Engine penalty Fix thread. | FerrariChat
Discussion in 'F1' started by Bas, Sep 10, 2022.
  1. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,708
    ESP
    Bas
    Carrying over from the Monza practise thread, this is an issue that's been a problem for years, and will be a problem in the future, so lets give it it's own thread.
    The fix is very difficult because these engines are so obscenely expensive and teams always put their self interest first. So even if alll teams made a pact "we'll just give everyone a brand new engine every race so we'll start in the same position", inevitably there'll be someone that renegs on the last moment to score a cheap pole...but aside from that, what is the FIA to do? No penalty? We'll end up with top teams using a new engine every day of the weekend and the rest unable to afford it, falling behind. Put the engines in the budget cap? One failed engine at the half way point or so will then lead to said team being excluded from the championship for spending too much money.
    F1, once again, looks foolish today as people only knew the starting grid (provisionally...) a mere 6 hours after the fact. After all this time, and this is definitely not the first time this penalty system led to no one knowing where they start, could easily have been solved by having someone clever work his magic with Excel, with the penalty (time+size of penalty) parameters put in. It can't be that hard.
    But going back to finding a solution...There isn't a simple one. Even the richest team will struggle to put a new engine in every weekend due to cost. That's 40 mil a weekend on engines for the 2 cars, with the spending cap they'll be looking at just over a billion to run the team. Excluding drivers.
    Give them 8 engines for the season? We'll have 2 problems: What if they use a 9th? Back of the grid penalty. Worth it. Same problem as today. And they'll just tune their engine to have more power. FIA won't approve more power? Just telll them it's a "reliabillity upgrade".
    What about changing the penalty? Back of the grid doesn't work. Race exclusion? That'll really suck if you're alfa romeo, at the pace they're going, Monza might be their last race of the season. Damn it'll be really embarrassing for F1 if for the Abu Dhabi season finale 2 teams show up.
    Contructor points penalty? "And in 9th place in the WCC, we have Haas, with minus 122 points, followed by Alfa Romeo at -480, which brings their total ever points scored in F1 history to...minus 301! And big teams up ahead will either have a decent gap in the constructor race and can just take free engines whenever they like, or wait for their rivals to take an engine and do the same...
    Heavier constructor points penalty depending on where they are in the championship? People don't want a maths degree calculating that ****. And again, a team not caring about their WCC standings can just make the hottest, 1 race engine, score minus 500 points and win the WDC....and on top of that, be so lucky that because they are now last in WCC standings, they get the most development hours! This is a win win!
    The real, only solution to this is have cheaper, simpler engines. Limit it to 1 engine per weekend. Remove the heavy battery. Keep the current ICE, allow 2 off the shelf turbos and be done with it, put in that zero carbon fuel and then work on a really exciting engine for 2028 or so. V10/12, 3.5 liter, zero carbon fuel, 16K rpm or whatever, 350K cost cap per engine. Blow it up or find critical damage? Start from the pitlane on a first come, first serve basis. With 1 engine per weekend cost per season for 2 cars is 15 million. Not even the cost of one engine today. I'm sure they'll find a way of making it last a whole race. Especially with material restrictions, rpm restrictions, oil restrictions and so on. Any idiot would be capable of making their own engine, even Mclaren this time.
    Nortonious likes this.
  2. william
    william Two Time F1 World Champ
    27,636
    Here we go again ...
  3. Jack-the-lad
    Jack-the-lad Seven Time F1 World Champ
    I’m not sure which addiction has been worse for F1: money or technology. The cars don’t have to be so complex, but to lure manufacturers the boards of directors have to be convinced that all of that money is going toward technology that is “relevant” to and supportive of their core business. Certainly, all that technology isn’t necessary just to make the cars faster…..which should be the point….unless you write the technical rules specifically to that purpose.
    Bas and william like this.
  4. william
    27,636
    It's certain that technology is slowly killing the sport. But I can't see it ever going back to "basics".
  5. DeSoto
    DeSoto F1 Veteran
    Nov 26, 2003
    7,792
    Well, probably giving a pair of extra engines per season would reduce drastically the penalties. The engines are not included in the cost cap and the price for the customers is capped too so it wouldn't bankrupt the whole grid.
  6. WPOZZZ
    WPOZZZ F1 Veteran
    Aug 22, 2012
    6,508
    Honolulu, HI
    Go back to 5 engines per season, and cut the number of races. Also, why not let the teams rebuild the engine that is in their allotment?
