Engine out | FerrariChat
Engine out
Discussion in '308/328' started by smg2, Jun 29, 2006.
  1. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    #1 smg2, Jun 29, 2006
    Well, i decided to pull the motor to do the cam pulley swap and to clean the filthy bay from the CV grease that let loose last yr. ceramic coat the headers and replace hoses since it is all accessable now. now to go rob an ATM ;)
    i noticed that the cam bank cover for 5~8 is numbered 1~4 on the cover, is this normal?
    this is job for two people. the space for pulling the motor is insanely tight and i need to go buy a load leveler for the lift. since i couldn't tilt the motor it came out by twisting it out like a screw. my neighbor helped out and brought the beer! see what a ferrari will do!
    her's some pics, enjoy...
  2. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    impressive - never seen a Mondial engine come out the top, only dropped out the bottom.
    Looking forward to more photos!!
  3. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    i asked a few guys, before braving it myself and was told it should work, it obviosly did however this it not for the faint hearted! it takes lots and i mean lots of muscle to manuver and manipulate the motor out. i'm no little guy eithier, 6 1/2ft tall 250lbs makes it easier to push things around ;) but so much harder to fit into the tight little italian work spaces of the engine bay.
    a number of points on the way up more things got stripped from the motor or bay to accomodate the engine. so it took some time and negotiating. the biggest pain are the hood hinges and the latch. the latch is rivited to the car so it stays and the hinges are oddly placed so i couldn't get at the bolts under them.
    dropping from below would ahve been the easiest but i don't have way to lift the car high enough.
  4. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,742
    The twilight zone
    yes
    ....and now that it's out, you can do cams, porting, and EFI or carbs and not need the blower to clear 300 hp :)
  5. wetpet
    wetpet F1 World Champ
    10,210
    you have more balls than me my freind.
  6. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    SUWEETNESS!! Nice job.
  7. onboost
    onboost Formula Junior
    Apr 13, 2004
    758
    DC Metro area
    Wheeeeew! Best to you my friend as I know this was quite a job. My first question was going to be why didn't drop as sub-frame from bottom. hey but you answered that already.
    I also did this job but on a Mondial cab a couple years back, dropped engine/ sub-frame from bottom. Done a lot of Porsches in my time, so hey I used to "getting it up" high enough!
    We made steel plates with L shaped square tubing welded to them, attached one end to the chassis, the other end was drilled and casters mounted to them so we could wheel the body/chassis out of the way, and do the same for the engine/trans assy. Fun stuff! Removal reasons were the same, did a full engine out service, belts hoses, timing belt, tensioners, valve adjustment (I didn't do that operation), a few gaskets, CV overhaul..you know the drill! Oh, did I mention lots of cussing and lots of beer?
    Hey, brings back fond memories had to chime in!
    Good luck..
    Paul
  8. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    i'm sick a twisted, that's how i figure it! if i had the spare $3~5k i'd gladly pay someone else to do this. but yrs of taking out motors and rebuilding them gets the best of me. the worst engine to date to pull has to be the yahama V6 in the ford SHO. transverse front drive shoehorned and greased up to get her in/out!
  9. andrewg
    andrewg F1 Rookie
    4,667
    Chester, England
    AndrewG
    Scott your insane (I mean that in the nicest way!) a simple way to get the car high enough is to remove the rear bumper and use the mounting points on the rear panel to lift the car high enough to allow the drivetrain to be wheeled out.
  10. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    #10 smg2, Jul 5, 2006
  11. DavidDriver
    DavidDriver F1 Rookie
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Which might also be a much easier and safer way to put the engine back in the car when your done. And detail the frame, etc... etc... etc..., while your at it.
    Bravo though! And please keep us posted on how you finally tackle the rest.
    I'm preparing to do the same on my GT4 shortly.
