Engine out. Wrecked the ring nut on the main TBelt drive pulley | FerrariChat
Discussion in '348/355' started by carwhisperer, Dec 28, 2014.
  1. carwhisperer
    carwhisperer Formula Junior
    Sep 29, 2014
    426
    Sacramento, CA
    Brian
    #1 carwhisperer, Dec 28, 2014
    Working on my timing belt. I dropped the motor in about 8 hours with 2 jacks and a helper. I had planned to replace the seal behind the pulley that drives the timing belt so I made a 4 prong socket for the nut. I proceeded to round it off so got to it with a chisel and hammer Hillbilly style. It looks like I can get it from Ricambi but I don't want to wait until Tuesday.
    Has anyone ever used a hex nut on this? I can't see why this ring nut is better than a locking hex nut but I'm sure Ferrari did it for a reason, seeing as how they never make mistakes. :)
  2. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    You wont get any other nut faster! do it right, buy the nut and socket from RA
  3. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,662
    San Carlos, CA
    Mitchell Le
    That is a very fine thread and no one will have a hex nut like that. You do need the nut, and the tool. That is the ONLY 4-prong tool I bought because it is so hard to grind a socket to fit that nut. Everything else with 4 prongs, I ground a socket to fit.
  4. plugzit
    plugzit F1 Veteran
    7,790
    Redondo Beach, CA
    Bruce Bogart
    IIRC the ring nut is the same as the steering wheel on the 348. Hint, hint.
  5. phrogs
    phrogs F1 Veteran
    7,357
    Kzoo Michigan
    Buy a new nut.
    Then make your tool to fit the New one. Or buy the tool.
    Then when done sell the tool you bought or put it in the box to collect dust until the next time.
  6. yelcab
    Nov 29, 2001
    13,662
    San Carlos, CA
    Mitchell Le
    Don't think so.
  7. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
    Just reuse the old nut.
  8. spaghetti_jet
    spaghetti_jet Formula Junior
    Jan 5, 2005
    946
    Europa
    Bob
    ...With some loctite. Will be fine :)
    Probably..
  9. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,276
    CT
    John Kreskovsky
    Weld the pulley on. :)
  10. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Engine out in 8 hours is strong work! Just jacking the car up, pulling the rear wheels and undoing all those fasteners to remove the 6 plastic fender liners takes me a fair bit of time. Then there's the wiggling of ECU plugs through the little slots in the bulkhead...
    I'm wondering why your home made tool mangled the nut. Although no work of art, the 4 pins look pretty straight and square. Looks like hooking it up to a good impact gun should have done the job.
  11. Brewman
    Brewman Formula Junior
    Apr 3, 2012
    417
    NC Mountains @ Boone
    Joe
    Do it right. Buy the nut and socket from Ricambi.
    Brewman
  12. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    An impact gun is the reason for the failure IMO. Right tool for the job.
  13. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    #13 cf355, Dec 29, 2014
    I don't know the cost from Ferrari for this nut but my past experience with OEM bolts/nuts has been quite reasonable.....but regardless buy a new nut and the tool to install it.
    Good for you on doing your own engine out.
  14. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Agreed....the impact gun and correct socket would have made this re & re a non event.
  15. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    found it at Ricambi: 104919 [104919 RING NUT] $4.28 each
  16. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    and the tool at Ricambi: RNT-28 [RNT-28 28mm Ring Nut Tool] $97.00 each
  17. vjlax18
    vjlax18 Formula Junior
    687
    Nottingham, MD
    I have the proper tool (RNT-28) and a good impact gun (@120psi), but I can't get the nut off. It's all ready started deforming, so I'm going to get a new nut for $7. I have it soaking right now with PB Blaster and I figured I'd try again tomorrow.
    Any suggestions?
  18. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,208
    chris
    Do you mean you have a 120 lb impact gun?
    My impact gun is 385 lbs.
    Also what size is your compressor?
  19. yelcab
    Nov 29, 2001
    13,662
    San Carlos, CA
    Mitchell Le
    A good IR impact gun, well oiled, set at 120 psi for air, will make easy work of that nut.
  20. vjlax18
    687
    Nottingham, MD
    I have a Craftsman stamped IR gun running at 120psi. I'm going to pick up another gun today to see if it's just getting old. (Thinking back, I had to use a breaker bar to get the lugs loose) What really bothers me is that the impact hits walked the crank way off TDC. I put the pulley back on and turned it back to TDC.
