348 - Engine out service please help | Page 2 | FerrariChat
348 Engine out service please help
Discussion in '348/355' started by FAT378, Jul 17, 2023.
  1. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Those are OEM, I would not use those especially if you plan to push service intervals. Hill ones are a different league.
    ernie likes this.
  2. Rifledriver
    37,335
    The trick to longevity is powder paint.
  3. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    they looked different to the OEM ones but I agree I think I’ll just stick to the Hill ones
    thanks
  4. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    Sorry what do you mean?
  5. Rifledriver
    37,335
    If you want the finish to last use powder paint.
  6. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I used red Crinkle Powder Coat for valve covers, turns out much better than rattle can and is more durable, they also have back Crinkle for the oil can.
  7. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    Everyone may already know this but I thought I’d share anyway. OEM crank angle sensor plugs just crumbled in my hands. Found a place in Victoria that sell the Bosch 3 pin connector relatively cheap. Needed a little tweaking but I was able to retain the original pins so didn’t need to unpick or cut the wire.
  8. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Yep, pretty much everything does that down there, try pulling apart the radiator fan connection, it too crumbles.
  9. AceMaster
    Feb 6, 2009
    34,793
    Ontario, Canada
    The safest (and smartest) thing to do is to change everything with quality parts right now, and don't play a guessing game with whatever the previous owner has used for parts. That way you are starting clean and you know what parts you will have installed now.
  10. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    Yea agree. This engine out service definitely escalated to more than expected and could have done a heap more but just taking baby steps for this round. I ended up adjusting all valve clearances with new shim where needed, new hill tensioner pulley’s, spring and belt. New genuine water pump (mine had a little too much play after further inspection), new cam and valve cover seals and gaskets, strip clean and paint oil tank, timing belt cover repair, new handbrake shoes, injectors serviced and flowed, engine oil filters etc, new nuts bolts etc, zinc plated some bits, vapour blasted some bits and pieces a tonne of cleaning on the engine and bay.
    Really appreciate everyone’s help and comments so far. Nice to know there is a wealth of knowledge at your fingertips.
    AceMaster likes this.
  11. AceMaster
    Feb 6, 2009
    34,793
    Ontario, Canada
    Very good.
  12. A348W
    A348W Formula 3
    Jun 28, 2017
    1,865
    North Wiltshire, UK
    part numbers listed in alternative parts thread! worth searching there first. £20 from kia !
  13. FAT378
    FAT378 Rookie
    Mar 25, 2021
    31
    Sydney Australia
    Tony Luppino
    Qavion likes this.