  12. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    i'll keep the updates coming. to remove the engine and sub assy from below adds another complexity, brake fluid! the harness is also clamped to the sub assy making it another pain. pulling it out up top allowed me to keep the brake and clutch lines intack. also the wiring harness didn't have to be re-threaded through. i think becouse my mondi is an '81 it was still put together so it came out up top. the engine harness connected at the sub assy making it an easy dissconnect.
    if i wheel out the sub assy i'll need casters for the 'K' brace so it wouldn't tip forward. i can still detail the engine bay. i'm not going for 100pt concours correct as it is a daily driver and keeping it spotless will drive me nuts.
    i'll be doing these services:
    cam pulley and belt change
    cam timing
    drive pulley
    plugs
    exhaust ceramic coated
    new hardware as needed
    re-design on the oil/air seperator
    replace coolant and fuel hoses..possibly all hoses
    harmonic balancer
    new accesory pulleys
    supercharger
    oil lines
    new paint for manifold,valve cover and cam cover
    fix oil pressure sender
    etc...
    all this needs to be done in the next 5~6 weeks as it is going to Monterey! so lets keep our fingers crossed! my wife already is wondering if i'm moving into the shop, or as she calls it "the bat cave"
    time and money the two things i'm always short on!
  13. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    My wife calls it the "man cave"!
    Great work! You are one ambitious dude to pull that sucker out the top! Congratulations!
    Birdman
  14. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    #14 smg2, Jul 6, 2006
    ahh, the 'whilst i'm here' continues!
    i pulled off the intake manifold to replace the hoses and in doing so noticed an injector come loose from its rubber grommet. so i decided to pull all the injectors. i ndoing some searching it looks as though the '77~'80 mercedes 450SEL uses the same rubber grommet and can be sourced for $1.39 a pop! i'll order one to see for sure. i'm going to have the injectors tested, however i also noted that the mercedes injectors are a whopping $32 per vs the $$$$ ferrari cost. a quick check of the bosch book shows all mercedes used the same injector as ferrari but not porsche! so it may be cheaper to buy all new injectors. my steel OEM's are slightly rusty and heavily carbonized.
    the cost just keeps pilling on!!
  15. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,742
    The twilight zone
    My wife refers to the ferrari as "the money disposal" and does everything she can to keep me from going into the shop, because there always seems to be a cash request when I come back out of the shop :)
  16. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    UPDATE:
    talk about ticking tiime bomb!!!! i was removing the front exhaust cam and one of the middle caps had a loose nut! not finger loose but just sitting a few threads down from the top.
    got the lower drive pulley's off and replaced them with the new ones. so far thats the easy part ;)
    now i'm waiting on injectors, seals, hoses etc...the head unit should be here next week then i can fab up the brakets and get it installed. route the oil lines and have some custom hoses done.
    sounds simple enough but i know this is going to take all the time i have for the next 6wks. i hate relying on suppliers for parts, eats way to much time :(...here's keeping those fingers crossed.
  17. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    #17 smg2, Jul 8, 2006
    ohh man was today a busy day!
    it started out with the concern over some additional thrust on the drivers side diff flange. i measured the thrust and it was .005" passenger side is 0, no movement. so i suspect a worn beering or shim. i open the case and measure and check the beerings, shims and they are all good. then as i play with the output shaft i notice the movement is further in by the clutches. so it looks as though i need to overhaul the diff, come winter. i don't have the time right now and the play isn't causing any leaks or issues yet, so back it goes.
    i notice though the that lip seal is super easy to replace now that the carrier is off. whish i had noticed that before!.
    onto the cams and pulleys! i started with 5~8 set the engined to TDC with a degree wheel. layed in the cams locating the notches and tightend down the caps. pay attention to the washers as they are belville washers, the cup faces down. tighten to 79 in*lbf or .9daN*m.
    once in i positioned the pulleys on the cams and looped on the belt. from there it was beyond easy. i set the intake pulley and found a pin hole that would work. then the exhaust pulley, it took a few turns to get a hole lined up but were talking maybe a minute of work. set the pin adjusted the tension, and rotated the engine twice. checked the TDC to the cap marks and it was spot on! locked the flywheel and tightend the cam pulley bolt to 79 ft*lbf. i also set the allen bolts on the pulleys to 90in*lbf or 7.5ft*lbf NO MORE!!! you risk shear and stripping.
    i also spent an hour scraping the silcone gasket combo off the heads and covers a real PITA! with all those studs in the way.
    no update is complete without pics so here we go....
    oh and the lipseal pic, is funny looking to me only becouse my hand is so large in comparison to it. the itailans don't have hands my size so it gets real fun working on these cars.
  18. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    #18 smg2, Jul 9, 2006
  19. AMA328
    AMA328 F1 Rookie
    Nov 12, 2002
    2,518
    ABQ-67me68-OKC :)
    hmm, clue me in here, musta missed something on the board about pulley/belt swaparoo. I know there's been discussion about the belt tooth design being outdated, etc, but I wasn't aware someone was supplying updated replacements(red pulleys in pic).
    Can you give me some more details on this, including price, supplier, etc, etc, etc., for both pulley & belts ?
    thx
  20. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
  21. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    synoptic overview:
    outer hub is 7075-T7 hub cut gear, hard ano in black mil-spec. inner is 6061-T6 red ano. double serrated belville washer and blue coated steel oxide bolts.
    HTD2 curvelinear belt, superceeds trapazoidal. 10*A/R ability.
  22. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Did you time a cams with a wheel / dial indicator after you set the cam marks to the cover? I just spent the weekend timing my cams. After I got them "spot on", I attached a 11" degree wheel to the damper and set DTC using a piston stop (found the mark on the flywheel off by .25 degree). Then checked the cams using the max lift midpoint method. I discovered both rear cams were off by 2 degrees, the front intake dead on, and the front exhaust off by 4 degrees. Having put 12 hours into cam timing, I just called it a day. Tomorrow I'll see about getting everything to within 1 degree of specs, if possible. BTW, all this was done with the engine out of the car (I'm finishing up a engine/trans rebuild). It will be interesting to see how the cam marks line up after everything is dialed in.
  23. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    yes i used a degree wheel and dial indicator, the marks on the flywheel are close but not accurate for TDC. as to the cams, if you want to be highly accurate you'll need to measure each lobe and take the average. i've yet to measure a cam and get them all the same. very time consuming and not really worth the effort on the stock motor.
    i use the timing events as per spec, and found the cams to be within 1/2*. i can further fine tune it now by pulleys without having to play pin/tooth jump.
    the factory pullies have belt tooth spacing at 12* and the pin holes are 25* on the pulley and 28* on the cam.
    my new pulleys are 10* tooth spacing and the same degrees for the pin as OEM. this has an advantage of 2* less movement when lining up the belt.
    for max lift calculations you'd need to plot the cam profile in degrees, a real PITA. i find it simpler to measure valve lift and crank degrees to spot my cams. remember cam lobes rate of rise and fall is not equal on either side of the max lift.
  24. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    mystery solved!
    i have had the hardest time getting the engine to idle right. since i've been doing the cams i noticed what the problem is. now this engine is a re-built unit fom t-rutlands the PO had installed.
    the intake cams are ferrari OEM 2Vi the exhaust cams are not ferrari OEM and have the timing events of the 2vEuro carb. so this is what my timing events look like.
    I: 16/48
    E: 30/28
    any ideas on what this will do for power or where? i have driven the car for 5k+ miles and it does not lack low end torque from what i can feel. it pulls strong and keeps pulling right up to redline. the idle sounds like a small block chevy though, a thrump, thrump, thrump, ttthrump, and so forth smooth for a few cycles then lumpy a few cycles. it'll smooth out right around 2krpm.
  25. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,338
    Dumpster Fire #31
    SMG
    cams, cams, cams the big PITA! alright i grabbed another dial gauge and went to work setting TDC. lined up the cams and caps. checked shim gap. here is what i got at factory settings of notches lining up with caps. all measurments at .50mm/.0196" lift
    Banks 5~8
    I:18/32
    E:42/17
    factory setting should be:
    I:16/48
    E:50/14
    as we can see the grind on my cams is not there. using the my new pulleys i advanced the exhaust by 3* to get 48/11 and retarded the intake 2* to get 14/36.
    started on banks 1~4 today.
    once again lined it all up TDC and set the caps/cams.
    I:6/45
    if i move it by 8* i'll get close to the front bank with 14/37
    so setting the cams to line up TDC with the caps and notches doesn't get the events correct. all i can figure is someone re-ground these and that explains the problems.
    i'm calling t-rutlands tommorow morning to see what can be done. the motor was a replacement by the PO from them.
