Engine out.... Why? | FerrariChat
Engine out.... Why?
Discussion in '348/355' started by Adamfl, Aug 28, 2012.
  1. Adamfl
    Adamfl Rookie
    Aug 21, 2012
    10
    Sweden / USA
    Adam Flamholc
    Im gonna do a big service on my 348 in a while, changing belt, waterhoses, tensoiner bearings and so on.
    In all the threads Ive read so far everybody is talking about taking the motor out of the car... Why is that?
    Im pretty sure it can be done with the motor still in the car.
    Any ideas????
    Adam
  2. Jedi
    Jedi Moderator Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,275
    Seattle Area
    Dave
    It's a great opportunity to actually LOOK at everything and inspect from one
    end to the other. Also a great time to inspect the engine bay and clean and
    detail all the bits that cannot be reached with the engine in place.
    Jedi
  3. 2NA
    2NA F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    Read the many threads on the subject.
    Dropping the engine/gearbox unit is the only practical way of doing it "right".
    Here are a couple views of the engine, in place with the fuel tank removed. It is necessary to remove the crankshaft pulley to access the timing belts. Can you see the problem?
    Don't cut corners (or the chassis). Drop the engine, it's not really that hard with the right equipment.
  4. BOKE
    BOKE Beaks' Gun Rabbi Rossa Subscribed
    Jul 13, 2009
    33,965
    600 East Fremont Street
    Lucky
    +355
  5. 3forty8
    3forty8 F1 Rookie Owner
    Apr 25, 2006
    2,713
    San Diego
    Eric
    Great pics. I'll add that the engine and drivetrain are designed to be removed easily with the sub-frame assembly. It doesn't take much more effort to remove the engine than fudging aorund with the gas tank "method" and the result is proper access to do the job correctly.
  6. sws4re
    sws4re Formula Junior
    Jan 28, 2006
    281
    Olathe Ks
    Scott Sweat
    I would rather drop the motor than the gas tank anyway. Especially on a 348. I have dropped 2 tanks on 355s and it wasnt any fun, but I hate dealing with fuel.
  7. FlyingAces
    FlyingAces Formula Junior
    Jun 2, 2011
    849
    LA 2 Vegas
    Joejoe
  8. tcannon
    tcannon Formula 3
    Feb 18, 2009
    1,763
    Norman, OK
    Todd Cannon
    In simple terms, that is how it was designed to work. Cut corners at your own peril.
  9. angelis
    angelis F1 Veteran Owner
    Jun 18, 2004
    6,400
    London, England
    Sy
    I had an engine in Cambelt change done last year.
    This winter I'm taking the engine out.
    That's what i think of engine in cambelt changes!!!! It's a load of bollocks!!!
  10. SoCal1
    SoCal1 F1 Veteran Owner Silver Subscribed
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Motor comes out so you can make nice to it in that special way :)
  11. fjb
    fjb Formula Junior Rossa Subscribed
    Nov 12, 2006
    744
    UNK
  12. J. Salmon
    J. Salmon F1 Rookie Owner Rossa Subscribed
    Aug 27, 2005
    4,367
    VA
    OK, so it needs to have the engine out to do the service. Well, it was DESIGNED to have the engine come out. I love that you can get at it all.
    The worst has to be the 512TR, which needs engine out but is a bee-atch to do.
  13. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
    Great illustration, Tim
  14. 2NA
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I believe those are good buddy Ernie's pictures. :D
  15. Kaivball
    Kaivball Three Time F1 World Champ Owner
    Jan 11, 2007
    35,997
    Kalifornia
    Well, you "could" make a small u cut in that beam...
    Kai
  16. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,583
    San Carlos, CA
    Mitchell Le
    We'll start with your 348 this winter. I have bought extra sawzall blades for you.
  17. PatrikD
    PatrikD Rookie
    May 12, 2012
    48
    Sweden, Dalarna
    Patrik D
    Is there a diffrent to change drivebelt on a spider? The autorized Feraridealer/workshop here in Sweden change the belt whitout taking down the engine, they doing it by remove the fueltank,(i was looking at a spider and read the documenation on the drivebelt change).
    Patrik
  18. rustybits
    rustybits F1 Rookie Professional Ferrari Technician
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    That is not the way recommended by the factory. The engine is supposed to be removed.
  19. bowbells
    bowbells Formula Junior
    Jan 14, 2008
    353
    Guernsey
    Arthur Dent
    Heck with all this! Just cut the belt and thread a new one in, join ends with staples like they do on conveyor belts..............sheez people
  20. PAP 348
    PAP 348 Ten Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    That they are. :)
    Nope, same procedure to change the cam belt on the 348 coupe and 348 Spider Patrik. :)
    Either engine out or fuel tank out.
    That's what I did last time. :eek:
  21. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Holy crap, Batman!! Looks like Jaws took a bite out of it. Not much metal left there. Sure hope it was over engineered. Don't hit any potholes, for sure....
  22. chas-3
    chas-3 Formula 3 Silver Subscribed
    Jan 28, 2009
    1,281
    Colorado
    Chuck
    No offense Pap, but that is truely disturbing. ;)
  23. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
    Why on earth would anyone want to remove the fuel tank to do this?
    Why not just follow the procedure that this was designed to do = engine comes out
  24. ernie
    ernie Two Time F1 World Champ Lifetime Rossa Owner
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Yuppers. :D
    I'm glad to see they were put to good use, and that is the reason it took them. So that it's plain as day why you need to remove the engine.
  25. MRF40@yahoo.com
    [email protected] Formula Junior
    Jan 1, 2006
    563
    Planet Urf.
    like whut? Ralph??
    cutting the tube frame to allow for engine out the top, and welding in brakets to bolt the bracing back together. My old race car had this and the engine/trans came out in 20 minutes. Thoughts?
