. :eek::eek:
