Engine out ........... | FerrariChat
Discussion in '348/355' started by fxdwgs, Apr 14, 2015.
  1. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    #1 fxdwgs, Apr 14, 2015
  2. Uncle
    Uncle Rookie
    Jun 6, 2014
    18
    Newcastle
    Maybe it's a Porsche thing. On my last 911 I got it down to 46 minutes working alone. Going by your pictures though it's a more complex job than a 911.
  3. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,224
    CT
    John Kreskovsky
    4 times in 9 years?
  4. dapper
    dapper Formula Junior
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    4 times in 9yrs.....this cam belt thing really has got out of hand, as an Engineer I'm finding this whole thing rediculous!
  5. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    That is pretty fast.
    Nice job and thanks for sharing.
  6. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    We inspected my 5 year old belts and my opinion is that the belt change itself is the least important part of the whole process. It's all the other stuff you find when you're in there that justifies the 5 year rule. Doing this for belts only seems unnecessary.
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,567
    San Carlos, CA
    Mitchell Le
    From the engine on the floor, to engine in with bolts torqued down, and nothing else connected, 2 hours is a decent time. Also, as Gobble said, getting the engine out to do everything else is the reason. The belt, it lasts a long time.
  8. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    It took me two hours just to remove the front carpets and evacuate the Freon. That time above is amazing.
  9. WATSON
    23,688
    WI
    Holy smokes.
    1: TWO hours? I don't care if that was with 4 people. Wowzer
    2: 4 times in 9 years? Why?
    My car is just about done...and it has been gone since January 6th!
  10. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
    4x in 9 years seems excessive...unless absolutely imperative to do so.
  11. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Pretty cool
    Looks like your all set up to do it
    Dialing in my setup here also
  12. vjlax18
    vjlax18 Formula Junior
    687
    Nottingham, MD
    Are you using some sort of hydraulic lift table? I'm thinking about picking one up so I can drop the motor out instead of lifting the body off.
  13. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    There was only one year between some years ago....found out the waterpump was not healthy and ordered a new one......three months deliverytime....so changed waterpump next Winter.......Engine out again......next time 2019.....if we are alive and kicking by then!
  14. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    .....the only hydraulic is the lift...... the table is a four Wheel one, just because it is easier to swing around.
  15. Robbe
    Robbe Formula Junior
    622
    The Netherlands
    I have been busy for 2 weeks already, and the moment is approaching fast!
    Just have to make sure the ecu cable / loom is free, and I have it out.
    2 weeks, of maybe 2 hours an evening, and on the saturdays and sundays some extra time, so I would estimate 15 - 20 hours...
    But I have labelled everything, and in the same time made the dolly, and a higher floor to let the dolly pass the lower parts of my polishing lift (easy for brakes and bodywork/ not so easy if you have to remove an engine...)
    So 2 hours is absurdly fast in my eyes...
    Hope to do the next in a few years, in say 10 hours...
  16. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    I have all my parts lined up for an engine out but a MAJOR service. lots of home made mods and parts to put on
    First I need to do headgaskets on my duramax diesel, waiting on my new garage stall
  17. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    #17 gobble, Apr 14, 2015
    Mine was from harbor freight.
  18. vjlax18
    687
    Nottingham, MD
    That's exactly what I was thinking. Do your 4x4 pads leave room to drop the oil pan too? (Looks like the HF 1000lb table is on sale for $260 too)
  19. yelcab
    Nov 29, 2001
    13,567
    San Carlos, CA
    Mitchell Le
    What he said is not clear, but what I read is he put the engine back into the car in 2+hours without connecting anything up. With a lift, that is very standard speed.
    From driving the car on to a lift, and engine on the ground, it is 6 hours with 2 persons.
  20. gobble
    gobble Formula 3
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    You could but that seems easier to do with the engine in the car. You can stack a 25% coupon onto the sale price too.
  21. vjlax18
    687
    Nottingham, MD
    Not to hijack the thread, but knowing that I have to replace the crank seal. Pull the oil pan, drop the motor, perform major, put motor back in, re-install oil pan?
  22. dahveedem
    dahveedem Formula 3
    Mar 12, 2012
    1,603
    Maryland
    David
    Can I fly you here to teach me how to do it in that time?
  23. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    .......it is because of the write ups you and Paul of Norway made.......otherwise I would still try to figure it all out......
    All the credit to you guys...
    Thanks,
    //B//
  24. fxdwgs
    fxdwgs Formula 3
    Aug 22, 2006
    1,016
    Sjobo, Sweden
    Bengt
    David,
    You would be better off with Ernie......we are using his write up.
    Rgds,
    Bengt
  25. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,990
    Northeast U.S.
    Jim
    #25 jimmym, Apr 15, 2015
