348 - Engine out service please help | FerrariChat
348 Engine out service please help
Discussion in '348/355' started by FAT378, Jul 17, 2023.
  1. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    Hi everyone
    Just in the process of an engine out service so thought it would be a good time to refurbish the oil tank on my 94 GTS as it is starting to peel
    Just wondering what product people use for this to be as close to factory as possible? Is it just VHT wrinkle finish or powder coat?
    Also, the belt tensioner pulley’s were changed on its last engine out service which was 4 1/2 years ago however the car has only done 3000 km’s since so are they fine to continue using or do they need to be changed with every belt?
    Any other advice would be greatly appreciated
  2. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    756
    Vermont
    john truskowski
    Not too sure about the oil tank, but as for your tensioner pullies I would definitely replace them they are cheap insurance. I think the general thoughts relating to the tensioners is that they get replaced every other belt. I know it seems like way overkill when compared to other cars that go for 10 years and 100k miles between belts, but if you start questioning timing belts on here you had better invest in some asbestos clothing. ;)
  3. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    If they are OEM replace them as part of the major service. Powder coat for tank in satin black is what I would do.
  4. Rifledriver
    37,086
    I think more to the point unless he has more complete information they should be changed to be certain that quality parts are being used. There are more junk bearings out there than quality. If they were a known good quality, that would be worth discussion.
  5. WATSON
    23,679
    WI
    I powder coated my 355 tank in a krinkle black. It needs to be full stripped. If they want to bead blast it, make sure it is completely sealed up before they start.
    The tanks were painted form the factory so that's an option as well.
    Unless you know the history and make of the bearings, they should be swapped with proper ones. I used Hill Engineering on my 355. Other options exist.
    The same holds true for the tensioners. Unless you know the age, might be best to get a new baseline and install new ones. Kind of suck to have an unknown aged tensioner fail with the fancy new bearing in place.
    Stripping the tank is a fun job.....smells great too. hahahaha
  6. A348W
    A348W Formula 3
    Jun 28, 2017
    1,846
    North Wiltshire, UK
    as above, powder coat in satin black wrinkle.
    as to tensioners; as they say, whilst your there!!
  7. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    Thanks for everyone’s replies so far
    Only proof I have on the tensioners is the receipt from Ferrari Gold Coast saying they were changed in October 2018 however not sure what brand the replaced them with
    This is what they look like now, not sure if anyone can pick what brand they are?
  8. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    wow I would have been tempted to just polish that tank after how good of a job you did stripping it lol
  9. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    OEM.
    FAT378 likes this.
  10. John Glen
    John Glen Formula Junior
    Dec 30, 2009
    494
    Victoria, B.C, Can.
    John Glen Wesanko
    VHT wrinkle paint works great the same as the red for cam covers. The trick to add longevity is to apply a quality epoxy primer to the fresh prepped aluminum prior to applying the wrinkle paint. This prevents the finish from "lifting" over time and heat cycles due to corrosion and poor bonding.
    FAT378 likes this.
  11. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    Decision made I’ve added PT-348 kit and a tensioner spring to my shopping cart. I’ll feel better knowing it’s all new
    jjtjr likes this.
  12. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    The OEM ones can be questionable even new. Thier life seems reported as short. The Hill ones are a different league of quality.
    FAT378 likes this.
  13. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    Now for the water pump, mine seems to be the original one still
    Should I just replace with a new one or rebuild the original?
  14. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Up to you, check the bearing as rebuild kits are usually seals not the bearing. Many rebuild since new one cost is absurd, rebuild costs peanuts.
  15. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    My WP bearing feels ok but still would like to replace it as piece of mind but the new WP price is ridiculous. Are there any options or anyone in Australia rebuilding these with a new quality bearing
  16. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    Also just shopping around for a new one and Ricambi have it for $1586 usd eurospares for 795 pounds and superformance for 295 pounds. Why is there such a price difference and are any better than others?
  17. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,629
    Elliott Caras
    Aftermarket varieties cost less than a Genuine part. I've seen questionable aftermarket water pumps for the F355. Would not want to risk a subpar water pump on a 348.
  18. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    Thanks Elliot
    So I take the superformance unit is aftermarket and the Eurospares is genuine?
    You’re not offering a rebuild service on them yet? I follow you on IG and you pretty much take care of everything else in house. Love your work
  19. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    This is a pic of mine. Would you agree it is the original. It also has green markings on the nuts, not sure if that was from factory or done at a later date?
  20. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,629
    Elliott Caras
    You would have to confirm with the vendor if the item is genuine, I find most of the Superformance stuff is aftermarket.
    I have not rebuilt a 348 water pump though.
  21. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    Yea the Eurospares site says it’s genuine so I’ll probably just go with that
    would you say mine was the original pump from factory looking at the pic?
  22. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,531
    Jeff
    FAT378 likes this.
  23. Ricambi America
    Sponsor Owner
    The pump in your photo is original.
    When it comes to 348 pumps, I would advise 'use extreme caution'.
    A failed pump on a 348 doesn't just cause the car to overheat --- it'll cause valves & pistons to meet one another in an unholy union. If the pump spins smoothly with zero sign of gritty movement or resistance, and there's no sign of movement on the shaft/pulley, and no visible coolant that has leaked, you might want to consider leaving it alone. That's just my personal option. YMMV.
    ernie and MAD828 like this.
  24. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    Thanks very much for the advice
    My mechanic mate helping me with this whole deal seems to think the same way. He has inspected it and said if it was up to him he wouldn’t touch it as it is exactly as you described. I was only considering it as I absolutely love the car and want to do everything the best I can
  25. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    I’m just doing a parts order from Eurospares and asked if they had the hill engineering PT-348 tensioners and they offered me these
    Has anyone used them and how do they compare to the Hill ones?