  7. Bas
    Mar 24, 2008
    42,708
    ESP
    Bas
    This would be the best temporary fix IMO, BUT, and it's a big one, with the current engines being very close to each other (Ferrari leads, Honda behind by 4kw, Merc and Alpine 5-7KW behind Ferrari), FIA should close the door to reliability upgrades, as otherwise we'll just get exactly the same stuff going on as they'll suddenly tune their engine for more power...
    There is engine parity now (only took 8 years but whatever), lock it in and give them up to 5 engines. Problem solved.
  8. WPOZZZ
    WPOZZZ F1 Veteran
    Aug 22, 2012
    6,508
    Honolulu, HI
    But why doesn't FIA allow the teams to rebuild the motor?
  9. Bas
    Mar 24, 2008
    42,708
    ESP
    Bas
    Not a clue.
    Presumably because big teams will just replace the whole thing rather than rebuild as there's a tiny advantage or something...
  10. DeSoto
    DeSoto F1 Veteran
    Nov 26, 2003
    7,792
    I guess the blocks are already wasted after 5 races so not worth rebuilding. But maybe they should allow replacement of internals when something breaks down. Also I don´t know why turbos are so restricted.
    In any case, it looks like the parts allotment is insufficent. Probably FIA does it on purpose not to save costs but to have mixed grids.
  11. william
    27,636
    I suppose they are too complex to be worked on outside the facilities of the engine builders.
    I can't see Haas, or Williams having access to the entrails of Ferrari or Mercedes engines.
  12. william
    27,636
    Years ago, BMW used old cylinder blocks from road cars that had been through plenty of thermal cycles to make their turbo engines (in Piquet time), saying it was more beneficial than taking new ones fresh from foundry. Something to do with weathering, metal stress relief and molecules that I can't fully explain.
    Dino2010, DeSoto and 375+ like this.
  13. JL350
    JL350 Karting
    Jan 20, 2013
    215
    I think there should be 5 or 6 allocated a year, it is motor sport anyway and the cars and their components are consumable anyway so there is some reason for us to watch. There could be a constructor penalty for exceeding the allocation that is related to the final championship finish position, ie each engine is -20 points, if you are number 1 it’s a full -20 points, if you are in 5th position it maybe -10 points.
    just my 2 cents.
    Bas likes this.
  14. SPEEDCORE
    SPEEDCORE Four Time F1 World Champ
    Jul 11, 2005
    46,182
    Toe Knee
    It's the easiest way for the FIA to police the current regs (using seals) and stop the teams from cheating. Nothing to do with how complex the engines are or how long the blocks last.
    william and Bas like this.
  15. JJ
    JJ F1 World Champ
    Jan 6, 2010
    11,362
    PA
    Why not simply have a budget cap and let the teams allocate their capital as they see fit?
  16. william
    27,636
    The simple notion of budget cap in a "sport" is contentious.
    Why do we need it? who benefits from it? Who called for it ? How do you control it?
  17. JJ
    JJ F1 World Champ
    Jan 6, 2010
    11,362
    PA
    I agree. I'd love the formula to be "if it fits inside this box, run it if you think you can win with it." Wishful thinking, though.
  18. william
    27,636
    I too dream of a Formula Unlimited, sort of "Run What You Brung", with a minimum of parameters imposed.
    I tend to think that rules kill the fun, everywhere.
    JJ likes this.
  19. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    Allowing the engines to be 'rebuilt' opens a huge can of worms as to what constitutes the parts required for a 're-build'. The teams will just find a way to make it look like EVERY part needs to be replaced and you are just where you are started. The power units are much to complex for the FIA to police when it is permitted to rebuild part or all of it.
  20. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    This is true. BMW did use engines from old taxi cabs because the thousands of heat cycles they had been through made for a very stable block that thermally deformed very little. Problem is that once BMW caught onto this they devised an incredibly expensive way to mimic this same condition in new engines. Again without restrictions the teams will find a way to burn through money.
    william likes this.
  21. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    This is the utopian dream of many but the concept is flawed for some basic reasons:
    1. Designers can easily make a car that no human on the planet can pilot to its limits. As such the human element is excluded and it becomes a competition between engineers. That is NOT sport
    2. An open situation also presumes open budgets which again will very quickly escalate to the point that it becomes economically impossible to compete
    Racing is no different than life in that rules and regulations are required to avoid us destroying ourselves. It is basic human nature and elevate the element of competition and you have a recipe for disaster.
    Bas likes this.
  22. william
    27,636
    Hold your horses !!
    I said it was a dream ...;)
    Nuvolari likes this.
